Up to 20% off select tools
iPhone SE 2020 Battery Replacement
Views: 445K
View statistics:
Past 24 Hours:
163
Past 7 Days:
1,241
Past 30 Days:
5,677
All Time:
445,345
Comments: 369
323 comments on steps, 46 guide comments.
Go to guide comments
Completed: 232
232 people have marked this guide "completed." Will you be next?
Favorites: 30
30 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to revive your iPhone SE 2020’s battery life and performance with a new battery. If your battery is swollen, take appropriate precautions.
This guide instructs you to completely detach the display assembly; this is intended to prevent accidental damage to the display cables. If you feel comfortable removing the battery without putting undue strain on the display cables, you can skip the steps for detaching the display. Additionally, while it’s possible to remove the adhesive strips securing the battery as soon as you open the phone, this guide recommends first removing the Taptic Engine. Doing so reduces the risk of breaking the lower adhesive strips accidentally, either by snagging them on the Taptic Engine, or by pulling the strips at too sharp of an angle.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
    1. iPhone SE 2020 Battery Replacement, Remove the pentalobe screws: step 1, image 1 of 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone SE 2020 Battery Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone SE 2020 Battery Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone SE 2020 Battery Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone SE 2020 Battery Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPhone SE 2020 Battery Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPhone SE 2020 Battery Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    2. iPhone SE 2020 Battery Replacement: step 4, image 1 of 3 iPhone SE 2020 Battery Replacement: step 4, image 2 of 3 iPhone SE 2020 Battery Replacement: step 4, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    3. iPhone SE 2020 Battery Replacement: step 5, image 1 of 2 iPhone SE 2020 Battery Replacement: step 5, image 2 of 2
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    4. iPhone SE 2020 Battery Replacement, Heat the display: step 6, image 1 of 1
      • The next three steps show how to separate the screen using a suction cup.
      • Apply a heated iOpener to the bottom edge of the screen for two minutes. This softens the adhesive securing it.
      • Alternatively, you can use a hair dryer or heat gun to heat the bottom half of the screen until it’s slightly too hot to touch
      • Improper use of a heat gun can destroy the display and/or battery—review this guide for instructions. To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • For tips on using a hair dryer to soften adhesive, check out this guide.
      Ask FixBot
    5. iPhone SE 2020 Battery Replacement, Separate the display: step 7, image 1 of 2 iPhone SE 2020 Battery Replacement, Separate the display: step 7, image 2 of 2
      • Apply a suction cup to the lower half of the front panel, just above the home button.
      • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
      Ask FixBot
    6. iPhone SE 2020 Battery Replacement: step 8, image 1 of 3 iPhone SE 2020 Battery Replacement: step 8, image 2 of 3 iPhone SE 2020 Battery Replacement: step 8, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    7. iPhone SE 2020 Battery Replacement: step 9, image 1 of 3 iPhone SE 2020 Battery Replacement: step 9, image 2 of 3 iPhone SE 2020 Battery Replacement: step 9, image 3 of 3
      • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
      • Stop near the top left corner of the display.
      • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
      Ask FixBot
    8. iPhone SE 2020 Battery Replacement, Screen information: step 10, image 1 of 1
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      Ask FixBot
    9. iPhone SE 2020 Battery Replacement: step 11, image 1 of 3 iPhone SE 2020 Battery Replacement: step 11, image 2 of 3 iPhone SE 2020 Battery Replacement: step 11, image 3 of 3
      • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Ask FixBot
    10. iPhone SE 2020 Battery Replacement: step 12, image 1 of 2 iPhone SE 2020 Battery Replacement: step 12, image 2 of 2
      • Gently pull up on the suction cup to lift up the bottom edge of the display.
      • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Ask FixBot
    11. iPhone SE 2020 Battery Replacement: step 13, image 1 of 3 iPhone SE 2020 Battery Replacement: step 13, image 2 of 3 iPhone SE 2020 Battery Replacement: step 13, image 3 of 3
      • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
      Ask FixBot
    12. iPhone SE 2020 Battery Replacement: step 14, image 1 of 2 iPhone SE 2020 Battery Replacement: step 14, image 2 of 2
      • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
      Ask FixBot
    13. iPhone SE 2020 Battery Replacement: step 15, image 1 of 3 iPhone SE 2020 Battery Replacement: step 15, image 2 of 3 iPhone SE 2020 Battery Replacement: step 15, image 3 of 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      Ask FixBot
    1. iPhone SE 2020 Battery Replacement, Disconnect the battery: step 16, image 1 of 2 iPhone SE 2020 Battery Replacement, Disconnect the battery: step 16, image 2 of 2
      Magnetic Project Mat
      $16.96
      Buy
      • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
      • Two 1.3 mm screws
      • Two 2.8 mm screws
      • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
      • Remove the bracket.
