Up to 20% off select tools
iPhone 15 Plus Battery Replacement
Views: 34K
View statistics:
Past 24 Hours:
39
Past 7 Days:
465
Past 30 Days:
1,936
All Time:
34,268
Comments: 34
31 comments on steps, 3 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the battery in your iPhone 15 Plus.
iPhone batteries are rated to hold 80% of their capacity for up to 1000 charge cycles. If your iPhone needs to be charged more often or runs slower, it might be time to replace the battery.
You'll need replacement battery and back glass adhesive to complete this repair.
If your battery is swollen, take appropriate precautions.
Note: Due to Apple's parts pairing restrictions, on iOS 17.6 and earlier, you may receive warnings about your replacement part and lose access to battery health data, but your new battery will otherwise work normally. On iOS 18 and newer, calibrate authentic Apple batteries using Repair Assistant.
    1. iPhone 15 Plus Battery Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 iPhone 15 Plus Battery Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Ask FixBot
    2. iPhone 15 Plus Battery Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 15 Plus Battery Replacement, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    1. iPhone 15 Plus Battery Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 15 Plus Battery Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 15 Plus Battery Replacement, Mark your opening picks: step 3, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 15 Plus Battery Replacement, Remove the pentalobe screws: step 4, image 1 of 1
      • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 15 Plus Battery Replacement, Heat the bottom edge: step 5, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Ask FixBot
    2. iPhone 15 Plus Battery Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 15 Plus Battery Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 15 Plus Battery Replacement, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the back glass.
      • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    3. iPhone 15 Plus Battery Replacement, Back glass information: step 7, image 1 of 1
      • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
      • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
      Ask FixBot
    4. iPhone 15 Plus Battery Replacement, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 15 Plus Battery Replacement, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 15 Plus Battery Replacement, Separate the bottom edge adhesive: step 8, image 3 of 3
      • Don't insert your opening pick deeper than 5 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    5. iPhone 15 Plus Battery Replacement, Heat the right edge: step 9, image 1 of 1
      • Heat the right edge of the back glass until it's hot to the touch.
      Ask FixBot
    6. iPhone 15 Plus Battery Replacement, Separate the bottom right corner adhesive: step 10, image 1 of 3 iPhone 15 Plus Battery Replacement, Separate the bottom right corner adhesive: step 10, image 2 of 3 iPhone 15 Plus Battery Replacement, Separate the bottom right corner adhesive: step 10, image 3 of 3
      • Don't insert your pick deeper than 7 mm along the right edge.
      • Rotate your pick around the bottom right corner and slide it halfway up the right edge or until you feel a hard stop at a clip securing the back glass.
      • Don't slice near the volume buttons to avoid damaging the wireless charging cable.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    7. iPhone 15 Plus Battery Replacement, Heat the left edge: step 11, image 1 of 1
      • Heat the left edge of the back glass until it's hot to the touch.
      Ask FixBot
    8. iPhone 15 Plus Battery Replacement, Separate the left edge adhesive: step 12, image 1 of 3 iPhone 15 Plus Battery Replacement, Separate the left edge adhesive: step 12, image 2 of 3 iPhone 15 Plus Battery Replacement, Separate the left edge adhesive: step 12, image 3 of 3
      • Don't insert your pick deeper than 5 mm along the left edge.
      • Insert a second opening pick at the bottom edge.
      • Rotate the second pick around the bottom left corner.
      • Slide this pick up to the top left corner to separate the adhesive.
      Ask FixBot
    9. iPhone 15 Plus Battery Replacement, Heat the top edge: step 13, image 1 of 1
      • Heat the top edge of the back glass until it's hot to the touch.
      Ask FixBot
    10. iPhone 15 Plus Battery Replacement, Separate the top edge adhesive: step 14, image 1 of 3 iPhone 15 Plus Battery Replacement, Separate the top edge adhesive: step 14, image 2 of 3 iPhone 15 Plus Battery Replacement, Separate the top edge adhesive: step 14, image 3 of 3
      • Don't insert your pick deeper than 3 mm along the top edge.
      • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
      • You might hear and feel clicks as the top two clips release.
      • Leave this pick in place to prevent the adhesive from resealing.
      Ask FixBot
    11. iPhone 15 Plus Battery Replacement, Heat the top right corner: step 15, image 1 of 1
      • Heat the top right corner of the back glass until it's hot to the touch.
