MacBook Pro 17" Unibody Hard Drive Cable Replacement
    1. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Lower Case: step 1, image 1 of 1
      • Seven 3 mm Phillips screws.
      Ask FixBot
    2. MacBook Pro 17" Unibody Hard Drive Cable Replacement: step 2, image 1 of 2 MacBook Pro 17" Unibody Hard Drive Cable Replacement: step 2, image 2 of 2
      • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
      • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
      • Remove the lower case.
      Ask FixBot
    1. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: step 3, image 1 of 3 MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: step 3, image 2 of 3 MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: step 3, image 3 of 3
      • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
      • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
      • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
      • Pull the tab parallel to the face of the logic board.
      Ask FixBot
    1. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive: step 4, image 1 of 1
      • Remove the two Phillips screws securing the hard drive bracket to the upper case.
      • These screws are captive to the hard drive bracket.
      Ask FixBot
    2. MacBook Pro 17" Unibody Hard Drive Cable Replacement: step 5, image 1 of 1
      • Remove the hard drive bracket from the upper case.
      Ask FixBot
    3. MacBook Pro 17" Unibody Hard Drive Cable Replacement: step 6, image 1 of 1
      • Use the hard drive's pull tab to lift it out of the upper case.
      • Don't try to completely remove the hard drive just yet! Its cable is still connected.
      Ask FixBot
    4. MacBook Pro 17" Unibody Hard Drive Cable Replacement: step 7, image 1 of 2 MacBook Pro 17" Unibody Hard Drive Cable Replacement: step 7, image 2 of 2
      • Pull the hard drive connector away from the body of the hard drive.
      • Remove the hard drive from your MacBook Pro.
      Ask FixBot
    1. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive Cable: step 8, image 1 of 2 MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive Cable: step 8, image 2 of 2
      • Remove the following four screws securing the hard drive cable assembly to the upper case:
      • Two 1.6 mm Phillips screws securing the shield that covers the hard drive cable connector.
      • Two 2.2 mm Phillips screws securing the hard drive cable connector to the upper case.
      • Remove the shield from the logic board.
      Ask FixBot
    2. MacBook Pro 17" Unibody Hard Drive Cable Replacement: step 9, image 1 of 1
      • Use the flat end of a spudger to pry the hard drive connector up and out of its socket on the logic board.
      Ask FixBot
    3. MacBook Pro 17" Unibody Hard Drive Cable Replacement: step 10, image 1 of 1
      • Lift the hard drive cable out of the upper case.
      Ask FixBot
16 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 139
All Time: 21,459