      Ask FixBot
    2. iPhone SE 2020 Battery Replacement: step 17, image 1 of 2 iPhone SE 2020 Battery Replacement: step 17, image 2 of 2
      • Use the point of a spudger to pry the battery connector out of its socket in the logic board.
      • Don't pry against the logic board, or you may damage the charging circuitry.
      • Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Ask FixBot
    1. iPhone SE 2020 Battery Replacement, Disconnect the display and digitizer: step 18, image 1 of 2 iPhone SE 2020 Battery Replacement, Disconnect the display and digitizer: step 18, image 2 of 2
      • Use the point of a spudger to pry the lower display connector out of its socket.
      • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
      Ask FixBot
    2. iPhone SE 2020 Battery Replacement: step 19, image 1 of 2 iPhone SE 2020 Battery Replacement: step 19, image 2 of 2
      • Use the point of a spudger to disconnect the second lower display cable.
      Ask FixBot
    3. iPhone SE 2020 Battery Replacement: step 20, image 1 of 2 iPhone SE 2020 Battery Replacement: step 20, image 2 of 2
      • Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
      Ask FixBot
    4. iPhone SE 2020 Battery Replacement: step 21, image 1 of 2 iPhone SE 2020 Battery Replacement: step 21, image 2 of 2
      • Use the point of a spudger to disconnect the front panel sensor assembly connector.
      Ask FixBot
    5. iPhone SE 2020 Battery Replacement, Remove the display assembly: step 22, image 1 of 1
      Ask FixBot
    1. iPhone SE 2020 Battery Replacement, Remove the Wi-Fi diversity antenna: step 23, image 1 of 1
      • Remove the three screws securing the bracket next to the Taptic Engine:
      • One 1.3 mm Y000 screw
      • One 2.7 mm Phillips screw
      • One 2.9 mm Phillips screw
      Ask FixBot
    2. iPhone SE 2020 Battery Replacement: step 24, image 1 of 1
      Ask FixBot
    3. iPhone SE 2020 Battery Replacement: step 25, image 1 of 3 iPhone SE 2020 Battery Replacement: step 25, image 2 of 3 iPhone SE 2020 Battery Replacement: step 25, image 3 of 3
      • Gently slide an opening pick between the antenna flex cable and the top of the speaker.
      • This portion of the flex cable is lightly adhered in place. If necessary, apply a little heat from an iOpener or hair dryer to soften the adhesive. This will make it easier to separate the flex cable safely.
      Ask FixBot
    4. iPhone SE 2020 Battery Replacement: step 26, image 1 of 2 iPhone SE 2020 Battery Replacement: step 26, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the diversity antenna flex cable from the logic board.
      Ask FixBot
    5. iPhone SE 2020 Battery Replacement: step 27, image 1 of 3 iPhone SE 2020 Battery Replacement: step 27, image 2 of 3 iPhone SE 2020 Battery Replacement: step 27, image 3 of 3
      Buy
      • Slide an opening pick under the antenna flex cable to hold the socket down.
      • Use the point of your spudger to pry up and disconnect the antenna flex cable from its socket, using the opening pick to hold the socket down.
      • Reconnecting this cable can be tricky. Make it easier by using your tweezers to hold the flex cable so the connector aligns with its socket. Then, gently press straight down on the connector with the flat of your spudger until it clicks into place.
      Ask FixBot
    6. iPhone SE 2020 Battery Replacement: step 28, image 1 of 1
      • Remove the Wi-Fi diversity antenna.
      Ask FixBot
    1. iPhone SE 2020 Battery Replacement, Remove the Taptic Engine: step 29, image 1 of 1
      Standoff Screwdriver for iPhones
      $5.49
      Buy
      • Remove the two screws securing the Taptic Engine:
      • One 2.1 mm Phillips screw
      • One 2.1 mm standoff screw
      • Standoff screws are best removed using a standoff screwdriver or bit.
      • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      Ask FixBot
    2. iPhone SE 2020 Battery Replacement: step 30, image 1 of 2 iPhone SE 2020 Battery Replacement: step 30, image 2 of 2
      • Use the point of your spudger to pry the antenna cable socket up and away from the connector below it.
      Ask FixBot
    3. iPhone SE 2020 Battery Replacement: step 31, image 1 of 2 iPhone SE 2020 Battery Replacement: step 31, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the Taptic Engine flex cable.
      Ask FixBot
    4. iPhone SE 2020 Battery Replacement: step 32, image 1 of 1
      • Remove the Taptic Engine.
      • Be careful removing Taptic Engine flex cable as it may be glued to the antenna flex cable.
      Ask FixBot
    1. iPhone SE 2020 Battery Replacement, Remove the battery adhesive: step 33, image 1 of 1
      • The iPhone's battery is secured by four pieces of stretch-release adhesive—two at the top, and two at the bottom.
