Up to 20% off select tools
iPhone 16 Battery Replacement
Views: 74K
View statistics:
Past 24 Hours:
118
Past 7 Days:
1,017
Past 30 Days:
4,642
All Time:
73,877
Comments: 36
31 comments on steps, 5 guide comments.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the battery in your iPhone 16.
iPhone batteries are rated to hold 80% of their capacity for up to 500 charge cycles, or roughly 18–24 months. If your iPhone needs to be charged more often or runs slower, it might be time to replace the battery.
This iPhone and the iPhone 16 Plus use a battery adhesive that requires an electrical charge to loosen it. Apple's repair manual recommends connecting a 9V battery for 90 seconds, but you can use a power supply or a power bank at a 5–20V output instead—the time required to loosen the adhesive will vary.
The guide uses the VoltClip along with the FixHub Portable Power Station to release the adhesive. If you're using a different method, follow the guide normally and supplement your power source's operating procedures during the necessary steps.
After completing this repair, you may receive warnings about your replacement part and lose access to battery health data, but your new battery will otherwise work normally. As of iOS 18.1, battery health works with both genuine and aftermarket replacement batteries. Run Repair Assistant to reset the battery metrics.
    1. iPhone 16 Battery Replacement, Before you begin: step 1, image 1 of 2 iPhone 16 Battery Replacement, Before you begin: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Ask FixBot
    2. iPhone 16 Battery Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 16 Battery Replacement, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    3. iPhone 16 Battery Replacement, Remove the pentalobe screws: step 3, image 1 of 2 iPhone 16 Battery Replacement, Remove the pentalobe screws: step 3, image 2 of 2
      • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 16 Battery Replacement, Mark your opening picks: step 4, image 1 of 3 iPhone 16 Battery Replacement, Mark your opening picks: step 4, image 2 of 3 iPhone 16 Battery Replacement, Mark your opening picks: step 4, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 16 Battery Replacement, Heat the bottom edge: step 5, image 1 of 1
      Tool used on this step:
      iOpener
      $14.95
      Buy
      • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
      • You can also use an iOpener to heat the back glass. Follow these instructions to heat and apply the iOpener properly.
      Ask FixBot
    2. iPhone 16 Battery Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 16 Battery Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 16 Battery Replacement, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the back glass.
      • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    3. iPhone 16 Battery Replacement, Back glass information: step 7, image 1 of 1
      • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
      • A delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
      • Multiple spring contacts around the perimeter of the phone.
      Ask FixBot
    4. iPhone 16 Battery Replacement, Heat the right edge: step 8, image 1 of 1
      • Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
      Ask FixBot
    5. iPhone 16 Battery Replacement, Separate the bottom right adhesive: step 9, image 1 of 3 iPhone 16 Battery Replacement, Separate the bottom right adhesive: step 9, image 2 of 3 iPhone 16 Battery Replacement, Separate the bottom right adhesive: step 9, image 3 of 3
      • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
      • Slide your pick around the bottom right corner and to the volume down button to separate the adhesive and release the metal clip.
      • Don't slide past the volume buttons to avoid damaging the wireless charging cable.
      • You'll hear and feel the metal clip release as you pass it.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    6. iPhone 16 Battery Replacement, Heat the left edge: step 10, image 1 of 1
      • Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
      Ask FixBot
    7. iPhone 16 Battery Replacement, Separate the left adhesive: step 11, image 1 of 3 iPhone 16 Battery Replacement, Separate the left adhesive: step 11, image 2 of 3 iPhone 16 Battery Replacement, Separate the left adhesive: step 11, image 3 of 3
      • Insert a second opening pick at the bottom edge.
      • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
      • You'll hear and feel the metal clips release as you pass them.
      • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    8. iPhone 16 Battery Replacement, Heat the top edge: step 12, image 1 of 1
      • Use a hair dryer or heat gun to heat the top edge of the back glass until it's hot to the touch.
