Up to 20% off select tools
iPhone 15 Pro Battery Replacement
Views: 202K
View statistics:
Past 24 Hours:
398
Past 7 Days:
2,788
Past 30 Days:
12,218
All Time:
202,207
Comments: 60
48 comments on steps, 12 guide comments.
Go to guide comments
Completed: 46
46 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the battery in your iPhone 15 Pro.
iPhone batteries are rated to hold 80% of their capacity for up to 1000 charge cycles. If your iPhone needs to be charged more often or runs slower, it might be time to replace the battery.
You'll need replacement screen adhesive to complete this repair. If your new battery doesn't come with adhesive pre-installed, you'll need replacement adhesive for it as well.
If your battery is swollen, take appropriate precautions.
Note: Due to Apple's parts pairing restrictions, on iOS 17.6 and earlier, you may receive warnings about your replacement part and lose access to battery health data, but your new battery will otherwise work normally. On iOS 18 and newer, all batteries should work normally. Pair original Apple batteries using Repair Assistant.
    1. iPhone 15 Pro Battery Replacement, Prepare your iPhone for disassembly: step 1, image 1 of 2 iPhone 15 Pro Battery Replacement, Prepare your iPhone for disassembly: step 1, image 2 of 2
      • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone.
      • Hold the power and either volume button and slide to power off your phone.
      Ask FixBot
    2. iPhone 15 Pro Battery Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 15 Pro Battery Replacement, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    1. iPhone 15 Pro Battery Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 15 Pro Battery Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 15 Pro Battery Replacement, Mark your opening picks: step 3, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 15 Pro Battery Replacement, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 15 Pro Battery Replacement, Remove the pentalobe screws: step 4, image 2 of 2
      • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 15 Pro Battery Replacement, Screen information: step 5, image 1 of 1
      • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
      • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
      Ask FixBot
    2. iPhone 15 Pro Battery Replacement, Heat the bottom edge: step 6, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Ask FixBot
    3. iPhone 15 Pro Battery Replacement, Insert an opening pick: step 7, image 1 of 3 iPhone 15 Pro Battery Replacement, Insert an opening pick: step 7, image 2 of 3 iPhone 15 Pro Battery Replacement, Insert an opening pick: step 7, image 3 of 3
      • Apply a suction handle to the bottom edge of the screen.
      • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    4. iPhone 15 Pro Battery Replacement, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 15 Pro Battery Replacement, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 15 Pro Battery Replacement, Separate the bottom edge adhesive: step 8, image 3 of 3
      • Don't insert your opening pick deeper than 3 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    5. iPhone 15 Pro Battery Replacement, Heat the right edge: step 9, image 1 of 1
      • Heat the right edge of the screen until it's hot to the touch.
      Ask FixBot
    6. iPhone 15 Pro Battery Replacement, Position the opening pick: step 10, image 1 of 3 iPhone 15 Pro Battery Replacement, Position the opening pick: step 10, image 2 of 3 iPhone 15 Pro Battery Replacement, Position the opening pick: step 10, image 3 of 3
      • Don't insert your pick deeper than 5 mm along the right edge.
      • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
      • Rotate your pick so the flat edge is under the screen.
      Ask FixBot
    7. iPhone 15 Pro Battery Replacement, Release the right clip: step 11, image 1 of 3 iPhone 15 Pro Battery Replacement, Release the right clip: step 11, image 2 of 3 iPhone 15 Pro Battery Replacement, Release the right clip: step 11, image 3 of 3
      • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
      • Insert a second opening pick to the right of the first pick.
      Ask FixBot
    8. iPhone 15 Pro Battery Replacement, Separate the right edge adhesive: step 12, image 1 of 3 iPhone 15 Pro Battery Replacement, Separate the right edge adhesive: step 12, image 2 of 3 iPhone 15 Pro Battery Replacement, Separate the right edge adhesive: step 12, image 3 of 3
      • Slide the first pick back to the bottom right corner of the screen.
      • Slide the second pick to the top right corner of the screen to separate the adhesive.
      • Leave these picks inserted to prevent the adhesive from resealing.
      Ask FixBot
    9. iPhone 15 Pro Battery Replacement, Heat the top edge: step 13, image 1 of 1
      • Heat the top edge of the screen until it's hot to the touch.