      Ask FixBot
    12. iPhone 15 Plus Battery Replacement, Separate the top right corner adhesive: step 16, image 1 of 3 iPhone 15 Plus Battery Replacement, Separate the top right corner adhesive: step 16, image 2 of 3 iPhone 15 Plus Battery Replacement, Separate the top right corner adhesive: step 16, image 3 of 3
      • Don't insert your pick deeper than 4 mm along the right edge.
      • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
      Ask FixBot
    13. iPhone 15 Plus Battery Replacement, Swing open the back glass: step 17, image 1 of 2 iPhone 15 Plus Battery Replacement, Swing open the back glass: step 17, image 2 of 2
      • Gently swing open the back glass to the right of the phone.
      • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
      • Rest the back glass against a raised surface so it doesn't strain the cable.
      Ask FixBot
    1. iPhone 15 Plus Battery Replacement, Unfasten the lower connector cover: step 18, image 1 of 2 iPhone 15 Plus Battery Replacement, Unfasten the lower connector cover: step 18, image 2 of 2
      Tool used on this step:
      FixMat
      $31.41
      Buy
      • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
      Ask FixBot
    2. iPhone 15 Plus Battery Replacement, Remove the lower connector cover: step 19, image 1 of 3 iPhone 15 Plus Battery Replacement, Remove the lower connector cover: step 19, image 2 of 3 iPhone 15 Plus Battery Replacement, Remove the lower connector cover: step 19, image 3 of 3
      Buy
      • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
      • Remove the cover.
      Ask FixBot
    3. iPhone 15 Plus Battery Replacement: step 20, image 1 of 3 iPhone 15 Plus Battery Replacement: step 20, image 2 of 3 iPhone 15 Plus Battery Replacement: step 20, image 3 of 3
      • Hold the back glass upright with one hand and rotate the bottom edge to the left to reveal the battery press connector just below the volume buttons.
      • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
      • A plus and minus sign is printed on the head of this connector.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
      Ask FixBot
    1. iPhone 15 Plus Battery Replacement, Unfasten the middle connector cover: step 21, image 1 of 2 iPhone 15 Plus Battery Replacement, Unfasten the middle connector cover: step 21, image 2 of 2
      • Use your tri-point Y000 driver to remove the 0.9 mm-long screw securing the middle connector cover.
      Ask FixBot
    2. iPhone 15 Plus Battery Replacement, Remove the cover: step 22, image 1 of 3 iPhone 15 Plus Battery Replacement, Remove the cover: step 22, image 2 of 3 iPhone 15 Plus Battery Replacement, Remove the cover: step 22, image 3 of 3
      • Use the flat end of a spudger or your finger to push the cover toward the bottom of the phone and unclip its top edge.
      • Remove the cover.
      Ask FixBot
    3. iPhone 15 Plus Battery Replacement, Disconnect the wireless charging coil: step 23, image 1 of 2 iPhone 15 Plus Battery Replacement, Disconnect the wireless charging coil: step 23, image 2 of 2
      • Use an opening pick to pry up and disconnect the wireless charging coil and NFC connector.
      Ask FixBot
    4. iPhone 15 Plus Battery Replacement: step 24, image 1 of 1
      • Remove the back glass.
      Ask FixBot
    1. iPhone 15 Plus Battery Replacement, Separate the battery cable: step 25, image 1 of 2 iPhone 15 Plus Battery Replacement, Separate the battery cable: step 25, image 2 of 2
      • Light adhesive secures the battery cable to the logic board.
      • Slide an opening pick under the battery cable to separate it from the logic board.
      • Be careful not to crease the cable or dent the battery with your tool.
      Ask FixBot
    2. iPhone 15 Plus Battery Replacement, Peel up a corner of the pull tabs: step 26, image 1 of 3 iPhone 15 Plus Battery Replacement, Peel up a corner of the pull tabs: step 26, image 2 of 3 iPhone 15 Plus Battery Replacement, Peel up a corner of the pull tabs: step 26, image 3 of 3
      Buy
      • Your iPhone's battery is secured with two stretch release adhesive strips. The next four steps show how to remove them and free your battery.
      • Be careful not to dent or puncture the battery, and avoid using sharp tools near it.
      • Use the tip of an opening pick to scrape up an edge of each stretch release pull tab from the top of the battery until you can grip the tab with blunt nose tweezers.