      Ask FixBot
    9. iPhone 16 Battery Replacement, Separate the top right adhesive: step 13, image 1 of 3 iPhone 16 Battery Replacement, Separate the top right adhesive: step 13, image 2 of 3 iPhone 16 Battery Replacement, Separate the top right adhesive: step 13, image 3 of 3
      • Slide your second opening pick around the top left corner and along the top edge to separate the adhesive and release the metal clips.
      • Continue sliding your pick around the top right corner until you reach the Action button.
      Ask FixBot
    10. iPhone 16 Battery Replacement, Reposition the back glass: step 14, image 1 of 3 iPhone 16 Battery Replacement, Reposition the back glass: step 14, image 2 of 3 iPhone 16 Battery Replacement, Reposition the back glass: step 14, image 3 of 3
      • At this point, the back glass should be free from the frame. If the back glass feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
      • Swing open the back glass to the right of the phone to separate the remaining adhesive.
      • Support the back glass with a clean, sturdy object.
      • Remove the opening picks before continuing.
      Ask FixBot
    11. iPhone 16 Battery Replacement, Remove the middle connector cover screws: step 15, image 1 of 2 iPhone 16 Battery Replacement, Remove the middle connector cover screws: step 15, image 2 of 2
      • Use a tri-point Y000 driver to remove the two 1 mm‑long screws securing the middle connector cover.
      Ask FixBot
    12. iPhone 16 Battery Replacement, Remove the middle connector cover: step 16, image 1 of 3 iPhone 16 Battery Replacement, Remove the middle connector cover: step 16, image 2 of 3 iPhone 16 Battery Replacement, Remove the middle connector cover: step 16, image 3 of 3
      • Insert the point of a spudger in either cutout on the middle connector cover.
      • Slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
      • Remove the cover.
      Ask FixBot
    13. iPhone 16 Battery Replacement, Disconnect the battery: step 17, image 1 of 2 iPhone 16 Battery Replacement, Disconnect the battery: step 17, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    14. iPhone 16 Battery Replacement, Disconnect the wireless charging coil: step 18, image 1 of 2 iPhone 16 Battery Replacement, Disconnect the wireless charging coil: step 18, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
      Ask FixBot
    15. iPhone 16 Battery Replacement, Remove the back glass: step 19, image 1 of 1
      • Lift the back glass off the frame and remove it.
      Ask FixBot
    1. iPhone 16 Battery Replacement, Separate the silver tab: step 20, image 1 of 2 iPhone 16 Battery Replacement, Separate the silver tab: step 20, image 2 of 2
      • Use an opening pick, or a clean fingernail, to peel up the silver tab at the bottom edge of the battery.
      Ask FixBot
    2. iPhone 16 Battery Replacement, Assemble the VoltClip: step 21, image 1 of 2 iPhone 16 Battery Replacement, Assemble the VoltClip: step 21, image 2 of 2
      • Plug the VoltClip's barrel connector into the USB-C elbow.
      • Don't connect the VoltClip to a power source just yet. The loose alligator clips may accidentally touch each other and cause an electrical short.
      Ask FixBot
    3. iPhone 16 Battery Replacement, Attach the alligator clips: step 22, image 1 of 2 iPhone 16 Battery Replacement, Attach the alligator clips: step 22, image 2 of 2
      • Attach the red alligator clip to the silver tab.
      Ask FixBot
    4. iPhone 16 Battery Replacement: step 23, image 1 of 3 iPhone 16 Battery Replacement: step 23, image 2 of 3 iPhone 16 Battery Replacement: step 23, image 3 of 3
      • Attach the black alligator clip to the grounding screw.
      Ask FixBot
    5. iPhone 16 Battery Replacement, Connect power to the VoltClip: step 24, image 1 of 3 iPhone 16 Battery Replacement, Connect power to the VoltClip: step 24, image 2 of 3 iPhone 16 Battery Replacement, Connect power to the VoltClip: step 24, image 3 of 3
      • Make sure the red alligator clip isn't touching any stray metallic surfaces.
      • Connect a powered USB-C cable to the USB-C elbow and wait 90 seconds for the adhesive to loosen.
