Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Overview
why!'s 14" model is the ideal travel companion: lightweight (less than 1.2 kg), it has a very long battery life thanks to its particularly efficient AlderLake generation processor and its large battery.
Its power is more than sufficient for all office work as well as for surfing the web. It is, however, possible to add 8 GB of RAM to the 8 GB installed by default.
Specifications
Operating system
Operating system: Ubuntu
Version: 22.04 LTS
Architecture: 64 bit
Processor
Processor family: AlderLake
Processor type: Intel Core i5-1235U
Processor speed: 1.30 GHz
Max processor speed: 4.40 GHz
RAM
RAM - Default: 8 GB (1x 8 GB) SO-DDR4-3200 MHz
RAM - Additional: 8GB (1x 8 GB) SO-DDR4-3200 / 16 GB (1x 16 GB) SO-DDR4-3200 / 32 GB (1x 32 GB) SO-DDR4-3200
Graphics card
Brand: Intel
Model: Intel® Iris Xe Graphics
Screen
Image resolution: Full HD 1920x1080
Aspect ratio: 16:9
Screen size: 14"
Screen technology: IPS Panel
Storage slot 1
M.2 SSD - Default: 250 GB
M.2 SSD - Available: 500 GB / 1 TB / 2 TB
Optical drive
Optical drive type: -
SD card reader
SD card type: MicroSD Card Reader
Connectivity
Ports: 1x USB 3.2 Gen 1 Type A, 1x USB 3.2 Gen 2 Type A
Ethernet port: 1x RJ45
Video port: 1x HDMI
Audio / Microphone socket: 1x 3.5 mm jack
Audio
Audio channel: Stereo
Built-in microphone: 1x
Webcam
Front webcam: Yes
Resolution: 1.0 Mpx HD
Wireless transmission
Bluetooth: Yes
Bluetooth version: 5.3
Wifi: Yes
Wifi standard: 802.11a, 802.11ac, 802.11b, 802.11g, 802.11n
Keyboard
Backlit keyboard: yes
Keyboard layout: AZERTY-FR or QWERTZ-CH
Numeric keypad: No
Battery/power properties
Battery capacity: 73 Wh
Power supply: 19 V, 65 W, Efficency Level V
Housing properties
Color: Aluminum gray
Dimensions
Weight: 1.15 kg
Depth: 216.8mm
Width: 322mm
Front thickness: 20 mm
Rear thickness: 31 mm
Warranty
Warranty duration: 2 years (Only 6 months for the battery)
Sustainability
Power consumption on: 8.2 W
Standby power consumption: 0.8 W
Off power consumption: 0.3 W
Repairability
Replaced in less than 10 min:
  • Memory
  • Screen
  • Storage space
  • Webcam and microphone
  • Wifi Bluetooth chipset
  • Keyboard
  • BIOS battery
Replaced in less than 30 min:
  • Motherboard (including soldered processor and RAM)
Additional information
Special thanks to these translators:
fr en
100%
Clay Eickemeyer is helping us fix the world! Want to contribute?
Start translating ›
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 53
All Time: 1,511