      Ask FixBot
    10. iPhone 15 Pro Battery Replacement, Separate the top edge adhesive: step 14, image 1 of 3 iPhone 15 Pro Battery Replacement, Separate the top edge adhesive: step 14, image 2 of 3 iPhone 15 Pro Battery Replacement, Separate the top edge adhesive: step 14, image 3 of 3
      • Don't insert your pick deeper than 3 mm along the top edge.
      • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
      Ask FixBot
    11. iPhone 15 Pro Battery Replacement, Heat the left edge: step 15, image 1 of 1
      • Heat the left edge of the screen until it's hot to the touch.
      Ask FixBot
    12. iPhone 15 Pro Battery Replacement, Separate the left edge adhesive: step 16, image 1 of 3 iPhone 15 Pro Battery Replacement, Separate the left edge adhesive: step 16, image 2 of 3 iPhone 15 Pro Battery Replacement, Separate the left edge adhesive: step 16, image 3 of 3
      • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick to the bottom left corner of the screen to separate the adhesive.
      Ask FixBot
    1. iPhone 15 Pro Battery Replacement, Prop up the screen: step 17, image 1 of 3 iPhone 15 Pro Battery Replacement, Prop up the screen: step 17, image 2 of 3 iPhone 15 Pro Battery Replacement, Prop up the screen: step 17, image 3 of 3
      • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
      • Swing up the right edge of the screen like the front cover of a book.
      • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
      • Prop up the screen so you can access its cables without straining them.
      Ask FixBot
    2. iPhone 15 Pro Battery Replacement, Unfasten the logic board cover: step 18, image 1 of 2 iPhone 15 Pro Battery Replacement, Unfasten the logic board cover: step 18, image 2 of 2
      • Use a Y000 screwdriver to remove the six screws securing the logic board cover:
      • Four 1.6 mm‑long screws
      • Two 1.3 mm‑long screws
      Ask FixBot
    3. iPhone 15 Pro Battery Replacement, Remove the logic board cover: step 19, image 1 of 3 iPhone 15 Pro Battery Replacement, Remove the logic board cover: step 19, image 2 of 3 iPhone 15 Pro Battery Replacement, Remove the logic board cover: step 19, image 3 of 3
      • Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
      • During reassembly, make sure the top left corner of the cover goes under the ambient light sensor cable.
      Ask FixBot
    4. iPhone 15 Pro Battery Replacement, Disconnect the battery: step 20, image 1 of 3 iPhone 15 Pro Battery Replacement, Disconnect the battery: step 20, image 2 of 3 iPhone 15 Pro Battery Replacement, Disconnect the battery: step 20, image 3 of 3
      • Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
      Ask FixBot
    5. iPhone 15 Pro Battery Replacement, Disconnect the screen: step 21, image 1 of 2 iPhone 15 Pro Battery Replacement, Disconnect the screen: step 21, image 2 of 2
      • Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
      Ask FixBot
    6. iPhone 15 Pro Battery Replacement, Disconnect the ambient light sensor: step 22, image 1 of 2 iPhone 15 Pro Battery Replacement, Disconnect the ambient light sensor: step 22, image 2 of 2
      • Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
      • Lift the cable to disconnect it.
      Ask FixBot
    7. iPhone 15 Pro Battery Replacement, Remove the screen: step 23, image 1 of 2 iPhone 15 Pro Battery Replacement, Remove the screen: step 23, image 2 of 2
      • Remove the screen.
      • During reassembly, follow this guide to apply new adhesive and install your screen.
      • Be careful not to damage any of the spring contacts as you clean the frame.
      Ask FixBot
    1. iPhone 15 Pro Battery Replacement, Unfasten the loudspeaker: step 24, image 1 of 2 iPhone 15 Pro Battery Replacement, Unfasten the loudspeaker: step 24, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the four screws securing the loudspeaker:
      • One 2.7 mm‑long screw
      • Three 2 mm‑long screws
      Ask FixBot
    2. iPhone 15 Pro Battery Replacement, Remove the loudspeaker: step 25, image 1 of 3 iPhone 15 Pro Battery Replacement, Remove the loudspeaker: step 25, image 2 of 3 iPhone 15 Pro Battery Replacement, Remove the loudspeaker: step 25, image 3 of 3
      • A plastic buffer is adhered to the top edges of the loudspeaker and Taptic Engine.
      • Lift the bottom edge of the loudspeaker until you can grab it with your fingers.
      • Peel the loudspeaker from the plastic buffer on its top edge and remove it.
      Ask FixBot
    1. iPhone 15 Pro Battery Replacement, Disconnect the Taptic Engine: step 26, image 1 of 2 iPhone 15 Pro Battery Replacement, Disconnect the Taptic Engine: step 26, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the Taptic Engine press connector.
