AirPort Antenna
3 Answers 4 Score |
What adhesive is safe to use for keyboard rubber cap under spacebar? |
10 Answers 6 Score |
Thunderbolt Port not working correctly! |
7 Answers 5 Score |
MacBook Pro 17" early 2011, possible revival? |
4 Answers 3 Score |
Why is my new battery's health dropping so quickly!? |
Parts
- Apple MagSafe 1 AC Adapter
- MacBook and MacBook Pro Unibody Plastic Feet
- MacBook Pro Unibody Lower Case Screw Set
- 2.5" Hard Drive Enclosure with USB 3.0 Cable
- MacBook and MacBook Pro (Non-Retina) SSD Upgrade Kit
- MacBook Pro Unibody (A1278, A1286, A1297) Key Caps
- MacBook Pro Unibody Lower Case Screw and Foot Kit
- G4/MagSafe AC Adapter End
Tools
- Spudger
- Essential Electronics Toolkit
- iFixit Opening Picks (Set of 6)
- Tweezers
- iFixit Opening Tool
- Phillips #00 Screwdriver
- iFixit Thermal Paste
- Heat Gun
- T5 Torx Screwdriver
- Tri-point Y0 Screwdriver
- Phillips #000 Screwdriver
- Tri-point Y1 Screwdriver
- Heavy-Duty Suction Cups (Pair)
- Adhesive Cleanup Kit (Set of 12)
- Arctic Silver ArctiClean
- T6 Torx Screwdriver
Models
A1297 (EMC 2272 MacBookPro5,2) 2.66 GHz (Early 2009), A1297 (EMC 2272 MacBookPro5,2) 2.93 GHz (Early 2009), A1297 (EMC 2329 MacBookPro5,2) 2.8 GHz (Mid 2009), A1297 (EMC 2329 MacBookPro5,2) 3.06 GHz (Mid 2009), A1297 (EMC 2352 MacBookPro6,1) 2.53 GHz (Mid 2010), A1297 (EMC 2352 MacBookPro6,1) 2.66 GHz (Mid 2010), A1297 (EMC 2352 MacBookPro6,1) 2.8 GHz (Mid 2010), A1297 (EMC 2352-1 MacBookPro8,3) 2.2 GHz (Early 2011), A1297 (EMC 2352-1 MacBookPro8,3) 2.3 GHz (Early 2011), A1297 (EMC 2564 MacBookPro8,3) 2.4 GHz Late 2011, A1297 (EMC 2564 MacBookPro8,3) 2.5 GHz Late 2011
Upgrades
There are a number of components in the MacBook Pro 17" Unibody that can be cost-effectively upgraded.
- Memory: MacBook Pro 17" Unibodys come with 4 GB standard. If your MacBook Pro 17" Unibody is still running with only the stock RAM, upgrading to 8 GB will provide a performance boost. User tests have proved that installing Mavericks can enable an upgrade to 16 GB when combined with proper downclocking.
- Hard Drive: 500 Gigabyte hard drives came standard with the MacBook Pro 17" Unibody. You can easily upgrade the drive to 750 GB.
Identification and Background
The MacBook Pro 17" Unibody was announced in January of 2009. The MacBook Pro 17" Unibody looks very distinct from other MacBook laptops, with the exception of the MacBook Unibody and MacBook Pro 15" Unibody. The MacBook Pro 17" Unibody is easily identifiable from the other two models by having a 17" screen, as opposed to a 13" or 15" screen.
MacBooks tend to look very similar, and it's important to know which machine you have before ordering any replacement parts. Check your machine against the details in this section. If they don't match, find your model under MacBook Pro 17" and check the Identification section on its page.
The MacBook Pro 17" Unibody's case is composed of aluminum, just like the laptops before it. However, the case is machined out of a single block of aluminum, following the same process of the MacBook Unibody and the MacBook Pro 15" Unibody. The Unibody revision also introduced some features that were never before seen on an Apple laptop: the inclusion of dual video cards (one for regular use, one for graphics intensive applications) the Mini DisplayPort (which replaced the full-size DVI display connector), and larger hard drive and RAM capacities.
Tech Specs
Factory specs for each model are available at the following links.