      • Each piece of adhesive has a black pull-tab at the end, which is lightly adhered to the front surface of the battery.
      Ask FixBot
    2. iPhone SE 2020 Battery Replacement: step 34, image 1 of 3 iPhone SE 2020 Battery Replacement: step 34, image 2 of 3 iPhone SE 2020 Battery Replacement: step 34, image 3 of 3
      Buy
      • Peel back the first battery adhesive tab from the bottom right edge of the battery.
      • If possible, use your fingernails or blunt tweezers. Be careful not to poke the battery with any sharp tools.
      Ask FixBot
    3. iPhone SE 2020 Battery Replacement: step 35, image 1 of 3 iPhone SE 2020 Battery Replacement: step 35, image 2 of 3 iPhone SE 2020 Battery Replacement: step 35, image 3 of 3
      • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
      • Additionally, do not press down on the battery as you pull the strips. Pressing on the battery creates pressure points that can snag and break the adhesive.
      • Slowly pull one battery adhesive tab away from the battery, towards the bottom of the iPhone.
      • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at as low an angle as possible, without snagging it on any of the iPhone's other components.
      • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
      • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
      • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strips, and then proceed as instructed below.
      Ask FixBot
    4. iPhone SE 2020 Battery Replacement: step 36, image 1 of 3 iPhone SE 2020 Battery Replacement: step 36, image 2 of 3 iPhone SE 2020 Battery Replacement: step 36, image 3 of 3
      • Repeat the above steps to remove the remaining three adhesive strips.
      • Be sure to hold onto the battery as you remove the final strip, or it may fling out of the iPhone unexpectedly.
      • If you removed all of the adhesive strips successfully, skip the next step.
      • If any of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
      Ask FixBot
    5. iPhone SE 2020 Battery Replacement: step 37, image 1 of 2 iPhone SE 2020 Battery Replacement: step 37, image 2 of 2
      • If any of the adhesive strips broke off and the battery remains stuck to the rear case, remove it by adding a few drops of isopropyl alcohol (90% or greater) underneath the battery near the stuck strip(s). After about a minute, gently lift the battery.
      • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
      • If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
      • If the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. This will help soften the adhesive.
      • Heat the iPhone until the rear case is slightly too hot to comfortably touch. Don't overheat the iPhone, or you may accidentally ignite the battery.
      • Alternatively, thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
      • Pull the string from side to side in a sawing motion all along the length of the battery to separate the adhesive. Do not deform or damage the battery.
      • To protect your fingers, wear gloves or wrap the string ends around a tool (such as the two screwdriver handles shown in the image).
      Ask FixBot
    6. iPhone SE 2020 Battery Replacement, Remove the battery: step 38, image 1 of 1
      • Remove the battery from the iPhone.
      • If your replacement battery came in a plastic sleeve, slide off and remove the sleeve before installation.
      • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
      • If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
      • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
      • Before you adhere the replacement battery, temporarily reconnect the battery connector to the logic board socket. This ensures that the battery is properly aligned in its recess.
      • Adhere the battery, disconnect it, and continue reassembling your device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Don't forget to reapply the display adhesive before reinstalling the display.
Repair didn’t go as planned? Check out our iPhone SE 2020 Answers community for troubleshooting help.
232 other people completed this guide.
Author
with
Adam O'Camb
226,699 Reputation
415 Guides authored
46 Guide Comments
Quick question on this guide, and maybe I missed the listing on this one, but like the iPhone 11, will this give you that message regarding the battery not being an apple part if you replace the battery?
Bryant Alvarez - Reply Share
It might considering Apple is stooping to these antics.
https://www.ifixit.com/News/33147/apple-...
Imagine that. Your display breaks, by accident or by carelessness - no matter, you want to fix your own display or take it someplace that isn’t “Apple Authorized” and because you don’t go directly to Apple’s den of thieves, they pull this on you. You don’t want to pay out the yingyang? I guess you’ve got a faulty display then!
(Look, I get it. They do this to save their own butts legally. That does not make it right.)
Jesse - Reply Share
I’ve looked at both the original SE and this next generation SE and I’m wondering if it’s really necessary to remove the entire display. I realize if the phone has its original battery in it that it likely is but if you’ve replaced it once before I don’t see why it’d be necessary to remove the display, just remove the battery itself and then you have less work. Maybe I’m missing something?
Jesse - Reply Share
You would run the risk of tearing the flexes. It is totally worth the time removing the screen.
Daniel Allen - Reply Share
if i put another new battery in se 2020, is this message come “non genuine battery warning”
Imran Khan - Reply Share
Past 24 Hours: 163
Past 7 Days: 1,241
Past 30 Days: 5,677
All Time: 445,345
