Up to 20% off select tools
iPhone 14 Battery Replacement
Views: 296K
View statistics:
Past 24 Hours:
394
Past 7 Days:
2,720
Past 30 Days:
11,082
All Time:
296,353
Comments: 52
38 comments on steps, 14 guide comments.
Go to guide comments
Completed: 70
70 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a worn-out or dead battery in your iPhone 14.
iPhone batteries are rated to hold 80% of their capacity for up to 500 charge cycles, which lasts roughly 18-24 months for most users. After that, your iPhone may need to be charged far more frequently, and iOS may warn you that performance is affected (in other words, your phone will run slower).
This guide was created using the A2882 (international) model. If you're fixing a different iPhone 14 model, there may be some visual discrepancies, but the procedure should be the same.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Note: On iOS 17.6 and earlier, your iPhone may display a warning about the “genuineness” of the battery after the repair, even when using original Apple parts. If your iPhone functions normally, you can safely ignore the warning. On iOS 18 and newer, calibrate authentic Apple batteries using Repair Assistant.
You’ll need replacement adhesive to reattach the battery and the screen when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
    1. iPhone 14 Battery Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone 14 Battery Replacement, Remove the pentalobe screws: step 1, image 2 of 2
      • Power off your iPhone before beginning disassembly.
      • Use a P2 pentalobe screwdriver to remove the two 6.8 mm‑long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 14 Battery Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 14 Battery Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 14 Battery Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 14 Battery Replacement, Tape over any cracks: step 3, image 1 of 2 iPhone 14 Battery Replacement, Tape over any cracks: step 3, image 2 of 2
      • If your iPhone has a cracked rear glass, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
      • If all else fails, you can superglue the suction cup to the rear glass.
      Ask FixBot
    2. iPhone 14 Battery Replacement, Heat the bottom edge: step 4, image 1 of 1
      • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the rear glass is slightly too hot to touch.
      • Never leave your heat gun in one spot for an extended period of time.
      Ask FixBot
    3. iPhone 14 Battery Replacement, Insert an opening pick: step 5, image 1 of 3 iPhone 14 Battery Replacement, Insert an opening pick: step 5, image 2 of 3 iPhone 14 Battery Replacement, Insert an opening pick: step 5, image 3 of 3
      • Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
      • Insert an opening pick into the gap.
      • The adhesive holding the rear glass in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the rear glass up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
      Ask FixBot
    4. iPhone 14 Battery Replacement, Heat the left edge: step 6, image 1 of 1
      • Heat the left edge of the iPhone until the rear glass is slightly too hot to touch.
      Ask FixBot
    5. iPhone 14 Battery Replacement, Slice the left edge adhesive: step 7, image 1 of 3 iPhone 14 Battery Replacement, Slice the left edge adhesive: step 7, image 2 of 3 iPhone 14 Battery Replacement, Slice the left edge adhesive: step 7, image 3 of 3
      • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      Ask FixBot
    6. iPhone 14 Battery Replacement, Rear glass information: step 8, image 1 of 1
      • There's a delicate cable along the right edge, next to the volume up button. Don't insert your pick here, as you may damage the cable.
      Ask FixBot
    7. iPhone 14 Battery Replacement, Heat the right edge: step 9, image 1 of 1
      • Heat the right edge of the iPhone (the edge with the volume buttons) until the rear glass is slightly too hot to touch.
      Ask FixBot
    8. iPhone 14 Battery Replacement, Slice the right edge adhesive: step 10, image 1 of 3 iPhone 14 Battery Replacement, Slice the right edge adhesive: step 10, image 2 of 3 iPhone 14 Battery Replacement, Slice the right edge adhesive: step 10, image 3 of 3
      • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the charging coil cable.
      Ask FixBot
    9. iPhone 14 Battery Replacement, Heat the top edge: step 11, image 1 of 1
      • Heat the top edge of the iPhone until the rear glass is slightly too hot to touch.
      Ask FixBot
    10. iPhone 14 Battery Replacement, Slice the top edge adhesive: step 12, image 1 of 3 iPhone 14 Battery Replacement, Slice the top edge adhesive: step 12, image 2 of 3 iPhone 14 Battery Replacement, Slice the top edge adhesive: step 12, image 3 of 3
      • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
      Ask FixBot
    11. iPhone 14 Battery Replacement: step 13, image 1 of 3 iPhone 14 Battery Replacement: step 13, image 2 of 3 iPhone 14 Battery Replacement: step 13, image 3 of 3
      • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
      • Don't insert the pick more than 3 mm, as you may damage or smear the camera array.
      • Don't try to fully separate the rear glass yet, as a fragile ribbon cable still connects it to the iPhone's logic board.
      Ask FixBot
    12. iPhone 14 Battery Replacement, Open the iPhone: step 14, image 1 of 3 iPhone 14 Battery Replacement, Open the iPhone: step 14, image 2 of 3 iPhone 14 Battery Replacement, Open the iPhone: step 14, image 3 of 3
      • Remove your suction handle from the rear glass.
      • Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
      • Be careful not to strain the short charging coil flex cable.
      • Lean the rear glass against something to keep it propped up while you're working on the phone.
      • If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
      • During reassembly, lay the rear glass in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the rear glass and make sure they aren't bent.