      Ask FixBot
    3. iPhone 15 Plus Battery Replacement, Peel up the pull tabs: step 27, image 1 of 2 iPhone 15 Plus Battery Replacement, Peel up the pull tabs: step 27, image 2 of 2
      • Use blunt nose tweezers to grip a pull tab and peel it from the battery.
      • Don't try to pull the tab out from under the battery just yet.
      • Repeat for the other pull tab.
      Ask FixBot
    4. iPhone 15 Plus Battery Replacement, Free the top edge of the battery: step 28, image 1 of 3 iPhone 15 Plus Battery Replacement, Free the top edge of the battery: step 28, image 2 of 3 iPhone 15 Plus Battery Replacement, Free the top edge of the battery: step 28, image 3 of 3
      • The stretch release adhesive wraps around the top edge of the battery, and must be separated before you remove the strips.
      • Hold one of the pull tabs away from the battery with tweezers.
      • Use an opening pick to slice the adhesive securing the strip to the top edge of the battery.
      Ask FixBot
    5. iPhone 15 Plus Battery Replacement, Remove the stretch release adhesive: step 29, image 1 of 3 iPhone 15 Plus Battery Replacement, Remove the stretch release adhesive: step 29, image 2 of 3 iPhone 15 Plus Battery Replacement, Remove the stretch release adhesive: step 29, image 3 of 3
      • Use your blunt nose tweezers to grip the entire length of an adhesive strip's pull tab.
      • Twist your tweezers to roll the adhesive strip over itself and pull it slowly, evenly, and at a low angle out from under the battery.
      • Give the strip plenty of time to stretch. Avoid dragging it over cables or components as you pull.
      • If you're using your fingers, re-grip the strip often to avoid it stretching unevenly and tearing.
      • Repeat for the other strip.
      • If a strip breaks off, try to retrieve it from under the battery. If you can't retrieve it, don't worry! Move on to the next step for an alternate method.
      Ask FixBot
    6. iPhone 15 Plus Battery Replacement, Alternate method to remove the battery: step 30, image 1 of 2 iPhone 15 Plus Battery Replacement, Alternate method to remove the battery: step 30, image 2 of 2
      • If you removed both stretch release adhesive strips, congratulations—you can now remove the battery! If not, follow the next three steps to remove it with isopropyl alcohol and a plastic card.
      • Prop up the right edge of the phone (the side with the volume buttons).
      • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the inside edge of the battery.
      • Prop up the top edge of the phone and repeat this for the upper edge of the battery.
      • Wait one minute for the isopropyl alcohol to flow under the battery and soften the adhesive.
      Ask FixBot
    7. iPhone 15 Plus Battery Replacement, Insert a plastic card: step 31, image 1 of 3 iPhone 15 Plus Battery Replacement, Insert a plastic card: step 31, image 2 of 3 iPhone 15 Plus Battery Replacement, Insert a plastic card: step 31, image 3 of 3
      Plastic Cards
      $2.99
      Buy
      • Don't bend or crease your battery. If it feels stubborn, apply a few more drops of isopropyl alcohol and try again.
      • Insert the long edge of a plastic card between the left edge of the battery and the frame.
      • Hold the phone steady and pry the battery up.
      • Depending on how strong your adhesive is, this may take some time. Allow up to a minute of constant pressure for the adhesive to loosen.
      Ask FixBot
    8. iPhone 15 Plus Battery Replacement, Pry up the battery: step 32, image 1 of 2 iPhone 15 Plus Battery Replacement, Pry up the battery: step 32, image 2 of 2
      • Slide the plastic card deeper under the battery until you can pry it up.
      • Lift the battery until you can grab it with your fingers.
      Ask FixBot
    9. iPhone 15 Plus Battery Replacement, Remove the battery: step 33, image 1 of 2 iPhone 15 Plus Battery Replacement, Remove the battery: step 33, image 2 of 2
      • Remove the battery.
      Ask FixBot
    1. iPhone 15 Plus Battery Replacement, End of disassembly: step 34, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
      • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      • Reassembly photos are of the iPhone 15 non‑Plus. It may look a little different, but the procedure is correct.
      Ask FixBot
    1. iPhone 15 Plus Battery Replacement, Remove the residual battery adhesive: step 35, image 1 of 1
      • If there's any large pieces of residual battery adhesive remaining, use a pair of tweezers to peel them off the iPhone frame.
      • Use coffee filters or a lint‑free cloth and high‑concentration (>90%) isopropyl alcohol to wipe off any remaining battery adhesive residue from the iPhone frame.