      Ask FixBot
    2. iPhone 15 Pro Battery Replacement, Unfasten the Taptic Engine: step 27, image 1 of 2 iPhone 15 Pro Battery Replacement, Unfasten the Taptic Engine: step 27, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the two 2 mm‑long screws securing the Taptic Engine.
      Ask FixBot
    3. iPhone 15 Pro Battery Replacement, Remove the Taptic Engine: step 28, image 1 of 1
      • Remove the Taptic Engine.
      Ask FixBot
    1. iPhone 15 Pro Battery Replacement, Adhesive information: step 29, image 1 of 1
      • Three sections of stretch release adhesive secure the battery to the frame—two along the bottom and one on top.
      • Each strip has a black pull tab at its end, which is lightly adhered to the edge of the battery.
      • In the following steps, you'll pull each tab out from underneath the battery.
      • The strips loosen when stretched, but might break off before you can fully remove them, especially the top edge strip. If any break, don't worry! Keep reading for an alternate way to remove the battery.
      Ask FixBot
    2. iPhone 15 Pro Battery Replacement, Separate the pull tabs: step 30, image 1 of 3 iPhone 15 Pro Battery Replacement, Separate the pull tabs: step 30, image 2 of 3 iPhone 15 Pro Battery Replacement, Separate the pull tabs: step 30, image 3 of 3
      Tool used on this step:
      Buy
      • Don't puncture or dent the battery with your tool, as it can leak dangerous chemicals or catch fire if damaged.
      • Use the tip of an opening pick to gently unstick an edge of an adhesive pull tab from the edge of the battery.
      • Use blunt nose tweezers to grip the edge of the pull tab and pull it completely off the edge of the battery.
      • Repeat for the other two pull tabs.
      Ask FixBot
    3. iPhone 15 Pro Battery Replacement, Remove the stretch release adhesive: step 31, image 1 of 3 iPhone 15 Pro Battery Replacement, Remove the stretch release adhesive: step 31, image 2 of 3 iPhone 15 Pro Battery Replacement, Remove the stretch release adhesive: step 31, image 3 of 3
      • Pull one of the pull tabs out from under the battery until you can grip it with your fingers or wrap it around your tool.
      • Hold the phone steady using the edges of the frame—don't press down on the battery.
      • Pull the strip slowly, evenly, and at a low angle without dragging on other components.
      • Continue pulling, re-gripping or wrapping it around your tool as you go, until the strip fully releases from under the battery.
      • If the strip breaks off, try to retrieve it. If you can't grip it from under the battery, move on to the next step.
      • Repeat this step for the other two strips.
      Ask FixBot
    4. iPhone 15 Pro Battery Replacement, Alternate method to remove the battery: step 32, image 1 of 2 iPhone 15 Pro Battery Replacement, Alternate method to remove the battery: step 32, image 2 of 2
      • If you removed all three stretch release adhesive strips, congratulations—you can now remove the battery! If not, follow the next two steps to separate the adhesive with isopropyl alcohol and a plastic card.
      • If the top strip remains, prop up the top edge of the phone.
      • If either of the bottom strips remain, prop up the left edge of the phone (the side with the volume buttons).
      • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the elevated edge of the battery.
      • Wait one minute for the isopropyl alcohol to flow under the battery and soften the adhesive.
      Ask FixBot
    5. iPhone 15 Pro Battery Replacement, Pry up the battery: step 33, image 1 of 3 iPhone 15 Pro Battery Replacement, Pry up the battery: step 33, image 2 of 3 iPhone 15 Pro Battery Replacement, Pry up the battery: step 33, image 3 of 3
      Plastic Cards
      $2.99
      Buy
      • Don't bend or crease your battery. If the adhesive feels stubborn, apply a few more drops of isopropyl alcohol and try again.
      • Insert the short edge of a plastic card between the bottom edge of the battery and the frame.
      • Be careful not to scrape the frame underneath the battery—the wireless charging coil is exposed near the center.
      • Gently pry up the battery until the adhesive fully separates.
      • Depending on how strong your adhesive is, this may take some time. Allow up to a minute of constant pressure for the adhesive to loosen.
      Ask FixBot
    6. iPhone 15 Pro Battery Replacement, Remove the battery: step 34, image 1 of 2 iPhone 15 Pro Battery Replacement, Remove the battery: step 34, image 2 of 2
      • Remove the battery.