      Ask FixBot
    6. iPhone 16 Battery Replacement, Disconnect the VoltClip: step 25, image 1 of 3 iPhone 16 Battery Replacement, Disconnect the VoltClip: step 25, image 2 of 3 iPhone 16 Battery Replacement, Disconnect the VoltClip: step 25, image 3 of 3
      • Disconnect the USB-C cable from the elbow, then disconnect the alligator clips.
      Ask FixBot
    7. iPhone 16 Battery Replacement, Remove the battery: step 26, image 1 of 3 iPhone 16 Battery Replacement, Remove the battery: step 26, image 2 of 3 iPhone 16 Battery Replacement, Remove the battery: step 26, image 3 of 3
      • Your adhesive should be fully loosened at this point. If your battery doesn't budge during the step, reconnect the alligator clips for an additional minute and try again.
      • Grip the silver tab and lift the battery out of the frame.
      • Alternatively, you can use a suction handle to pull the battery out. If the battery doesn't come out easily, don't force it—repeat the previous step.
      Ask FixBot
    1. iPhone 16 Battery Replacement, End of disassembly: step 27, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
      • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    1. iPhone 16 Battery Replacement, Remove residual battery adhesive: step 28, image 1 of 2 iPhone 16 Battery Replacement, Remove residual battery adhesive: step 28, image 2 of 2
      • Use a pair of tweezers to peel up any large pieces of residual battery adhesive from the iPhone frame.
      Ask FixBot
    2. iPhone 16 Battery Replacement, Remove adhesive residue: step 29, image 1 of 2 iPhone 16 Battery Replacement, Remove adhesive residue: step 29, image 2 of 2
      • Use coffee filters or a lint‑free cloth and high‑concentration (>90%) isopropyl alcohol to wipe off any remaining battery adhesive residue from the iPhone frame.
      Ask FixBot
    3. iPhone 16 Battery Replacement, Remove the top battery‑side liner: step 30, image 1 of 3 iPhone 16 Battery Replacement, Remove the top battery‑side liner: step 30, image 2 of 3 iPhone 16 Battery Replacement, Remove the top battery‑side liner: step 30, image 3 of 3
      • If your battery came with the adhesive installed, skip this step and the next four steps.
      • Lay the old battery with the adhesive facing up next to the new battery. Lay the new adhesive on the new battery to see how it needs to be applied.
      • Your adhesive may look slightly different or have different liners.
      • If the battery‑side of your adhesive has two liners, remove the top liner.
      • If the battery‑side of your adhesive has one liner, remove it.
      Ask FixBot
    4. iPhone 16 Battery Replacement, Apply the top of the adhesive: step 31, image 1 of 3 iPhone 16 Battery Replacement, Apply the top of the adhesive: step 31, image 2 of 3 iPhone 16 Battery Replacement, Apply the top of the adhesive: step 31, image 3 of 3
      • With the old battery nearby so you can align the new adhesive correctly, use your finger to lightly press the new adhesive to the new battery.
      • Compare the placement of the new adhesive with the old adhesive.
      • If you need to adjust it, you can carefully peel the adhesive up and try again.
      • Once the new adhesive is aligned correctly and matches the old adhesive, press it firmly to the battery.
      Ask FixBot
    5. iPhone 16 Battery Replacement, Remove the bottom battery‑side liner: step 32, image 1 of 3 iPhone 16 Battery Replacement, Remove the bottom battery‑side liner: step 32, image 2 of 3 iPhone 16 Battery Replacement, Remove the bottom battery‑side liner: step 32, image 3 of 3
      • If the battery‑side of your adhesive still has a bottom liner on it, remove it now.
      Ask FixBot
    6. iPhone 16 Battery Replacement, Press the adhesive: step 33, image 1 of 3 iPhone 16 Battery Replacement, Press the adhesive: step 33, image 2 of 3 iPhone 16 Battery Replacement, Press the adhesive: step 33, image 3 of 3
      • Lay the adhesive onto the battery and press it into place.