      Ask FixBot
    2. iPhone 15 Plus Battery Replacement, Remove the plastic sleeve: step 36, image 1 of 2 iPhone 15 Plus Battery Replacement, Remove the plastic sleeve: step 36, image 2 of 2
      • If your replacement battery comes with a plastic sleeve, peel it off and remove it.
      Ask FixBot
    3. iPhone 15 Plus Battery Replacement, Remove adhesive liner: step 37, image 1 of 2 iPhone 15 Plus Battery Replacement, Remove adhesive liner: step 37, image 2 of 2
      • If your battery doesn't come with pre‑installed adhesive, follow this guide to install it, then come back to this guide to finish reassembly.
      • Peel the liner off the battery adhesive.
      Ask FixBot
    4. iPhone 15 Plus Battery Replacement, Place the battery: step 38, image 1 of 3 iPhone 15 Plus Battery Replacement, Place the battery: step 38, image 2 of 3 iPhone 15 Plus Battery Replacement, Place the battery: step 38, image 3 of 3
      • Hold the battery over its place in the iPhone and connect its press connector.
      • With the battery connected, lower it into place and use your fingers to press it into the frame.
      • After the battery is set, use the tip of a spudger to pry up and disconnect the battery cable press connector.
      Ask FixBot
    1. iPhone 15 Plus Battery Replacement, Remove the back glass adhesive: step 39, image 1 of 2 iPhone 15 Plus Battery Replacement, Remove the back glass adhesive: step 39, image 2 of 2
      • Be careful not to damage any of the spring contacts as you clean the frame.
      • This is a good point to test your repair before sealing up your phone. Connect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down, disconnect the battery and back glass, and continue reassembly.
      • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
      • Use the pointed end of a spudger to press and roll the adhesive until you can grip it with a pair of tweezers.
      • Use the tweezers to pull the adhesive off of the phone.
      Ask FixBot
    2. iPhone 15 Plus Battery Replacement: step 40, image 1 of 3 iPhone 15 Plus Battery Replacement: step 40, image 2 of 3 iPhone 15 Plus Battery Replacement: step 40, image 3 of 3
      • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
      • Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
      • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
      • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
      Ask FixBot
    3. iPhone 15 Plus Battery Replacement, Orient the adhesive: step 41, image 1 of 3 iPhone 15 Plus Battery Replacement, Orient the adhesive: step 41, image 2 of 3 iPhone 15 Plus Battery Replacement, Orient the adhesive: step 41, image 3 of 3
      • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the rear camera to make sure the adhesive is oriented correctly.
      • Your adhesive may look slightly different.
      Ask FixBot
    4. iPhone 15 Plus Battery Replacement, Apply the adhesive: step 42, image 1 of 3 iPhone 15 Plus Battery Replacement, Apply the adhesive: step 42, image 2 of 3 iPhone 15 Plus Battery Replacement, Apply the adhesive: step 42, image 3 of 3
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • Use the pull tab to begin peeling the back liner off the adhesive starting from the bottom, but don't remove the liner all the way.
      • Hold the liner out of the way and align the adhesive with the bottom edge of the iPhone.
      • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
      Ask FixBot
    5. iPhone 15 Plus Battery Replacement: step 43, image 1 of 3 iPhone 15 Plus Battery Replacement: step 43, image 2 of 3 iPhone 15 Plus Battery Replacement: step 43, image 3 of 3
      • When the adhesive is aligned, use the flat end of a spudger or your finger to press it down firmly along the bottom edge.
      Ask FixBot
    6. iPhone 15 Plus Battery Replacement: step 44, image 1 of 3 iPhone 15 Plus Battery Replacement: step 44, image 2 of 3 iPhone 15 Plus Battery Replacement: step 44, image 3 of 3
      • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
      • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
      • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
      Ask FixBot
    7. iPhone 15 Plus Battery Replacement, Press the adhesive into place: step 45, image 1 of 3 iPhone 15 Plus Battery Replacement, Press the adhesive into place: step 45, image 2 of 3 iPhone 15 Plus Battery Replacement, Press the adhesive into place: step 45, image 3 of 3
      • Make sure the liner is aligned properly by checking that all spring contacts and the rear camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
      • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
      • Be careful not to touch the spring contacts sticking through the pink liner.
