iPhone Battery Replacement Triage
Fix the iPhone you already have – and save money and the planet in the process.
Find your iPhone model below and follow a step-by-step battery replacement guide. (Each guide will also link the corresponding Fix Kit with all the parts and tools needed to complete the guide.)
Frequently Asked Questions
Can I replace my iPhone battery myself?
Yes, you can replace your iPhone battery yourself. iFixit provides free step-by-step repair guides for every iPhone and sells DIY Battery Fix Kits for iPhones ranging from the 4 series to the 15 series. These kits include all the necessary tools and parts to replace your battery.
The repair process generally involves handling adhesive, screws, connectors, the screen, and is relatively straightforward. Apple simplified the battery replacement process by making the iPhone 14's back glass removable so a fixer does not need to remove the screen to access the battery. This “open from the front and back” design became the norm with the iPhone 16 series (the 16's battery is also secured by a new, more repair-friendly adhesive which debonds when an electrical current passes through it).
How much does it cost to replace my iPhone's battery myself?
Using an iFixit kit to replace your iPhone battery yourself can save you $34 to $49 compared to Apple's out-of-warranty repair costs, depending on your model. iFixit's battery replacement kits average around $40, while kits for newer models like the iPhone 16 cost around $55.
ModelApple's Cost (Out of Warranty)^iFixit CostSavings
iPhone SE$69$29.99$39
iPhone 7$69$29.99$39
iPhone 7 Plus$69$29.99$39
iPhone 8$69$29.99$39
iPhone 8 Plus$69$29.99$39
iPhone X$89$39.99$49
iPhone XS$89$39.99$49
iPhone XS Max$89$39.99$49
iPhone XR$89$39.99$49
iPhone SE 2020$69$31.99$37
iPhone 11$89$36.99$52
iPhone 11 Pro$89$39.99$49
iPhone 11 Pro Max$89$39.99$49
iPhone 12$89$46.99$42
iPhone 12 Pro$89$46.99$42
iPhone 12 Pro Max$89$44.99$44
iPhone 12 mini$89$44.99$44
iPhone 13$89$39.99$49
iPhone 13 Pro$89$39.99$49
iPhone 13 Pro Max$89$44.99$44
iPhone 13 mini$89$39.99$49
iPhone SE 2022$69$34.99$34
iPhone 14$99$59.99$39
iPhone 14 Plus$99$49.99$49
iPhone 14 Pro$99$54.99$44
iPhone 14 Pro Max$99$54.99$44
iPhone 15$99$49.99$49
iPhone 15 Plus$99$49.99$49
iPhone 15 Pro$99$49.99$49
iPhone 15 Pro Max$99$49.99$49
^ Apple's shared estimates as of November 2024.
How long does it take to fix an iPhone battery?
While the time investment can vary based on the iPhone model and your DIY experience, repairing your iPhone battery yourself is feasible. The repair should take you anywhere from 30 minutes to a couple of hours. If you get stuck, iFixit's community of fixers can help.
Further Reading: The World of DIY iPhone Repair
Author
with
Evan Gattuso
25,935 Reputation
7 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
21 Comments
Is there an option to have my iPhone 14 battery removed but not replaced? My battery is damaged an Verizon will not accept my phone to trade in for credit towards an upgrade with the battery still in it
Sdogg - Reply Share
Hi Sdogg,
You can use the iPhone 14 Battery Replacement guide to open your device and remove the battery. Hope this helps!
Manuel Haeussermann - Reply Share
What should I do if I find that a screw from the iPhone I am replacing has been stripepd? It seems as though within the manufacturing of the phone, 2 of the screws for this guide are completely unscrewable.
What should I do???
Marc Tabailloux - Reply Share
Hi Marc,
Sorry to hear your issue with the iPhone screws. There are several different options to try when dealing with stripped screw which are detailed in the "How to Remove a Stripped Screw" guide.
I have a refurbished iPhone XS and I attempted to replace the battery via your video. The instructions that came with the battery was useless so thank you! The adhesive tabs didn’t appear when I loosened the tape around the battery and I tried pulling on that but it kept tearing so I tried lifting one side and saw smoke! I checked out my options on your website but I’m concerned about using alcohol or high heat. Do I have another option or has it been irreversibly damaged in your opinion?
Thanks,
KT
KimT - Reply Share
Past 24 Hours: 807
Past 7 Days: 4,267
Past 30 Days: 19,555
All Time: 685,759
