This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
This guide shows you how to replace the trackpad of a why! L140/1PU by accessing the keyboard to disconnect its cable, before sliding it out of the frame.
Remove the bottom of the speaker, (red arrow) then the top.
Unplug the connector, third photo, red rectangle
You have to pull gently and steadily as indicated by the red arrows to remove them.
Peel off the adhesive strip from the keyboard.
Unscrew the 3 screws.
Slightly open the cover.
Gently lift the trackpad by pushing it from underneath.
Slide the trackpad in the direction of the orange arrow to remove it.
To reassemble your device, follow the instructions in reverse order.