      Ask FixBot
    7. iPhone 16 Battery Replacement, Fold the conductive tab: step 34, image 1 of 3 iPhone 16 Battery Replacement, Fold the conductive tab: step 34, image 2 of 3 iPhone 16 Battery Replacement, Fold the conductive tab: step 34, image 3 of 3
      • Use your finger to fold the conductive tab around to the front of the battery and press it into place.
      Ask FixBot
    8. iPhone 16 Battery Replacement, Remove the iPhone‑side liner: step 35, image 1 of 3 iPhone 16 Battery Replacement, Remove the iPhone‑side liner: step 35, image 2 of 3 iPhone 16 Battery Replacement, Remove the iPhone‑side liner: step 35, image 3 of 3
      • Peel the iPhone‑side liner off of the battery adhesive.
      Ask FixBot
    9. iPhone 16 Battery Replacement, Connect the battery: step 36, image 1 of 3 iPhone 16 Battery Replacement, Connect the battery: step 36, image 2 of 3 iPhone 16 Battery Replacement, Connect the battery: step 36, image 3 of 3
      • Hold the battery over its place in the iPhone, but don't lower it into place yet.
      • To ensure the battery is properly placed, use a spudger or your finger to connect the battery press connector.
      Ask FixBot
    10. iPhone 16 Battery Replacement, Place the battery: step 37, image 1 of 3 iPhone 16 Battery Replacement, Place the battery: step 37, image 2 of 3 iPhone 16 Battery Replacement, Place the battery: step 37, image 3 of 3
      • With the battery connected, lower it into its place in the iPhone.
      • Use your fingers to press the battery into place.
      Ask FixBot
    11. iPhone 16 Battery Replacement, Disconnect the battery: step 38, image 1 of 2 iPhone 16 Battery Replacement, Disconnect the battery: step 38, image 2 of 2
      • Use a spudger or your finger to disconnect the battery to protect your iPhone during the rest of the reassembly process.
      Ask FixBot
    1. iPhone 16 Battery Replacement, Remove the back glass adhesive: step 39, image 1 of 3 iPhone 16 Battery Replacement, Remove the back glass adhesive: step 39, image 2 of 3 iPhone 16 Battery Replacement, Remove the back glass adhesive: step 39, image 3 of 3
      • Be careful not to damage any of the spring contacts as you clean the frame.
      • This is a good point to test your repair before sealing up your phone. Connect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down, disconnect the battery and back glass, and continue reassembly.
      • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
      • Use the pointed end of a spudger to press and roll the adhesive until you can grip it with a pair of tweezers.
      Ask FixBot
    2. iPhone 16 Battery Replacement: step 40, image 1 of 2 iPhone 16 Battery Replacement: step 40, image 2 of 2
      • Use the tweezers to pull the adhesive off of the phone.
      • Repeat the previous step and this step until all of the adhesive is removed.
      Ask FixBot
    3. iPhone 16 Battery Replacement, Clean the frame: step 41, image 1 of 3 iPhone 16 Battery Replacement, Clean the frame: step 41, image 2 of 3 iPhone 16 Battery Replacement, Clean the frame: step 41, image 3 of 3
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
      • Wrap a microfiber or lint-free cloth over the point of a spudger and apply a few drops of high-concentration isopropyl alcohol (over 90%) to the cloth.
      • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
      • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
      Ask FixBot
    4. iPhone 16 Battery Replacement, Clean the back glass: step 42, image 1 of 2 iPhone 16 Battery Replacement, Clean the back glass: step 42, image 2 of 2
      • If you're not reusing your back glass, skip this step.
      • Apply a few drops of high-concentration isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter of the back glass to prepare the surface for new adhesive.
      • If any clips on the back glass are bent, gently straighten them with your fingers.
      Ask FixBot
    5. iPhone 16 Battery Replacement, Orient the adhesive: step 43, image 1 of 2 iPhone 16 Battery Replacement, Orient the adhesive: step 43, image 2 of 2
      • Orient your replacement adhesive over the frame with the larger blue liner on the underside and its pull tab in the bottom-right corner.
