MacBook Pro 17" Unibody Hard Drive Bracket Replacement
    1. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Lower Case: step 1, image 1 of 1
      • Seven 3 mm Phillips screws.
      Ask FixBot
    2. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: step 2, image 1 of 2 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: step 2, image 2 of 2
      • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
      • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
      • Remove the lower case.
      Ask FixBot
    1. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: step 3, image 1 of 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: step 3, image 2 of 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: step 3, image 3 of 3
      • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
      • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
      • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
      • Pull the tab parallel to the face of the logic board.
      Ask FixBot
    1. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Hard Drive: step 4, image 1 of 1
      • Remove the two Phillips screws securing the hard drive bracket to the upper case.
      • These screws are captive to the hard drive bracket.
      Ask FixBot
    2. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: step 5, image 1 of 1
      • Remove the hard drive bracket from the upper case.
      Ask FixBot
    3. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: step 6, image 1 of 1
      • Use the hard drive's pull tab to lift it out of the upper case.
      • Don't try to completely remove the hard drive just yet! Its cable is still connected.
      Ask FixBot
    4. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: step 7, image 1 of 2 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: step 7, image 2 of 2
      • Pull the hard drive connector away from the body of the hard drive.
      • Remove the hard drive from your MacBook Pro.
      Ask FixBot
    1. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Hard Drive Bracket: step 8, image 1 of 1
      • Remove the two 5 mm Phillips #00 screws securing the hard drive bracket to the upper case.
      Ask FixBot
    2. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: step 9, image 1 of 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: step 9, image 2 of 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: step 9, image 3 of 3
      • Tilt the outer hard drive bracket up toward the logic board and remove it from the rear case.
      Ask FixBot
10 other people completed this guide.
Sam Goldheart
478,462 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 128
All Time: 5,836
