Up to 20% off select tools
iPhone 11 Battery Replacement
Views: 956K
View statistics:
Past 24 Hours:
380
Past 7 Days:
2,515
Past 30 Days:
10,631
All Time:
956,121
Comments: 154
119 comments on steps, 35 guide comments.
Go to guide comments
Completed: 262
262 people have marked this guide "completed." Will you be next?
Favorites: 35
35 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
iPhone batteries degrade with use—over time, they lose their ability to hold a full charge. Apple's batteries are rated to hold 80% of their capacity for up to 500 charge cycles, which lasts roughly 18-24 months for most users. When your battery's chemistry is degraded, it may also cause your iPhone to run more slowly. Use this guide to replace your battery and restore your iPhone 11 to full performance.
If your battery is swollen, take appropriate precautions.
Note: After the repair, your iPhone may display a warning about the “genuineness” of the battery, even when using original Apple parts. If your iPhone functions normally, you can safely ignore the warning.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
You'll need replacement adhesive in order to complete this repair.
Video Overview
    1. iPhone 11 Battery Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone 11 Battery Replacement, Remove the pentalobe screws: step 1, image 2 of 2
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.7 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone 11 Battery Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 11 Battery Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 11 Battery Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 11 Battery Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 11 Battery Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 11 Battery Replacement, Tape over any cracks: step 3, image 3 of 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    2. iPhone 11 Battery Replacement, Screen damage warning: step 4, image 1 of 3 iPhone 11 Battery Replacement, Screen damage warning: step 4, image 2 of 3 iPhone 11 Battery Replacement, Screen damage warning: step 4, image 3 of 3
      • To avoid damaging your screen in the next step, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll damage the screen.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive. In this case, you’ll most likely need to replace your entire screen.
      Ask FixBot
    3. iPhone 11 Battery Replacement, Anti-Clamp instructions: step 5, image 1 of 3 iPhone 11 Battery Replacement, Anti-Clamp instructions: step 5, image 2 of 3 iPhone 11 Battery Replacement, Anti-Clamp instructions: step 5, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    4. iPhone 11 Battery Replacement: step 6, image 1 of 3 iPhone 11 Battery Replacement: step 6, image 2 of 3 iPhone 11 Battery Replacement: step 6, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    5. iPhone 11 Battery Replacement: step 7, image 1 of 3 iPhone 11 Battery Replacement: step 7, image 2 of 3 iPhone 11 Battery Replacement: step 7, image 3 of 3
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    6. iPhone 11 Battery Replacement, Heat the lower edge of the phone: step 8, image 1 of 1
      • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
      Ask FixBot
    7. iPhone 11 Battery Replacement: step 9, image 1 of 2 iPhone 11 Battery Replacement: step 9, image 2 of 2
      • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
      Ask FixBot
    8. iPhone 11 Battery Replacement, Lift the display slightly: step 10, image 1 of 3 iPhone 11 Battery Replacement, Lift the display slightly: step 10, image 2 of 3 iPhone 11 Battery Replacement, Lift the display slightly: step 10, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
      • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    9. iPhone 11 Battery Replacement, Separate the screen adhesive: step 11, image 1 of 3 iPhone 11 Battery Replacement, Separate the screen adhesive: step 11, image 2 of 3 iPhone 11 Battery Replacement, Separate the screen adhesive: step 11, image 3 of 3
      • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      Ask FixBot
    10. iPhone 11 Battery Replacement, Screen information: step 12, image 1 of 1
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      Ask FixBot
    11. iPhone 11 Battery Replacement: step 13, image 1 of 3 iPhone 11 Battery Replacement: step 13, image 2 of 3 iPhone 11 Battery Replacement: step 13, image 3 of 3
      • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Ask FixBot
    12. iPhone 11 Battery Replacement: step 14, image 1 of 3 iPhone 11 Battery Replacement: step 14, image 2 of 3 iPhone 11 Battery Replacement: step 14, image 3 of 3
      • The top edge of the display is secured with both glue and clips.
      • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
      • Insert your pick into the top-right corner of the phone.
      Ask FixBot
    13. iPhone 11 Battery Replacement: step 15, image 1 of 2 iPhone 11 Battery Replacement: step 15, image 2 of 2
      • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
      • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
      • Don't insert your pick more than 3 mm, as you may damage the Face ID sensor array.
      Ask FixBot
    14. iPhone 11 Battery Replacement, Remove the suction cup: step 16, image 1 of 1
      • Pull the small nub on the suction cup to detach it from the front panel.
