Up to 20% off select tools
iPhone 11 Pro Battery Replacement
Views: 317K
View statistics:
Past 24 Hours:
82
Past 7 Days:
679
Past 30 Days:
3,203
All Time:
316,752
Comments: 71
55 comments on steps, 16 guide comments.
Go to guide comments
Completed: 119
119 people have marked this guide "completed." Will you be next?
Favorites: 14
14 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
iPhone batteries are rated to hold 80% of their capacity for up to 500 charge cycles, which lasts roughly 18-24 months for most users. After that, your iPhone may need to be charged far more frequently, and iOS may warn you that performance is affected (in other words, your phone will run slower). Use this guide to replace your battery and restore your iPhone to like-new performance.
If your battery is swollen, take appropriate precautions.
Note: After the repair, your iPhone may display a warning about the “genuineness” of the battery, even when using original Apple parts. If your iPhone functions normally, you can safely ignore the warning.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
    1. iPhone 11 Pro Battery Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone 11 Pro Battery Replacement, Remove the pentalobe screws: step 1, image 2 of 2
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone 11 Pro Battery Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 11 Pro Battery Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 11 Pro Battery Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 11 Pro Battery Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 11 Pro Battery Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 11 Pro Battery Replacement, Tape over any cracks: step 3, image 3 of 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    2. iPhone 11 Pro Battery Replacement, Screen damage warning: step 4, image 1 of 3 iPhone 11 Pro Battery Replacement, Screen damage warning: step 4, image 2 of 3 iPhone 11 Pro Battery Replacement, Screen damage warning: step 4, image 3 of 3
      • To avoid damaging your screen in the next steps, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll damage the screen.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive. In this case, you’ll most likely need to replace your entire screen.
      Ask FixBot
    3. iPhone 11 Pro Battery Replacement, Anti-Clamp instructions: step 5, image 1 of 3 iPhone 11 Pro Battery Replacement, Anti-Clamp instructions: step 5, image 2 of 3 iPhone 11 Pro Battery Replacement, Anti-Clamp instructions: step 5, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    4. iPhone 11 Pro Battery Replacement: step 6, image 1 of 3 iPhone 11 Pro Battery Replacement: step 6, image 2 of 3 iPhone 11 Pro Battery Replacement: step 6, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    5. iPhone 11 Pro Battery Replacement: step 7, image 1 of 3 iPhone 11 Pro Battery Replacement: step 7, image 2 of 3 iPhone 11 Pro Battery Replacement: step 7, image 3 of 3
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    6. iPhone 11 Pro Battery Replacement, Heat the lower edge of the phone: step 8, image 1 of 1
      • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
      Ask FixBot
    7. iPhone 11 Pro Battery Replacement: step 9, image 1 of 2 iPhone 11 Pro Battery Replacement: step 9, image 2 of 2
      • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
      Ask FixBot
    8. iPhone 11 Pro Battery Replacement, Lift the display slightly: step 10, image 1 of 3 iPhone 11 Pro Battery Replacement, Lift the display slightly: step 10, image 2 of 3 iPhone 11 Pro Battery Replacement, Lift the display slightly: step 10, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
      • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    9. iPhone 11 Pro Battery Replacement, Separate the screen adhesive: step 11, image 1 of 3 iPhone 11 Pro Battery Replacement, Separate the screen adhesive: step 11, image 2 of 3 iPhone 11 Pro Battery Replacement, Separate the screen adhesive: step 11, image 3 of 3
      • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      Ask FixBot
    10. iPhone 11 Pro Battery Replacement, Screen information: step 12, image 1 of 1
      • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
      Ask FixBot
    11. iPhone 11 Pro Battery Replacement: step 13, image 1 of 3 iPhone 11 Pro Battery Replacement: step 13, image 2 of 3 iPhone 11 Pro Battery Replacement: step 13, image 3 of 3
      • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Ask FixBot
    12. iPhone 11 Pro Battery Replacement: step 14, image 1 of 3 iPhone 11 Pro Battery Replacement: step 14, image 2 of 3 iPhone 11 Pro Battery Replacement: step 14, image 3 of 3
      • The top edge of the display is secured with both glue and clips.
      • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
      • Insert your pick into the top-right corner of the phone.
      Ask FixBot
    13. iPhone 11 Pro Battery Replacement: step 15, image 1 of 2 iPhone 11 Pro Battery Replacement: step 15, image 2 of 2
      • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
      • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
      • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
      Ask FixBot
    14. iPhone 11 Pro Battery Replacement, Remove the suction cup: step 16, image 1 of 1
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Ask FixBot
    15. iPhone 11 Pro Battery Replacement, Open the iPhone: step 17, image 1 of 3 iPhone 11 Pro Battery Replacement, Open the iPhone: step 17, image 2 of 3 iPhone 11 Pro Battery Replacement, Open the iPhone: step 17, image 3 of 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
      Ask FixBot
    1. iPhone 11 Pro Battery Replacement, Unscrew the battery connector cover: step 18, image 1 of 2 iPhone 11 Pro Battery Replacement, Unscrew the battery connector cover: step 18, image 2 of 2
      Magnetic Project Mat
      $16.96
      Buy
      • Remove two 1.3 mm long Y000 screws securing the battery cover bracket.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Ask FixBot
    2. iPhone 11 Pro Battery Replacement, Remove the battery connector cover: step 19, image 1 of 1
      • Remove the bracket.
      Ask FixBot
    3. iPhone 11 Pro Battery Replacement, Disconnect the battery: step 20, image 1 of 2 iPhone 11 Pro Battery Replacement, Disconnect the battery: step 20, image 2 of 2
      • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Ask FixBot
    4. iPhone 11 Pro Battery Replacement, Unscrew the logic board cover screws: step 21, image 1 of 2 iPhone 11 Pro Battery Replacement, Unscrew the logic board cover screws: step 21, image 2 of 2
      • Use a Y000 driver to remove six 1.3 mm screws securing the logic board cover bracket.
      Ask FixBot
    5. iPhone 11 Pro Battery Replacement, Remove the logic board cover bracket: step 22, image 1 of 1
      Ask FixBot
    6. iPhone 11 Pro Battery Replacement, Disconnect the OLED display cable: step 23, image 1 of 2 iPhone 11 Pro Battery Replacement, Disconnect the OLED display cable: step 23, image 2 of 2
      • Use a spudger or a fingernail to disconnect the OLED panel cable connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    7. iPhone 11 Pro Battery Replacement, Disconnect the front sensors + digitizer: step 24, image 1 of 3 iPhone 11 Pro Battery Replacement, Disconnect the front sensors + digitizer: step 24, image 2 of 3 iPhone 11 Pro Battery Replacement, Disconnect the front sensors + digitizer: step 24, image 3 of 3
      • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
      • Use a spudger or a fingernail to disconnect the digitizer cable connector.
      • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
      Ask FixBot
    8. iPhone 11 Pro Battery Replacement, Remove the display assembly: step 25, image 1 of 1
      Ask FixBot
    1. iPhone 11 Pro Battery Replacement, Unscrew the lower battery connector cover: step 26, image 1 of 1
      • Use a Y000 driver to remove the four 1.5 mm screws securing the lower battery connector cover.
      Ask FixBot
    2. iPhone 11 Pro Battery Replacement, Remove the cover: step 27, image 1 of 1
      • Remove the lower battery connector cover.
      Ask FixBot
    3. iPhone 11 Pro Battery Replacement, Disconnect the lower battery connector: step 28, image 1 of 2 iPhone 11 Pro Battery Replacement, Disconnect the lower battery connector: step 28, image 2 of 2
      • Use a spudger to disconnect the lower battery flex cable by prying it straight up from its socket.