      Ask FixBot
    8. iPhone 15 Plus Battery Replacement, Remove the top liner: step 46, image 1 of 3 iPhone 15 Plus Battery Replacement, Remove the top liner: step 46, image 2 of 3 iPhone 15 Plus Battery Replacement, Remove the top liner: step 46, image 3 of 3
      • Remove the top adhesive liner.
      • Depending on your adhesive, your liner might be split into multiple parts or be a single piece.
      Ask FixBot
    9. iPhone 15 Plus Battery Replacement, Prop up the back glass: step 47, image 1 of 3 iPhone 15 Plus Battery Replacement, Prop up the back glass: step 47, image 2 of 3 iPhone 15 Plus Battery Replacement, Prop up the back glass: step 47, image 3 of 3
      • Prop up the back glass along the right edge of the iPhone, using a box or similar sturdy object to support the screen.
      • Use the flat end of a spudger or your finger to connect the wireless charging coil press connector, then the battery press connector.
      Ask FixBot
    10. iPhone 15 Plus Battery Replacement, Place the middle connector cover: step 48, image 1 of 2 iPhone 15 Plus Battery Replacement, Place the middle connector cover: step 48, image 2 of 2
      • Place the middle connector cover over the wireless charging coil press connector so it slightly overhangs the slot on the logic board for the bottom clip.
      Ask FixBot
    11. iPhone 15 Plus Battery Replacement: step 49, image 1 of 2 iPhone 15 Plus Battery Replacement: step 49, image 2 of 2
      • Use your finger to press the cover down on the logic board.
      • While pressing it down, slide the cover upward so both metal clips slot into their spots in the logic board.
      Ask FixBot
    12. iPhone 15 Plus Battery Replacement, Place the lower connector cover: step 50, image 1 of 3 iPhone 15 Plus Battery Replacement, Place the lower connector cover: step 50, image 2 of 3 iPhone 15 Plus Battery Replacement, Place the lower connector cover: step 50, image 3 of 3
      • Use tweezers to hook the top of the lower connector cover into its slot on the logic board.
      • Lay the lower connector cover over the press connectors.
      Ask FixBot
    13. iPhone 15 Plus Battery Replacement, Install the cover screws: step 51, image 1 of 2 iPhone 15 Plus Battery Replacement, Install the cover screws: step 51, image 2 of 2
      • Use a tri-point Y000 screwdriver to install the 0.9 mm‑long screw securing the middle connector cover.
      • Use a tri-point Y000 screwdriver to install the two 1.3 mm‑long screws securing the lower connector cover.
      Ask FixBot
    14. iPhone 15 Plus Battery Replacement, Remove the final adhesive liners: step 52, image 1 of 2 iPhone 15 Plus Battery Replacement, Remove the final adhesive liners: step 52, image 2 of 2
      • Use tweezers or your fingers to separate the pull tabs at the bottom of the frame, near the charging port.
      Ask FixBot
    15. iPhone 15 Plus Battery Replacement: step 53, image 1 of 3 iPhone 15 Plus Battery Replacement: step 53, image 2 of 3 iPhone 15 Plus Battery Replacement: step 53, image 3 of 3
      • Remove the narrow liner covering the adhesive along the left and top edges of the frame.
      Ask FixBot
    16. iPhone 15 Plus Battery Replacement: step 54, image 1 of 3 iPhone 15 Plus Battery Replacement: step 54, image 2 of 3 iPhone 15 Plus Battery Replacement: step 54, image 3 of 3
      • Hold the back glass over the phone without letting it touch the adhesive, so you can access the remaining liners along the right edge of the phone.
      • Use a pair of tweezers or your fingers to remove the remaing liners along the right edge of the phone.
      Ask FixBot
    17. iPhone 15 Plus Battery Replacement, Install the back glass: step 55, image 1 of 3 iPhone 15 Plus Battery Replacement, Install the back glass: step 55, image 2 of 3 iPhone 15 Plus Battery Replacement, Install the back glass: step 55, image 3 of 3
      • Lay the back glass straight down onto the frame and press until the clips engage.
      • Press around the perimeter of the back glass to engage all the clips.
      Ask FixBot
    18. iPhone 15 Plus Battery Replacement, Install the pentalobe screws: step 56, image 1 of 2 iPhone 15 Plus Battery Replacement, Install the pentalobe screws: step 56, image 2 of 2
      • Use a P2 pentalobe driver to install the two 7.7 mm‑long screws on either side of the charging port.
