This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
why! L140/1PU CMOS battery replacement
    1. why! L140/1PU CMOS battery replacement, Back cover: step 1, image 1 of 2 why! L140/1PU CMOS battery replacement, Back cover: step 1, image 2 of 2
      • Remove the screws.
      • Lift the cover.
      Ask FixBot
    1. why! L140/1PU CMOS battery replacement, Disconnection: step 2, image 1 of 2 why! L140/1PU CMOS battery replacement, Disconnection: step 2, image 2 of 2
      • For safety reasons, the battery must be disconnected before each intervention.
      • Disconnect the battery your fingers.
      • Other components can now be replaced safely.
      Ask FixBot
    1. why! L140/1PU CMOS battery replacement, SSD1: step 3, image 1 of 3 why! L140/1PU CMOS battery replacement, SSD1: step 3, image 2 of 3 why! L140/1PU CMOS battery replacement, SSD1: step 3, image 3 of 3
      • Unscrew the screw.
      • The SSD will lift by itself.
      • Remove the SSD.
      Ask FixBot
    1. why! L140/1PU CMOS battery replacement, CMOS 1: step 4, image 1 of 3 why! L140/1PU CMOS battery replacement, CMOS 1: step 4, image 2 of 3 why! L140/1PU CMOS battery replacement, CMOS 1: step 4, image 3 of 3
      • Peel off the adhesive tape.
      • Using a spudger, carefully peel off the battery.
      Ask FixBot
    2. why! L140/1PU CMOS battery replacement, CMOS 2: step 5, image 1 of 3 why! L140/1PU CMOS battery replacement, CMOS 2: step 5, image 2 of 3 why! L140/1PU CMOS battery replacement, CMOS 2: step 5, image 3 of 3
      • After carefully peeling off the battery, disconnect the cable.
      • The adhesive strip is located under the battery and is circled in orange.
      Ask FixBot
To reassemble your device, follow the steps in reverse order.
Special thanks to these translators:
fr en
71%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 29
All Time: 474