      Ask FixBot
    4. iPhone 11 Pro Battery Replacement, Disconnect the Taptic Engine: step 29, image 1 of 2 iPhone 11 Pro Battery Replacement, Disconnect the Taptic Engine: step 29, image 2 of 2
      • Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
      Ask FixBot
    5. iPhone 11 Pro Battery Replacement, Unscrew the Taptic Engine: step 30, image 1 of 2 iPhone 11 Pro Battery Replacement, Unscrew the Taptic Engine: step 30, image 2 of 2
      Standoff Screwdriver for iPhones
      $5.49
      Buy
      • Remove the three screws securing the Taptic Engine:
      • One 1.9 mm-long Y000 screw
      • One 1.4 mm-long Y000 screw
      • One 4.1 mm-long standoff screw
      • Standoff screws are best removed using a standoff screwdriver or bit.
      • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      Ask FixBot
    6. iPhone 11 Pro Battery Replacement, Remove the Taptic Engine: step 31, image 1 of 1
      • Remove the Taptic Engine.
      Ask FixBot
    1. iPhone 11 Pro Battery Replacement, Unscrew the flex cable bracket: step 32, image 1 of 2 iPhone 11 Pro Battery Replacement, Unscrew the flex cable bracket: step 32, image 2 of 2
      • Use a Y000 driver to remove the two 1.4 mm screws securing the Lightning flex cable bracket.
      Ask FixBot
    2. iPhone 11 Pro Battery Replacement, Remove the flex cable bracket: step 33, image 1 of 1
      • Remove the flex cable bracket.
      Ask FixBot
    3. iPhone 11 Pro Battery Replacement, Disconnect the Lightning flex cable: step 34, image 1 of 3 iPhone 11 Pro Battery Replacement, Disconnect the Lightning flex cable: step 34, image 2 of 3 iPhone 11 Pro Battery Replacement, Disconnect the Lightning flex cable: step 34, image 3 of 3
      • Pry up to disconnect both of the Lightning flex cable connectors from the Logic board.
      Ask FixBot
    4. iPhone 11 Pro Battery Replacement, Push the flex cable aside: step 35, image 1 of 2 iPhone 11 Pro Battery Replacement, Push the flex cable aside: step 35, image 2 of 2
      • Gently lift the Lightning flex cable and bend it slightly toward the bottom edge of the iPhone for better access to the battery underneath.
      Ask FixBot
    5. iPhone 11 Pro Battery Replacement, Locate the adhesive pull-tabs: step 36, image 1 of 3 iPhone 11 Pro Battery Replacement, Locate the adhesive pull-tabs: step 36, image 2 of 3 iPhone 11 Pro Battery Replacement, Locate the adhesive pull-tabs: step 36, image 3 of 3
      • The battery is secured to the rear case with three pieces of stretch-release adhesive—one near the bottom edge of the battery, one near the top, and one on the right.
      • Each piece of adhesive has one or two black pull-tabs at the end, which are lightly adhered to the side edges of the battery.
      • In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. These "command-strip" style adhesives lose their stick when stretched, so you can remove the battery with ease.
      • If the strips break, don't panic! They don't always work as intended. Keep reading for tips on removing broken strips.
      Ask FixBot
    6. iPhone 11 Pro Battery Replacement: step 37, image 1 of 2 iPhone 11 Pro Battery Replacement: step 37, image 2 of 2
      • Peel down the first battery adhesive pull-tab to un-stick it from the bottom edge of the battery.
      • Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
      Ask FixBot
    7. iPhone 11 Pro Battery Replacement, Remove the bottom adhesive strip: step 38, image 1 of 3 iPhone 11 Pro Battery Replacement, Remove the bottom adhesive strip: step 38, image 2 of 3 iPhone 11 Pro Battery Replacement, Remove the bottom adhesive strip: step 38, image 3 of 3
      Buy
      • Grab the pull tab with your fingers and slowly pull it away from the battery, toward the bottom of the iPhone.
      • Pull hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
      • Don't press down on the battery. Hold the iPhone firmly by its sides.
      • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
      • Pull at a low angle so the strip doesn't snag on the edge of the battery.
      • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
      • If any of the adhesive strips break off underneath the battery and can't be retrieved, try to remove the other strips, and then proceed as instructed below.
      Ask FixBot
    8. iPhone 11 Pro Battery Replacement: step 39, image 1 of 3 iPhone 11 Pro Battery Replacement: step 39, image 2 of 3 iPhone 11 Pro Battery Replacement: step 39, image 3 of 3
      • The top pull tabs lie very close to the Face ID sensors. If damaged, Face ID can only be repaired by Apple, so work with care. Don't touch the lenses with your fingers.
      • Peel down the battery adhesive pull tabs to un-stick them from the top edge of the battery.
      Ask FixBot
    9. iPhone 11 Pro Battery Replacement, Remove the top adhesive strip: step 40, image 1 of 3 iPhone 11 Pro Battery Replacement, Remove the top adhesive strip: step 40, image 2 of 3 iPhone 11 Pro Battery Replacement, Remove the top adhesive strip: step 40, image 3 of 3
      • Grab both pull tabs at the same time, and slowly pull to stretch the adhesive away from the battery, toward the top of the iPhone.
      • Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
      • If the adhesive breaks off underneath the battery and can't be retrieved, continue with the next step.
      Ask FixBot
    10. iPhone 11 Pro Battery Replacement: step 41, image 1 of 3 iPhone 11 Pro Battery Replacement: step 41, image 2 of 3 iPhone 11 Pro Battery Replacement: step 41, image 3 of 3
      • Peel up the two remaining battery adhesive pull-tabs to un-stick them from the right edge of the battery.
      Ask FixBot
    11. iPhone 11 Pro Battery Replacement, Remove the side adhesive strip: step 42, image 1 of 3 iPhone 11 Pro Battery Replacement, Remove the side adhesive strip: step 42, image 2 of 3 iPhone 11 Pro Battery Replacement, Remove the side adhesive strip: step 42, image 3 of 3
      • Using the same procedure as before, pull both tabs at the same time to stretch and remove the remaining adhesive strip holding the battery in place. Try not to snag the adhesive on the edge of the iPhone.
      • Be careful not to fling the battery from the iPhone as the final adhesive strip comes out.
      • If you removed all the adhesive strips successfully, skip the next step.
      • Otherwise, continue with the next step below.
      Ask FixBot
    12. iPhone 11 Pro Battery Replacement, How to remove a stuck battery: step 43, image 1 of 2 iPhone 11 Pro Battery Replacement, How to remove a stuck battery: step 43, image 2 of 2
      • If you're still having trouble removing the battery, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
      • Wait about one minute for the alcohol solution to weaken the adhesive.
      • Use the flat end of a spudger to gently lift the battery.
      • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
      Ask FixBot
    13. iPhone 11 Pro Battery Replacement, Remove the battery: step 44, image 1 of 1
      • Remove the battery.
      • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
      • Before you adhere the replacement battery, temporarily reconnect the battery connector to the motherboard socket. This ensures that the battery is properly aligned in its recess.
      • Adhere the battery, disconnect it, and continue reassembling your device.
      • If your new battery didn't come with adhesive preinstalled, refer to this guide for help replacing the adhesive strips.
      • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 11 Pro Answers community for help.
119 other people completed this guide.
Author
with
Jeff Suovanen
455,892 Reputation
259 Guides authored
16 Guide Comments
Is the waterproof lost?
sanrovan - Reply Share
The replacement battery comes with a new seal, but I wouldn’t trust that too much.
ethan mccarty - Reply Share
very nice and very hepful instructions. keep it up…
Amer Khan - Reply Share
Schwierig, aber effektiv. Man braucht volle KONZENTRATION
Dr. Kurt Neukirchen - Reply Share
Is there any way to remove the “Important Battery Message” notification that’s constantly on the home screen for settings?
Raymond Moore - Reply Share
Past 24 Hours: 82
Past 7 Days: 679
Past 30 Days: 3,203
All Time: 316,752