      Ask FixBot
    19. iPhone 15 Plus Battery Replacement, Heat the back glass: step 57, image 1 of 2 iPhone 15 Plus Battery Replacement, Heat the back glass: step 57, image 2 of 2
      • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
      • Firmly press around the perimeter of the back glass. If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the back glass.
      Ask FixBot
    20. iPhone 15 Plus Battery Replacement, Press the back glass: step 58, image 1 of 3 iPhone 15 Plus Battery Replacement, Press the back glass: step 58, image 2 of 3 iPhone 15 Plus Battery Replacement, Press the back glass: step 58, image 3 of 3
      • To evenly compress your iPhone and strengthen the bond of the back glass to the frame, you need to account for the camera bump.
      • If you have the box your iPhone came in, take the lid and place it on a flat surface.
      • If you don't have your original box, skip this step for an alternate method.
      • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
      • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
      • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
      Ask FixBot
    21. iPhone 15 Plus Battery Replacement: step 59, image 1 of 2 iPhone 15 Plus Battery Replacement: step 59, image 2 of 2
      • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the back glass.
      • Place the iPhone screen-side-down on a soft, flat surface.
      • Apply tape to the back glass to protect its finish.
      Ask FixBot
    22. iPhone 15 Plus Battery Replacement: step 60, image 1 of 3 iPhone 15 Plus Battery Replacement: step 60, image 2 of 3 iPhone 15 Plus Battery Replacement: step 60, image 3 of 3
      • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Stack them to a consistent height taller than the camera bump.
      Ask FixBot
    23. iPhone 15 Plus Battery Replacement: step 61, image 1 of 1
      • Stack multiple books or other heavy objects on your iPhone.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      Ask FixBot
    1. iPhone 15 Plus Battery Replacement, Install the pentalobe screws: step 62, image 1 of 2 iPhone 15 Plus Battery Replacement, Install the pentalobe screws: step 62, image 2 of 2
      Ask FixBot
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
For optimal performance, calibrate your newly installed battery after completing this guide.
11 other people completed this guide.
Author
with
Clay Eickemeyer
109,670 Reputation
471 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
3 Guide Comments
I guess I don't get the rationale here. We come to iFixit, ostensibly to save money. Apple will replace the battery of virtually any iPhone for $69-$99, right? So, I buy an iFixit battery kit for $50. Then I have to purchase a heat gun or hair dryer, another $20-$25, then the back panel adhesive (which I can't find here for a 15 plus), so that's another $6, then I possibly need some 90% isopropyl alcohol for the battery adhesive (which is also a run to a store with time and money spent), and those things alone come to $85-$90. Which brings me to the point: Why would I bother to do a 1 hour (minimum) repair with all the fiddlies, and all the possibility of messing it up, when for about $10 service cost above the iFixit cost, I can just have a CERTIFIED GUARANTEED repair done at Apple. Right?
mothera - Reply Share
Everyone has a hair dryer in the house. And the apple repair is mor like 99 than 69, at least in my country. And I would pay no problem but they expect me to leave the phone and after that they order the battery and until it is delivered and repaired it takes a total of 10 days or so time where I don’t have my phone. Last time I just bought a new phone because of this but I got the ifixit battery replaced for a friend and he was very happy that it took 2 hours and he has the phone available same day. So yea… maybe it is not for you but it certainly is for a lot of people. Thank you ifixit for having an alternative.
Andrei Mihailescu - Reply Share
So, do I not need to order a new adhesive seal for the back glass when my device is reassembled?
How about Step 19? Those photos don’t clearly illustrate the process of sliding that bracket up to remove it? Please be more clear with your photos if there is a specific “process” to be followed. You did a great job a few steps later with the other bracket.
I’ve done this before so it won’t be so confusing, but, I can imagine someone who’s never done this being super confused and worried they’re going to mess up their iPhone because of us unclear instructions.
To those saying this saves you no money due to the tools - fine, don’t do it. Go pay Apple extra $50 to have them do it. The tools that come with this kit are practically given away compared to the price of a battery alone and the heat gun or hair dryer can easily be substituted with anything that can heat up enough to soften the adhesive. I’ve used heating pads and microwaveable rice bags to do this.
Just read the instructions, be patient, and GO SLOW.
jsolan81 - Reply Share
Past 24 Hours: 39
Past 7 Days: 465
Past 30 Days: 1,936
All Time: 34,268