      Ask FixBot
    15. iPhone 11 Battery Replacement, Open the iPhone: step 17, image 1 of 3 iPhone 11 Battery Replacement, Open the iPhone: step 17, image 2 of 3 iPhone 11 Battery Replacement, Open the iPhone: step 17, image 3 of 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Prop the display up against something sturdy.
      • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
      Ask FixBot
    1. iPhone 11 Battery Replacement, Display Assembly: step 18, image 1 of 2 iPhone 11 Battery Replacement, Display Assembly: step 18, image 2 of 2
      • To access the screws in the following step, tilt the display by slightly lifting its lower edge.
      • Be careful not to strain or tear the display cables.
      Ask FixBot
    2. iPhone 11 Battery Replacement, Unscrew the battery connector cover: step 19, image 1 of 2 iPhone 11 Battery Replacement, Unscrew the battery connector cover: step 19, image 2 of 2
      Magnetic Project Mat
      $16.96
      Buy
      • Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Ask FixBot
    3. iPhone 11 Battery Replacement, Remove the battery connector cover: step 20, image 1 of 1
      • Remove the bracket.
      Ask FixBot
    4. iPhone 11 Battery Replacement, Disconnect the battery: step 21, image 1 of 2 iPhone 11 Battery Replacement, Disconnect the battery: step 21, image 2 of 2
      • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
      Ask FixBot
    5. iPhone 11 Battery Replacement, Unscrew the logic board cover screws: step 22, image 1 of 2 iPhone 11 Battery Replacement, Unscrew the logic board cover screws: step 22, image 2 of 2
      • Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket.
      Ask FixBot
    6. iPhone 11 Battery Replacement, Remove the logic board cover bracket: step 23, image 1 of 1
      Ask FixBot
    7. iPhone 11 Battery Replacement, Disconnect the display: step 24, image 1 of 3 iPhone 11 Battery Replacement, Disconnect the display: step 24, image 2 of 3 iPhone 11 Battery Replacement, Disconnect the display: step 24, image 3 of 3
      • Use a spudger or a fingernail to disconnect the LCD panel cable connector.
      • Disconnect the digitizer connector next to it.
      Ask FixBot
    8. iPhone 11 Battery Replacement, Disconnect the front sensors: step 25, image 1 of 2 iPhone 11 Battery Replacement, Disconnect the front sensors: step 25, image 2 of 2
      • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
      Ask FixBot
    9. iPhone 11 Battery Replacement, Remove the display assembly: step 26, image 1 of 1
      Ask FixBot
    1. iPhone 11 Battery Replacement, Remove the lower bracket screws: step 27, image 1 of 2 iPhone 11 Battery Replacement, Remove the lower bracket screws: step 27, image 2 of 2
      • Using a Phillips driver, remove the five screws securing the bracket below the Taptic engine and speaker:
      • Four 1.6 mm screws
      • One 1.3 mm screw
      Ask FixBot
    2. iPhone 11 Battery Replacement, Remove the lower bracket: step 28, image 1 of 1
      • Remove the lower bracket.
      Ask FixBot
    3. iPhone 11 Battery Replacement, Remove the Taptic Engine connector tape: step 29, image 1 of 3 iPhone 11 Battery Replacement, Remove the Taptic Engine connector tape: step 29, image 2 of 3 iPhone 11 Battery Replacement, Remove the Taptic Engine connector tape: step 29, image 3 of 3
      Buy
      • Use tweezers to lift and remove the black tape and rubber pad covering the Taptic Engine connector.
      • Use a little heat from a hair dryer or iOpener to make the tape easier to peel up and re-adhere later.
      Ask FixBot
    4. iPhone 11 Battery Replacement, Unscrew the lower speaker: step 30, image 1 of 2 iPhone 11 Battery Replacement, Unscrew the lower speaker: step 30, image 2 of 2
      • Remove the five screws securing the speaker and brackets:
      • One 1.9 mm Phillips screw
      • One 2.3 mm Phillips screw
      • One 3.1 mm standoff screw
      • Two 1.6 mm Phillips screws
      Ask FixBot
    5. iPhone 11 Battery Replacement, Remove the grounding clip: step 31, image 1 of 2 iPhone 11 Battery Replacement, Remove the grounding clip: step 31, image 2 of 2
      • Remove the small grounding clip on the top right corner of the speaker.
      Ask FixBot
    6. iPhone 11 Battery Replacement, Remove the Taptic Engine connector cover: step 32, image 1 of 1
      • Remove the Taptic Engine connector cover.
