This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
why! L140/1PU right hinge replacement
    1. why! L140/1PU right hinge replacement, Cover: step 1, image 1 of 2 why! L140/1PU right hinge replacement, Cover: step 1, image 2 of 2
      • Unscrew the screws.
      • Lift the cover.
      Ask FixBot
    1. why! L140/1PU right hinge replacement, Disconnection: step 2, image 1 of 2 why! L140/1PU right hinge replacement, Disconnection: step 2, image 2 of 2
      • For safety reasons, the battery must be disconnected before each intervention.
      • Disconnect the battery your fingers.
      • Other components can now be replaced safely.
      Ask FixBot
    1. why! L140/1PU right hinge replacement, Upper frame 1: step 3, image 1 of 3 why! L140/1PU right hinge replacement, Upper frame 1: step 3, image 2 of 3 why! L140/1PU right hinge replacement, Upper frame 1: step 3, image 3 of 3
      • The zones we will focus on are indicated.
      • Unplug the screen cable.
      • Unscrew the screw of the cover and those of the hinge. Remove the cover.
      Ask FixBot
    2. why! L140/1PU right hinge replacement, Upper frame 2: step 4, image 1 of 3 why! L140/1PU right hinge replacement, Upper frame 2: step 4, image 2 of 3 why! L140/1PU right hinge replacement, Upper frame 2: step 4, image 3 of 3
      • Unscrew the screw of the cover, as well as those of the clutch hinge. Remove the cover.
      • Unplug the Wifi cables.
      Ask FixBot
    3. why! L140/1PU right hinge replacement, Upper frame 3: step 5, image 1 of 3 why! L140/1PU right hinge replacement, Upper frame 3: step 5, image 2 of 3 why! L140/1PU right hinge replacement, Upper frame 3: step 5, image 3 of 3
      • Unplug the camera cable.
      • Open the two hinges.
      Ask FixBot
    4. why! L140/1PU right hinge replacement, Upper frame 4: step 6, image 1 of 3 why! L140/1PU right hinge replacement, Upper frame 4: step 6, image 2 of 3 why! L140/1PU right hinge replacement, Upper frame 4: step 6, image 3 of 3
      • Remove the upper case, separating it from the screen.
      • Using a hair dryer, blow hot air around the screen to soften the frame's adhesive.
      • In order to avoid damaging components, never keep the hair dryer aimed at the same spot.
      Ask FixBot
    5. why! L140/1PU right hinge replacement, Upper Frame 5: step 7, image 1 of 3 why! L140/1PU right hinge replacement, Upper Frame 5: step 7, image 2 of 3 why! L140/1PU right hinge replacement, Upper Frame 5: step 7, image 3 of 3
      • Separate the frame.
      • You can use the iFixit opening pick for this, or just your fingernails.
      Ask FixBot
    6. why! L140/1PU right hinge replacement: step 8, image 1 of 2 why! L140/1PU right hinge replacement: step 8, image 2 of 2
      • Remove the upper frame of the screen.
      Ask FixBot
    1. why! L140/1PU right hinge replacement, Lower screen 1: step 9, image 1 of 2 why! L140/1PU right hinge replacement, Lower screen 1: step 9, image 2 of 2
      • Unscrew the two screws circled in red.
      Ask FixBot
    2. why! L140/1PU right hinge replacement, Lower frame 2: step 10, image 1 of 3 why! L140/1PU right hinge replacement, Lower frame 2: step 10, image 2 of 3 why! L140/1PU right hinge replacement, Lower frame 2: step 10, image 3 of 3
      • Detach the lower frame from the screen.
      Ask FixBot
    1. why! L140/1PU right hinge replacement, Screen 1: step 11, image 1 of 3 why! L140/1PU right hinge replacement, Screen 1: step 11, image 2 of 3 why! L140/1PU right hinge replacement, Screen 1: step 11, image 3 of 3
      • Remove the four strips of tape.
      Ask FixBot
    2. why! L140/1PU right hinge replacement, Screen 2: step 12, image 1 of 3 why! L140/1PU right hinge replacement, Screen 2: step 12, image 2 of 3 why! L140/1PU right hinge replacement, Screen 2: step 12, image 3 of 3
      • Using tweezers, grasp and gently pull the tape.
      Ask FixBot
    3. why! L140/1PU right hinge replacement, Screen 3: step 13, image 1 of 3 why! L140/1PU right hinge replacement, Screen 3: step 13, image 2 of 3 why! L140/1PU right hinge replacement, Screen 3: step 13, image 3 of 3
      • Pull the tape until it is freed. Repeat on all 3 other sides.
      • Lift up the screen.
      Ask FixBot
    4. why! L140/1PU right hinge replacement, Screen 4: step 14, image 1 of 3 why! L140/1PU right hinge replacement, Screen 4: step 14, image 2 of 3 why! L140/1PU right hinge replacement, Screen 4: step 14, image 3 of 3
      • Remove the tape.
      • Remove the screen cable.
      Ask FixBot
    1. why! L140/1PU right hinge replacement, EDP: step 15, image 1 of 2 why! L140/1PU right hinge replacement, EDP: step 15, image 2 of 2
      • Release the cable and remove it.
      Ask FixBot
    1. why! L140/1PU right hinge replacement, Right hinge: step 16, image 1 of 3 why! L140/1PU right hinge replacement, Right hinge: step 16, image 2 of 3 why! L140/1PU right hinge replacement, Right hinge: step 16, image 3 of 3
      • Unscrew all three screws.
      • Move the cables.
      • Remove the hinge.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 55
All Time: 279