      • The color of your liner and the pull tab locations may be different on your adhesive.
      • Use features such as the camera cutout and notches along the edges to ensure the adhesive is oriented correctly.
      Ask FixBot
    6. iPhone 16 Battery Replacement, Expose the bottom edge of the adhesive: step 44, image 1 of 1
      • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
      Ask FixBot
    7. iPhone 16 Battery Replacement, Apply the adhesive: step 45, image 1 of 3 iPhone 16 Battery Replacement, Apply the adhesive: step 45, image 2 of 3 iPhone 16 Battery Replacement, Apply the adhesive: step 45, image 3 of 3
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • Hold the blue liner out of the way and align the adhesive with the bottom edge of the iPhone.
      • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
      Ask FixBot
    8. iPhone 16 Battery Replacement: step 46, image 1 of 3 iPhone 16 Battery Replacement: step 46, image 2 of 3 iPhone 16 Battery Replacement: step 46, image 3 of 3
      • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
      • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
      • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
      Ask FixBot
    9. iPhone 16 Battery Replacement, Press the adhesive into place: step 47, image 1 of 3 iPhone 16 Battery Replacement, Press the adhesive into place: step 47, image 2 of 3 iPhone 16 Battery Replacement, Press the adhesive into place: step 47, image 3 of 3
      • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
      • Be careful not to touch the spring contacts sticking through the pink liner.
      Ask FixBot
    10. iPhone 16 Battery Replacement, Remove the pink liner: step 48, image 1 of 3 iPhone 16 Battery Replacement, Remove the pink liner: step 48, image 2 of 3 iPhone 16 Battery Replacement, Remove the pink liner: step 48, image 3 of 3
      • Use the small pull tab in the top-right corner to remove the pink adhesive liner.
      Ask FixBot
    11. iPhone 16 Battery Replacement: step 49, image 1 of 2 iPhone 16 Battery Replacement: step 49, image 2 of 2
      • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
      • Your pull tabs may be in different positions.
      • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. If the adhesive is clean and properly aligned, you may proceed, just be careful not to touch anything to the exposed adhesive until you are ready to install the back glass.
      Ask FixBot
    12. iPhone 16 Battery Replacement, Connect the charging coil: step 50, image 1 of 3 iPhone 16 Battery Replacement, Connect the charging coil: step 50, image 2 of 3 iPhone 16 Battery Replacement, Connect the charging coil: step 50, image 3 of 3
      • Prop up the back glass along the right edge of your iPhone, using a box or similar sturdy object to support the screen.
      • Use the flat end of a spudger or your finger to connect the charging coil press connector.
      Ask FixBot
    13. iPhone 16 Battery Replacement, Connect the battery: step 51, image 1 of 2 iPhone 16 Battery Replacement, Connect the battery: step 51, image 2 of 2
      • Use the flat end of a spudger or your finger to connect the battery.
      Ask FixBot
    14. iPhone 16 Battery Replacement, Install the cover: step 52, image 1 of 3 iPhone 16 Battery Replacement, Install the cover: step 52, image 2 of 3 iPhone 16 Battery Replacement, Install the cover: step 52, image 3 of 3
      • The connector cover has two hooks that slide into slots on the logic board.
      • Lay the connector cover on the phone so the hooks are slightly to the left of their slots in the logic board.
      • Use your finger to press the connector cover down and to the right until both hooks slide into their slots.
      Ask FixBot
    15. iPhone 16 Battery Replacement, Install the cover screws: step 53, image 1 of 2 iPhone 16 Battery Replacement, Install the cover screws: step 53, image 2 of 2
      • Use a tri-point Y000 driver to install the two 1 mm‑long screws securing the middle connector cover.
      Ask FixBot
    16. iPhone 16 Battery Replacement, Remove the final adhesive liners: step 54, image 1 of 3 iPhone 16 Battery Replacement, Remove the final adhesive liners: step 54, image 2 of 3 iPhone 16 Battery Replacement, Remove the final adhesive liners: step 54, image 3 of 3
      • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
      • Use the blue tabs to remove the liners from the bottom, left, and top edges of your iPhone. Wait to remove the liner along the right edge.
