Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
why! L141PU Power Button Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
69
All Time:
754
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 hours
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide shows you how to replace the power button of a why! L141PU laptop.
    1. why! L141PU Power Button Replacement, Cover: step 1, image 1 of 2 why! L141PU Power Button Replacement, Cover: step 1, image 2 of 2
      • Unscrew the screws.
      • Lift the cover.
      Ask FixBot
    1. why! L141PU Power Button Replacement, Disconnection: step 2, image 1 of 2 why! L141PU Power Button Replacement, Disconnection: step 2, image 2 of 2
      • For safety reasons, the battery must be disconnected before each intervention.
      • Disconnect the battery your fingers.
      • Other components can now be replaced safely.
      Ask FixBot
    1. why! L141PU Power Button Replacement, RAM: step 3, image 1 of 3 why! L141PU Power Button Replacement, RAM: step 3, image 2 of 3 why! L141PU Power Button Replacement, RAM: step 3, image 3 of 3
      • press the plastic latches slightly to the sides (red arrows) to free the memory stick,
      • The memory stick will 'pop up' on its own
      • Remove the memory stick.
      Ask FixBot
    1. why! L141PU Power Button Replacement, SSD1: step 4, image 1 of 3 why! L141PU Power Button Replacement, SSD1: step 4, image 2 of 3 why! L141PU Power Button Replacement, SSD1: step 4, image 3 of 3
      • Unscrew the screw.
      • The SSD will lift by itself.
      • Remove the SSD.
      Ask FixBot
    1. why! L141PU Power Button Replacement, SSD2: step 5, image 1 of 3 why! L141PU Power Button Replacement, SSD2: step 5, image 2 of 3 why! L141PU Power Button Replacement, SSD2: step 5, image 3 of 3
      • Remove the SSD.
      Ask FixBot
    1. why! L141PU Power Button Replacement, WiFi Card: step 6, image 1 of 3 why! L141PU Power Button Replacement, WiFi Card: step 6, image 2 of 3 why! L141PU Power Button Replacement, WiFi Card: step 6, image 3 of 3
      • Peel up the label without completely removing it.
      • Remove the two antenna leads in the red rectangle. The red arrow might appear to indicate pulling away from the card... NO. they clip on, pry them UP gently. DO NOT pull on the wires, the connectors are delicate.
      Ask FixBot
    2. why! L141PU Power Button Replacement, WiFi Card: step 7, image 1 of 3 why! L141PU Power Button Replacement, WiFi Card: step 7, image 2 of 3 why! L141PU Power Button Replacement, WiFi Card: step 7, image 3 of 3
      • Remove the screw (red circle)
      • Pull out the WiFi card. (red arrows)
      Ask FixBot
    1. why! L141PU Power Button Replacement, Right Speaker: step 8, image 1 of 3 why! L141PU Power Button Replacement, Right Speaker: step 8, image 2 of 3 why! L141PU Power Button Replacement, Right Speaker: step 8, image 3 of 3
      • Remove the bottom of the speaker, (red arrow) then the top.
      • Unplug the connector, third photo, red rectangle
      Ask FixBot
    1. why! L141PU Power Button Replacement, Battery 1: step 9, image 1 of 1
      • There are 6 adhesive strips.
      Ask FixBot
    2. why! L141PU Power Button Replacement, Battery 2: step 10, image 1 of 3 why! L141PU Power Button Replacement, Battery 2: step 10, image 2 of 3 why! L141PU Power Button Replacement, Battery 2: step 10, image 3 of 3
      • You have to pull gently and steadily as indicated by the red arrows to remove them.
      Ask FixBot
    3. why! L141PU Power Button Replacement, Battery 3: step 11, image 1 of 3 why! L141PU Power Button Replacement, Battery 3: step 11, image 2 of 3 why! L141PU Power Button Replacement, Battery 3: step 11, image 3 of 3
      • Repeat on the other five tapes...