      Ask FixBot
    1. iPhone 15 Pro Battery Replacement, Disassembly complete: step 35, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps show how to reassemble the iPhone.
      Ask FixBot
    1. iPhone 15 Pro Battery Replacement, Clean the frame: step 36, image 1 of 3 iPhone 15 Pro Battery Replacement, Clean the frame: step 36, image 2 of 3 iPhone 15 Pro Battery Replacement, Clean the frame: step 36, image 3 of 3
      • Use cotton swabs or a lint‑free cloth and high‑concentration (>90%) isopropyl alcohol to wipe off any battery adhesive residue from the iPhone's frame.
      Ask FixBot
    2. iPhone 15 Pro Battery Replacement, Remove the adhesive liner: step 37, image 1 of 3 iPhone 15 Pro Battery Replacement, Remove the adhesive liner: step 37, image 2 of 3 iPhone 15 Pro Battery Replacement, Remove the adhesive liner: step 37, image 3 of 3
      • Peel the liner off the battery adhesive, pictured here in pink.
      • If the battery has a liner on the top of the battery, pictured here in blue, leave it in place for now.
      Ask FixBot
    3. iPhone 15 Pro Battery Replacement, Connect the battery: step 38, image 1 of 2 iPhone 15 Pro Battery Replacement, Connect the battery: step 38, image 2 of 2
      • Hold the battery over its place in the iPhone, but don't lower it into place yet.
      • Use your finger or a spudger to connect the battery press connector.
      • This will ensure the battery is properly aligned.
      Ask FixBot
    4. iPhone 15 Pro Battery Replacement, Place the battery: step 39, image 1 of 3 iPhone 15 Pro Battery Replacement, Place the battery: step 39, image 2 of 3 iPhone 15 Pro Battery Replacement, Place the battery: step 39, image 3 of 3
      • The battery adhesive is very sticky! Be careful as you align the battery in its recess—once it sticks, you won't be able to realign it.
      • Push the battery towards the top of the iPhone so the battery cable is pressed against it, then lay it into its recess.
      Ask FixBot
    5. iPhone 15 Pro Battery Replacement, Press the battery: step 40, image 1 of 2 iPhone 15 Pro Battery Replacement, Press the battery: step 40, image 2 of 2
      • Use your fingers to press the battery into place.
      Ask FixBot
    6. iPhone 15 Pro Battery Replacement, Remove the battery liner: step 41, image 1 of 3 iPhone 15 Pro Battery Replacement, Remove the battery liner: step 41, image 2 of 3 iPhone 15 Pro Battery Replacement, Remove the battery liner: step 41, image 3 of 3
      • Remove the protective cover off the top of the battery (if present).
      Ask FixBot
    7. iPhone 15 Pro Battery Replacement, Disconnect the battery: step 42, image 1 of 2 iPhone 15 Pro Battery Replacement, Disconnect the battery: step 42, image 2 of 2
      • Use the point of a spudger or opening pick to pry up and disconnect the battery press connector.
      Ask FixBot
    8. iPhone 15 Pro Battery Replacement, Install the Taptic Engine: step 43, image 1 of 3 iPhone 15 Pro Battery Replacement, Install the Taptic Engine: step 43, image 2 of 3 iPhone 15 Pro Battery Replacement, Install the Taptic Engine: step 43, image 3 of 3
      • Place the Taptic Engine into its recess in the frame.
      Ask FixBot
    9. iPhone 15 Pro Battery Replacement: step 44, image 1 of 1
      • Use a Phillips #000 screwdriver to install the two 2 mm‑long screws securing the Taptic Engine.
      Ask FixBot
    10. iPhone 15 Pro Battery Replacement, Connect the Taptic Engine: step 45, image 1 of 2 iPhone 15 Pro Battery Replacement, Connect the Taptic Engine: step 45, image 2 of 2
      • Use the flat end of a spudger to connect the Taptic Engine press connector.
      Ask FixBot
    11. iPhone 15 Pro Battery Replacement, Install the loudspeaker: step 46, image 1 of 3 iPhone 15 Pro Battery Replacement, Install the loudspeaker: step 46, image 2 of 3 iPhone 15 Pro Battery Replacement, Install the loudspeaker: step 46, image 3 of 3
      • Place the loudspeaker into its recess in the frame.