      Ask FixBot
    7. iPhone 11 Battery Replacement, Remove the speaker standoff screw: step 33, image 1 of 3 iPhone 11 Battery Replacement, Remove the speaker standoff screw: step 33, image 2 of 3 iPhone 11 Battery Replacement, Remove the speaker standoff screw: step 33, image 3 of 3
      • Lift and push aside the small board covering the remaining speaker screw in the bottom right corner of the iPhone.
      • Remove the 2.4 mm standoff screw underneath.
      Ask FixBot
    8. iPhone 11 Battery Replacement, Loosen the speaker: step 34, image 1 of 2 iPhone 11 Battery Replacement, Loosen the speaker: step 34, image 2 of 2
      • Insert a spudger under the top edge of the speaker, near the edge of the iPhone's case.
      • Gently pry up and lift the top edge of the speaker.
      Ask FixBot
    9. iPhone 11 Battery Replacement: step 35, image 1 of 2 iPhone 11 Battery Replacement: step 35, image 2 of 2
      • Hold the speaker by its side edges and rock it side-to-side, separating the adhesive securing it to the bottom edge of the iPhone.
      • Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates.
      Ask FixBot
    10. iPhone 11 Battery Replacement, Remove the speaker: step 36, image 1 of 2 iPhone 11 Battery Replacement, Remove the speaker: step 36, image 2 of 2
      • Remove the speaker.
      • Optionally, to help protect against water and dust intrusion, replace the speaker's adhesive gasket during reassembly:
      • Peel away any remaining adhesive with tweezers.
      • Prep the area underneath by cleaning it with a bit of isopropyl alcohol and a lint-free cloth or coffee filter so that the gasket adheres properly.
      • Install a new gasket onto the speaker, and then install the speaker.
      Ask FixBot
    1. iPhone 11 Battery Replacement, Unscrew the Taptic Engine: step 37, image 1 of 2 iPhone 11 Battery Replacement, Unscrew the Taptic Engine: step 37, image 2 of 2
      • Use a Phillips driver to remove the two 1.8 mm screws securing the Taptic Engine.
      Ask FixBot
    2. iPhone 11 Battery Replacement, Disconnect the Taptic Engine: step 38, image 1 of 2 iPhone 11 Battery Replacement, Disconnect the Taptic Engine: step 38, image 2 of 2
      • Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
      Ask FixBot
    3. iPhone 11 Battery Replacement, Remove the Taptic Engine: step 39, image 1 of 1
      • Remove the Taptic Engine.
      Ask FixBot
    1. iPhone 11 Battery Replacement, Locate the adhesive pull tabs: step 40, image 1 of 1
      • Six pieces of stretch-release adhesive hold the battery in place—three near the top edge, and three near the bottom.
      • Each piece of adhesive has a black pull-tab at one end, which is lightly adhered and folded onto the top of the battery.
      Ask FixBot
    2. iPhone 11 Battery Replacement, Peel back the lower pull tabs: step 41, image 1 of 3 iPhone 11 Battery Replacement, Peel back the lower pull tabs: step 41, image 2 of 3 iPhone 11 Battery Replacement, Peel back the lower pull tabs: step 41, image 3 of 3
      • Peel back the three battery adhesive pull tabs from the bottom edge of the battery.
      • Be careful not to jab the battery with any sharp tools—a punctured battery may leak dangerous chemicals or catch fire.
      Ask FixBot
    3. iPhone 11 Battery Replacement: step 42, image 1 of 1
      • In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. The adhesive releases as it stretches.
      • If the strips break, don't panic! Keep reading for some additional steps for removing broken strips.
      • To increase your odds of success:
      • Don't press down on the battery. Hold the iPhone firmly by its sides.
      • Keep the strips flat and unwrinkled as you pull.
      • Pull very slowly, giving the strip time to stretch and separate. It takes around 30 seconds of stretching to remove each strip.
      • Pull at a low angle so the strip doesn't snag along the bottom edge of the battery.
      • If a strip does break off underneath the battery and cannot be retrieved, move on to the other strips and then continue with the additional steps below.
      Ask FixBot
    4. iPhone 11 Battery Replacement, Remove the first adhesive strip: step 43, image 1 of 3 iPhone 11 Battery Replacement, Remove the first adhesive strip: step 43, image 2 of 3 iPhone 11 Battery Replacement, Remove the first adhesive strip: step 43, image 3 of 3
      Buy
      • Slowly pull one battery adhesive tab away from the battery, towards the bottom of the iPhone.
      • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case.
      • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
      • If the battery adhesive tabs break during the removal process, use your fingers or tweezers to retrieve the remaining length of adhesive, and continue pulling.
      • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the other strips, and then proceed as instructed below.
      Ask FixBot
    5. iPhone 11 Battery Replacement, Remove two more adhesive strips: step 44, image 1 of 3 iPhone 11 Battery Replacement, Remove two more adhesive strips: step 44, image 2 of 3 iPhone 11 Battery Replacement, Remove two more adhesive strips: step 44, image 3 of 3
      • Repeat the above steps to remove the other two adhesive strips near the bottom edge of the iPhone.
      Ask FixBot
    6. iPhone 11 Battery Replacement, Peel away the top adhesive pull tabs: step 45, image 1 of 3 iPhone 11 Battery Replacement, Peel away the top adhesive pull tabs: step 45, image 2 of 3 iPhone 11 Battery Replacement, Peel away the top adhesive pull tabs: step 45, image 3 of 3
      • Peel back the three battery adhesive tabs from the top edge of the battery.
      • Don't touch the Face ID sensor modules near the top of the iPhone.
      Ask FixBot
    7. iPhone 11 Battery Replacement, Remove the three top adhesive strips: step 46, image 1 of 3 iPhone 11 Battery Replacement, Remove the three top adhesive strips: step 46, image 2 of 3 iPhone 11 Battery Replacement, Remove the three top adhesive strips: step 46, image 3 of 3
      • Pull the top adhesive strips out one at a time, using the same method you've used to pull the bottom strips.
      • Be sure to hold onto the battery as you remove the final strip, or it may fling out of the iPhone unexpectedly.
      • If you removed all of the adhesive strips successfully, skip the next step.
      • If any of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
      Ask FixBot
    8. iPhone 11 Battery Replacement, Removing a battery that's still stuck: step 47, image 1 of 2 iPhone 11 Battery Replacement, Removing a battery that's still stuck: step 47, image 2 of 2
      • If any of the adhesive strips broke off and the battery remains stuck to the rear case, remove it by adding a few drops of isopropyl alcohol (90% or greater) underneath the battery near the stuck strip(s).
      • After about a minute, gently lift the battery.
      • The battery should come free with minimal force. If not, add a little more isopropyl alcohol and try again. Do not bend or puncture the battery.
      Ask FixBot
    9. iPhone 11 Battery Replacement, Removing a stuck battery (alternate method): step 48, image 1 of 3 iPhone 11 Battery Replacement, Removing a stuck battery (alternate method): step 48, image 2 of 3 iPhone 11 Battery Replacement, Removing a stuck battery (alternate method): step 48, image 3 of 3
      • If your battery is stuck and an appropriate liquid solvent is not available, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
      • Heat the iPhone until the rear case is slightly too hot to comfortably touch, but no more.
      • Flip the iPhone back over and thread a strong piece of string (such as dental floss) underneath the battery.
      • Wear gloves to protect your fingers, or wrap each end of the string around a tool.
      • Pull the string from side to side in a sawing motion to separate the adhesive. This can take some time since the adhesive is slow to deform, but with patience it will come free. Do not deform or damage the battery.
      • Start from the top or bottom edge of the battery, and pull toward the middle. Don't pull the string through the middle third of the battery, or you may damage the ribbon cables or the wireless charging coil directly underneath.
      • If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
      Ask FixBot
    10. iPhone 11 Battery Replacement, Remove the battery: step 49, image 1 of 1
      • Remove the battery.
      • Reinstall the Taptic Engine and speaker before installing a new battery. This helps keep the battery aligned correctly during installation.
      • Before you adhere the replacement battery, temporarily reconnect the battery connector to the motherboard socket. This ensures that the battery is properly aligned in its recess.
      • Adhere the battery, disconnect it, and continue reassembling your device.
      • If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
      • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 11 Answers community for help.
262 other people completed this guide.
Author
with
Jeff Suovanen
455,892 Reputation
259 Guides authored
35 Guide Comments
Also, it would be nice to have a step by step of how to reprogram the new battery to bypass the “non-genuine warning”
Olamide Olayinka - Reply Share
I have been looking for a solution for this! Seems the only way is to remove the BMS board from the original battery. Requires soldering.
Mohammad Ali - Reply Share
Yea. There's a step by step guide on how to do just that here
Joseftech - Reply Share
Apple specifically does this to prevent 3rd parties from repairing their products. A Simple google search would have yielded this.
Brian Kennally - Reply Share
"A simple google search would have yielded this" 🤓🤓🤓
Freddy Jackson - Reply Share
Past 24 Hours: 380
Past 7 Days: 2,515
Past 30 Days: 10,631
All Time: 956,121