      Ask FixBot
    4. why! L141PU Power Button Replacement, Battery 4: step 12, image 1 of 2 why! L141PU Power Button Replacement, Battery 4: step 12, image 2 of 2
      • Remove the battery. (Lifting as per red arrows)
      Ask FixBot
    1. why! L141PU Power Button Replacement, Heatsink/Fan Assembly 1: step 13, image 1 of 3 why! L141PU Power Button Replacement, Heatsink/Fan Assembly 1: step 13, image 2 of 3 why! L141PU Power Button Replacement, Heatsink/Fan Assembly 1: step 13, image 3 of 3
      • Unscrew the two screws on the fan in numerical order according to the red boxes. (a bit at a time to keep pressure equal on underlying components is best practice)
      • Unscrew the three screws on the radiator in numerical order according to the red boxes. (a bit at a time to keep pressure equal on underlying components is best practice)
      Ask FixBot
    2. why! L141PU Power Button Replacement, Heatsink/Fan Assembly 2: step 14, image 1 of 2 why! L141PU Power Button Replacement, Heatsink/Fan Assembly 2: step 14, image 2 of 2
      • Unplug the fan (red rectangle)
      • Remove the Heatsink/Fan Assembly. Pull carefully as indicated by the red arrows. Exercise caution not to damage the fragile cooling fins.
      • Under the heatsink is the processor, check if you need to put thermal paste back in when reassembling. (Translator Note: You really should clean and replace it to prevent overheating and optimize performance.)
      Ask FixBot
    1. why! L141PU Power Button Replacement, Mother Board 1: step 15, image 1 of 3 why! L141PU Power Button Replacement, Mother Board 1: step 15, image 2 of 3 why! L141PU Power Button Replacement, Mother Board 1: step 15, image 3 of 3
      • In the first photo the fours screw circled in red must be removed.
      • Next (red rectangles) disconnect the left speaker lead and the CMOS battery connector (red arrow).
      Ask FixBot
    2. why! L141PU Power Button Replacement, Mother Board 2: step 16, image 1 of 2 why! L141PU Power Button Replacement, Mother Board 2: step 16, image 2 of 2
      • Disconnect the Camera (red square and red arrow)
      Ask FixBot
    3. why! L141PU Power Button Replacement, Mother Board 3: step 17, image 1 of 3 why! L141PU Power Button Replacement, Mother Board 3: step 17, image 2 of 3 why! L141PU Power Button Replacement, Mother Board 3: step 17, image 3 of 3
      • Disconnect the screen ribbon cable (red rectangle).
      Ask FixBot
    4. why! L141PU Power Button Replacement, Mother Board 4: step 18, image 1 of 3 why! L141PU Power Button Replacement, Mother Board 4: step 18, image 2 of 3 why! L141PU Power Button Replacement, Mother Board 4: step 18, image 3 of 3
      • Disconnect the flat ribbon cables for the keyboard and touchpad. (red rectangle) AFTER you open the latches, see below.
      • Carefully lift open the latches in the direction of the orange arrows. Be careful, they are delicate and with increasing age ever more so!
      • Remove the cables in the direction of the red arrows.
      Ask FixBot
    5. why! L141PU Power Button Replacement, Mother Board 5: step 19, image 1 of 2 why! L141PU Power Button Replacement, Mother Board 5: step 19, image 2 of 2
      • Carefully lift the Mother Board and gently remove it. The red arrows might be a bit ambiguous here... lift, but you may need to pull such things as ports etc, free to enable your lifting...
      Ask FixBot
    1. why! L141PU Power Button Replacement, PW Button: step 20, image 1 of 3 why! L141PU Power Button Replacement, PW Button: step 20, image 2 of 3 why! L141PU Power Button Replacement, PW Button: step 20, image 3 of 3
      • Using the Spudger, pry the part so that you can grasp it with your fingers.
      • Remove the part.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Author
with
Felice Suglia
33,655 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 69
All Time: 754