      Ask FixBot
    12. iPhone 15 Pro Battery Replacement: step 47, image 1 of 1
      • Use a Phillips #000 screwdriver to install the four screws securing the loudspeaker:
      Ask FixBot
    1. iPhone 15 Pro Battery Replacement, Remove the screen adhesive: step 48, image 1 of 3 iPhone 15 Pro Battery Replacement, Remove the screen adhesive: step 48, image 2 of 3 iPhone 15 Pro Battery Replacement, Remove the screen adhesive: step 48, image 3 of 3
      • The adhesive remaining on the phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
      • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
      • Use a pair of tweezers, or your fingers, to remove the adhesive around the entire perimeter of the iPhone.
      Ask FixBot
    2. iPhone 15 Pro Battery Replacement: step 49, image 1 of 3 iPhone 15 Pro Battery Replacement: step 49, image 2 of 3 iPhone 15 Pro Battery Replacement: step 49, image 3 of 3
      • Any unevenness will compromise the iPhone's seal. Clean the frame thoroughly.
      • Apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to a cotton swab or lint-free cloth.
      • Wipe along the perimeter of the frame to clean the adhesive residue.
      • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
      Ask FixBot
    3. iPhone 15 Pro Battery Replacement, Orient the adhesive: step 50, image 1 of 1
      • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to orient it correctly.
      Ask FixBot
    4. iPhone 15 Pro Battery Replacement, Apply the adhesive: step 51, image 1 of 3 iPhone 15 Pro Battery Replacement, Apply the adhesive: step 51, image 2 of 3 iPhone 15 Pro Battery Replacement, Apply the adhesive: step 51, image 3 of 3
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but don't remove it all the way.
      • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
      • When the adhesive is aligned, set it down along the bottom edge.
      Ask FixBot
    5. iPhone 15 Pro Battery Replacement: step 52, image 1 of 3 iPhone 15 Pro Battery Replacement: step 52, image 2 of 3 iPhone 15 Pro Battery Replacement: step 52, image 3 of 3
      • Continue peeling the back liner off of the adhesive while setting the adhesive into place along the edges of the iPhone's frame.
      • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
      • If you don't have another one handy, it's okay to put your iPhone back together without adhesive, but keep in mind that it won't be water resistant until you install new adhesive.
      Ask FixBot
    6. iPhone 15 Pro Battery Replacement, Press the adhesive into place: step 53, image 1 of 3 iPhone 15 Pro Battery Replacement, Press the adhesive into place: step 53, image 2 of 3 iPhone 15 Pro Battery Replacement, Press the adhesive into place: step 53, image 3 of 3
      • Use the flat end of a spudger to press the adhesive into place all around the iPhone.
      • Be careful not to press on the camera, spring contacts, or other internal components.
      Ask FixBot
    7. iPhone 15 Pro Battery Replacement, Remove the top liner: step 54, image 1 of 2 iPhone 15 Pro Battery Replacement, Remove the top liner: step 54, image 2 of 2
      • Lift the pull tab in the top‑right corner of the frame to peel off the top liner and remove it.
      • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners along the edges.
      Ask FixBot
    8. iPhone 15 Pro Battery Replacement, Adhesive information: step 55, image 1 of 1
      • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
      • Your pull tabs may be in different positions.
      • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. Be careful not to touch anything to the exposed adhesive.
      Ask FixBot
    9. iPhone 15 Pro Battery Replacement, Prop up the screen: step 56, image 1 of 1
      • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
      Ask FixBot
    10. iPhone 15 Pro Battery Replacement, Connect the screen and ambient light sensor: step 57, image 1 of 3 iPhone 15 Pro Battery Replacement, Connect the screen and ambient light sensor: step 57, image 2 of 3 iPhone 15 Pro Battery Replacement, Connect the screen and ambient light sensor: step 57, image 3 of 3
      • Use your finger or the flat end of a spudger to connect the screen and ambient light sensor press connectors.
      Ask FixBot
    11. iPhone 15 Pro Battery Replacement, Connect the battery: step 58, image 1 of 2 iPhone 15 Pro Battery Replacement, Connect the battery: step 58, image 2 of 2
      • Use your finger or the flat end of a spudger to connect the battery press connector.