      Ask FixBot
    13. iPhone 14 Battery Replacement, Unfasten the battery connector cover screws: step 15, image 1 of 2 iPhone 14 Battery Replacement, Unfasten the battery connector cover screws: step 15, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Ask FixBot
    14. iPhone 14 Battery Replacement, Remove the battery connector cover: step 16, image 1 of 3 iPhone 14 Battery Replacement, Remove the battery connector cover: step 16, image 2 of 3 iPhone 14 Battery Replacement, Remove the battery connector cover: step 16, image 3 of 3
      Buy
      • Grasp the battery connector cover with a pair of tweezers and slide it upwards (towards the A15 print) to unlatch the top hook.
      • Remove the battery connector cover.
      Ask FixBot
    15. iPhone 14 Battery Replacement, Disconnect the battery: step 17, image 1 of 2 iPhone 14 Battery Replacement, Disconnect the battery: step 17, image 2 of 2
      • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Ask FixBot
    16. iPhone 14 Battery Replacement, Unfasten the charging coil connector cover screw: step 18, image 1 of 2 iPhone 14 Battery Replacement, Unfasten the charging coil connector cover screw: step 18, image 2 of 2
      • Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
      Ask FixBot
    17. iPhone 14 Battery Replacement, Remove the charging coil connector bracket: step 19, image 1 of 2 iPhone 14 Battery Replacement, Remove the charging coil connector bracket: step 19, image 2 of 2
      • Use a pair of tweezers to remove the charging coil connector cover.
      Ask FixBot
    18. iPhone 14 Battery Replacement, Disconnect the charging coil: step 20, image 1 of 2 iPhone 14 Battery Replacement, Disconnect the charging coil: step 20, image 2 of 2
      • Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
      Ask FixBot
    19. iPhone 14 Battery Replacement, Remove the rear glass assembly: step 21, image 1 of 2 iPhone 14 Battery Replacement, Remove the rear glass assembly: step 21, image 2 of 2
      • Remove the rear glass assembly.
      • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • During reassembly, pause here if you wish to replace the rear glass adhesives.
      Ask FixBot
    1. iPhone 14 Battery Replacement, Locate the adhesive pull-tabs: step 22, image 1 of 1
      • Two stretch adhesive strips secure the battery to the case. They're both accessed from the top edge of the battery.
      • Each adhesive strip has a black pull-tab at the end, which is lightly adhered to the edge of the battery.
      • In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. These "command-strip" style adhesives lose their stick when stretched, so you can remove the battery with ease.
      • If the strips break, don't panic! They don't always work as intended. Keep reading for tips on removing broken strips.
      Ask FixBot
    2. iPhone 14 Battery Replacement, Remove the stretch-release adhesive: step 23, image 1 of 3 iPhone 14 Battery Replacement, Remove the stretch-release adhesive: step 23, image 2 of 3 iPhone 14 Battery Replacement, Remove the stretch-release adhesive: step 23, image 3 of 3
      Buy
      • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
      • Use a pair of blunt-nosed tweezers to peel up the two battery adhesive pull-tabs along the top edge of the battery.
      Ask FixBot
    3. iPhone 14 Battery Replacement: step 24, image 1 of 3 iPhone 14 Battery Replacement: step 24, image 2 of 3 iPhone 14 Battery Replacement: step 24, image 3 of 3
      • Grab the first pull-tab with your fingers or wrap it around a spudger and slowly pull it away from the battery, toward the top of the iPhone.
      • Pull out hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
      • Don't press down on the battery but hold the iPhone firmly by its sides.
      • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
      • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
      • If any of the adhesive strips break off underneath the battery and can't be retrieved, try to remove the other strip, and then proceed as instructed below.
      Ask FixBot
    4. iPhone 14 Battery Replacement: step 25, image 1 of 3 iPhone 14 Battery Replacement: step 25, image 2 of 3 iPhone 14 Battery Replacement: step 25, image 3 of 3
      • Grab the second pull-tab with your fingers or the center of a spudger and pull it away from the battery, toward the top of the iPhone.
      • Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
      • If the adhesive breaks off underneath the battery and can't be retrieved, continue with the next step.
      Ask FixBot
    5. iPhone 14 Battery Replacement, How to remove a stuck battery: step 26, image 1 of 3 iPhone 14 Battery Replacement, How to remove a stuck battery: step 26, image 2 of 3 iPhone 14 Battery Replacement, How to remove a stuck battery: step 26, image 3 of 3
      • If you're still having trouble removing the battery, apply a few drops of high concentration (90% or higher) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
      • Wait about one minute for the alcohol solution to weaken the adhesive.
      • Use an opening pick or the flat end of a spudger to gently lift the battery.
      • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
      Ask FixBot
    6. iPhone 14 Battery Replacement, Remove the battery: step 27, image 1 of 2 iPhone 14 Battery Replacement, Remove the battery: step 27, image 2 of 2
      • Remove the battery.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • If there's any alcohol solution remaining in the phone, carefully wipe it off before installing your new battery.
      • If your new battery didn't come with adhesive preinstalled, refer to this guide for help replacing the adhesive strips.
      • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
70 other people completed this guide.
Author
with
Tobias Isakeit
136,837 Reputation
189 Guides authored
14 Guide Comments
Salut.
Je veux savoir plus de cette formation dépannage.
cfas fix - Reply Share
this is iPhone 14, title error, not iPhone 14 Pro
Wells Zhang - Reply Share
I think this guide is wrong -- my iPhone 14 has a metal plate inside, covering the battery. The iPhone 14 screen replacement guide appears to be correct, though.
Olivia Farmen - Reply Share
U must go to trainning first
bakri hamid - Reply Share
U must going to technical training first
Past 24 Hours: 394
Past 7 Days: 2,720
Past 30 Days: 11,082
All Time: 296,353