      Ask FixBot
    17. iPhone 16 Battery Replacement: step 55, image 1 of 2 iPhone 16 Battery Replacement: step 55, image 2 of 2
      • Without letting the back glass touch the adhesive, hold the back glass over the phone so you can access the final liner along the right edge of the phone.
      • Use a pair of tweezers or your fingers to remove the final liner along the right edge of the phone.
      Ask FixBot
    18. iPhone 16 Battery Replacement, Place the back glass: step 56, image 1 of 3 iPhone 16 Battery Replacement, Place the back glass: step 56, image 2 of 3 iPhone 16 Battery Replacement, Place the back glass: step 56, image 3 of 3
      • Hold the back glass above the phone and align it with the frame.
      • Lay the glass straight down onto the frame and press until the clips engage.
      • Press around the perimeter of the back glass to engage all clips.
      Ask FixBot
    19. iPhone 16 Battery Replacement, Heat the back glass: step 57, image 1 of 3 iPhone 16 Battery Replacement, Heat the back glass: step 57, image 2 of 3 iPhone 16 Battery Replacement, Heat the back glass: step 57, image 3 of 3
      • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
      • Firmly press around the perimeter of the back glass.
      • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the back glass.
      Ask FixBot
    20. iPhone 16 Battery Replacement, Press the back glass: step 58, image 1 of 3 iPhone 16 Battery Replacement, Press the back glass: step 58, image 2 of 3 iPhone 16 Battery Replacement, Press the back glass: step 58, image 3 of 3
      • To evenly compress your iPhone and strengthen the bond of the back glass to the frame, you need to account for the camera bump.
      • If you have the box your iPhone came in, take the lid and place it on a flat surface.
      • If you don't have your original box, skip this step for an alternate method.
      • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
      • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
      • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
      Ask FixBot
    21. iPhone 16 Battery Replacement: step 59, image 1 of 2 iPhone 16 Battery Replacement: step 59, image 2 of 2
      • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the back glass.
      • Place the iPhone screen-side-down on a soft, flat surface.
      • Apply tape to the back glass to protect its finish.
      Ask FixBot
    22. iPhone 16 Battery Replacement: step 60, image 1 of 3 iPhone 16 Battery Replacement: step 60, image 2 of 3 iPhone 16 Battery Replacement: step 60, image 3 of 3
      • Place two layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
      Ask FixBot
    23. iPhone 16 Battery Replacement: step 61, image 1 of 1
      • Stack multiple books or other heavy objects on your iPhone.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      Ask FixBot
    1. iPhone 16 Battery Replacement, Install the pentalobe screws: step 62, image 1 of 2 iPhone 16 Battery Replacement, Install the pentalobe screws: step 62, image 2 of 2
      • Use a P2 pentalobe driver to install the two 7.7 mm-long screws on either side of the charging port.
      Ask FixBot
After your repair, run Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Answers Community for help.
13 other people completed this guide.
Author
with
Alex Diaz-Kokaisl
253,203 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
5 Guide Comments
Thats some crazy stuff going on with the battery. Gonna need the same method to loosesn the back glass somehow. Maybe a hidden Positive and negaitve terminal in the sim slot where a special insert would loosen the glue with power being sent through it
Sebastian Wilmer - Reply Share
Does iPhone 16e require the same steps?
Albraa Tahani-Mazen - Reply Share
Similar, but not the same! We’ll be releasing guides for the 16e in a few weeks.
Alex Diaz-Kokaisl - Reply Share
My kit did not come with the alligator clips
Brian Nicosia - Reply Share
This may be because in some regions such as Australia ifixit does not sell the clips and you must use a 9v battery
Bhishan Charitra - Reply Share
Past 24 Hours: 118
Past 7 Days: 1,017
Past 30 Days: 4,642
All Time: 73,877