      Ask FixBot
    12. iPhone 15 Pro Battery Replacement, Install the logic board cover: step 59, image 1 of 3 iPhone 15 Pro Battery Replacement, Install the logic board cover: step 59, image 2 of 3 iPhone 15 Pro Battery Replacement, Install the logic board cover: step 59, image 3 of 3
      Ask FixBot
    13. iPhone 15 Pro Battery Replacement, Fasten the logic board cover: step 60, image 1 of 1
      • Use a Y000 screwdriver to install the six screws securing the logic board cover:
      Ask FixBot
    14. iPhone 15 Pro Battery Replacement, Remove the final adhesive liners: step 61, image 1 of 3 iPhone 15 Pro Battery Replacement, Remove the final adhesive liners: step 61, image 2 of 3 iPhone 15 Pro Battery Replacement, Remove the final adhesive liners: step 61, image 3 of 3
      • Once you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing accidentally sticks to it.
      • Use tweezers to remove the two narrow liners covering the adhesive along the right, top, and bottom edges of the frame.
      Ask FixBot
    15. iPhone 15 Pro Battery Replacement: step 62, image 1 of 2 iPhone 15 Pro Battery Replacement: step 62, image 2 of 2
      • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the frame.
      • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the frame.
      Ask FixBot
    16. iPhone 15 Pro Battery Replacement, Place the screen: step 63, image 1 of 3 iPhone 15 Pro Battery Replacement, Place the screen: step 63, image 2 of 3 iPhone 15 Pro Battery Replacement, Place the screen: step 63, image 3 of 3
      • Align the screen over the frame, then lower it into place.
      Ask FixBot
    17. iPhone 15 Pro Battery Replacement, Press the screen: step 64, image 1 of 2 iPhone 15 Pro Battery Replacement, Press the screen: step 64, image 2 of 2
      • Firmly press along the edges of the screen to engage the clips and compress the adhesive.
      Ask FixBot
    18. iPhone 15 Pro Battery Replacement, Install the pentalobe screws: step 65, image 1 of 1
      • Use a P2 pentalobe screwdriver to install the two 7 mm‑long screws on either side of the charging port.
      Ask FixBot
    19. iPhone 15 Pro Battery Replacement, Heat the screen: step 66, image 1 of 2 iPhone 15 Pro Battery Replacement, Heat the screen: step 66, image 2 of 2
      • To help the adhesive bond, apply heat to the edges of the screen using a hair dryer or heat gun until it's hot to the touch.
      • If you have screen vise clamps, use them to strengthen the bond of the new adhesive. If not, keep reading for more ways to secure the screen.
      Ask FixBot
    1. iPhone 15 Pro Battery Replacement, Press the back glass: step 67, image 1 of 3 iPhone 15 Pro Battery Replacement, Press the back glass: step 67, image 2 of 3 iPhone 15 Pro Battery Replacement, Press the back glass: step 67, image 3 of 3
      • To evenly compress the iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
      • If you have the iPhone's original box, take the lid and place it on a flat surface.
      • If you don't have the original box, skip this step for an alternate method.
      • Place the iPhone screen-side-up in the lid of the box with the camera bump in its recess.
      • Find something close to the size of the iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
      • Leave the objects in place for at least thirty minutes, ideally overnight.
      Ask FixBot
    2. iPhone 15 Pro Battery Replacement: step 68, image 1 of 3 iPhone 15 Pro Battery Replacement: step 68, image 2 of 3 iPhone 15 Pro Battery Replacement: step 68, image 3 of 3
      • If you don't have the iPhone's original box, follow the these two steps for another method to evenly compress the screen.
      • Place the iPhone screen-side-down on a soft, flat surface.
      • Apply tape to the back glass to protect its finish.
      • Place three layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
      Ask FixBot
    3. iPhone 15 Pro Battery Replacement: step 69, image 1 of 1
      • Stack multiple books or other heavy objects on your iPhone.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      Ask FixBot
Congratulations on replacing the battery!
Depending on the replacement part, you may be able to pair it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
For optimal performance, calibrate your newly installed battery after completing this guide.
46 other people completed this guide.
Author
with
Spencer Day
210,806 Reputation
1,265 Guides authored
12 Guide Comments
Very detailed
Isaiah Ayers - Reply Share
Exelente tutorial , gracias
Miguel Rincon - Reply Share
the hardest part of this repair was definitely removing the old glue, it made me lose my mind, the rest was easy
Carlo Bückert - Reply Share
What’s your advice on the best way to keep track of the screws as they’re being removed so they don’t get mixed up or lost before they’re put back into the phone?
Monika Radcliff - Reply Share
@monikaradcliff i would put them on magnets which i will do later today.
Franek B - Reply Share
Past 24 Hours: 398
Past 7 Days: 2,788
Past 30 Days: 12,218
All Time: 202,207
