MacBook Pro 17" Unibody Upper Case Replacement
    1. MacBook Pro 17" Unibody Upper Case Replacement, Lower Case: step 1, image 1 of 1
      • Seven 3 mm Phillips screws.
      Ask FixBot
    2. MacBook Pro 17" Unibody Upper Case Replacement: step 2, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 2, image 2 of 2
      • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
      • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
      • Remove the lower case.
      Ask FixBot
    1. MacBook Pro 17" Unibody Upper Case Replacement, Battery: step 3, image 1 of 3 MacBook Pro 17" Unibody Upper Case Replacement, Battery: step 3, image 2 of 3 MacBook Pro 17" Unibody Upper Case Replacement, Battery: step 3, image 3 of 3
      • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
      • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
      • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
      • Pull the tab parallel to the face of the logic board.
      Ask FixBot
    1. MacBook Pro 17" Unibody Upper Case Replacement, Right Fan: step 4, image 1 of 3 MacBook Pro 17" Unibody Upper Case Replacement, Right Fan: step 4, image 2 of 3 MacBook Pro 17" Unibody Upper Case Replacement, Right Fan: step 4, image 3 of 3
      • Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
      • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
      • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
      Ask FixBot
    2. MacBook Pro 17" Unibody Upper Case Replacement: step 5, image 1 of 1
      • Remove the three 3.1 mm Phillips screws securing the right fan to the logic board.
      • In the Late 2011 MacBook Pro 17" Unibody these screws will be T6 Torx.
      Ask FixBot
    3. MacBook Pro 17" Unibody Upper Case Replacement: step 6, image 1 of 1
      • Remove the right fan from the upper case, minding its cable that may get caught.
      Ask FixBot
    1. MacBook Pro 17" Unibody Upper Case Replacement, Logic Board: step 7, image 1 of 1
      • Use the flat end of a spudger to lift the left fan connector out of its socket on the logic board.
      Ask FixBot
    2. MacBook Pro 17" Unibody Upper Case Replacement: step 8, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 8, image 2 of 2
      • Remove the three 3.1 mm Phillips screws securing the left fan to the logic board.
      • Remove the left fan from the upper case, minding its cable that may get caught.
      Ask FixBot
    3. MacBook Pro 17" Unibody Upper Case Replacement: step 9, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 9, image 2 of 2
      • Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable.
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • Pull the keyboard backlight ribbon cable out of its socket.
      Ask FixBot
    4. MacBook Pro 17" Unibody Upper Case Replacement: step 10, image 1 of 1
      • Before disconnecting the camera cable, a small plastic retainer stuck to the logic board must first be moved out of the way.
      • Use the tip of a spudger to push the small plastic cable retainer away from the camera cable socket for enough clearance to remove the camera cable.
      Ask FixBot
    5. MacBook Pro 17" Unibody Upper Case Replacement: step 11, image 1 of 1
      • Pull the camera cable toward the optical drive opening to disconnect it from the logic board.
      • The camera cable socket is very fragile. Do not apply any upward force to this socket, as it may break off the logic board. Pull the camera cable parallel to the face of the logic board.
      Ask FixBot
    6. MacBook Pro 17" Unibody Upper Case Replacement: step 12, image 1 of 1
      • Use the flat end of a spudger to pry the optical drive connector up and out of its socket on the logic board.
      Ask FixBot
    7. MacBook Pro 17" Unibody Upper Case Replacement: step 13, image 1 of 1
      • Use the flat end of a spudger to lift the subwoofer & right speaker connector out of its socket on the logic board.
      • Pry up from beneath the wires.
      Ask FixBot
    8. MacBook Pro 17" Unibody Upper Case Replacement: step 14, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 14, image 2 of 2
      • Use the tip of a spudger or your fingernail to flip up the retaining flap on the IR sensor ribbon cable socket.
      • Pull the IR sensor ribbon cable out of its socket.
      Ask FixBot
    9. MacBook Pro 17" Unibody Upper Case Replacement: step 15, image 1 of 3 MacBook Pro 17" Unibody Upper Case Replacement: step 15, image 2 of 3 MacBook Pro 17" Unibody Upper Case Replacement: step 15, image 3 of 3
      • Remove the following four screws:
      • Two 3.5 mm Phillips screws
      • These may be T5 Torx screws in the Early 2011 model
      • Two 1.6 mm Phillips screws
      • Remove both connector shields from the logic board.
      Ask FixBot
    10. MacBook Pro 17" Unibody Upper Case Replacement: step 16, image 1 of 1
      • Use the flat end of a spudger to pry the trackpad connector up and out of its socket on the logic board.
      Ask FixBot
    11. MacBook Pro 17" Unibody Upper Case Replacement: step 17, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 17, image 2 of 2
      • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable socket.
      • Pull the keyboard ribbon cable out of its socket.
      • For reassembly, it can be helpful to put a small piece of tape on the keyboard ribbon cable (being careful not to stick any to the contacts), to create a small handle. Align the cable with the socket and gently pull with the tape to fully seat it.
      Ask FixBot
    12. MacBook Pro 17" Unibody Upper Case Replacement: step 18, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 18, image 2 of 2
      • Use your fingernail to flip up the retaining flap on the express card cage ribbon cable socket.
      • Pull the express card cage ribbon cable out of its socket.
      Ask FixBot
    13. MacBook Pro 17" Unibody Upper Case Replacement: step 19, image 1 of 1
      • Use the flat end of a spudger to lift the hard drive cable connector up and out of its socket on the logic board.
      Ask FixBot
    14. MacBook Pro 17" Unibody Upper Case Replacement: step 20, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 20, image 2 of 2
      • Use the tip of a spudger or your fingernail to flip up the retaining flap on the battery indicator cable socket.
      • Pull the battery indicator ribbon cable out of its socket.
      Ask FixBot
    15. MacBook Pro 17" Unibody Upper Case Replacement: step 21, image 1 of 3 MacBook Pro 17" Unibody Upper Case Replacement: step 21, image 2 of 3 MacBook Pro 17" Unibody Upper Case Replacement: step 21, image 3 of 3
      • Lift the black plastic flap attached to the display data cable retainer and rotate it toward the DC-In side of the MacBook.
      • Pull the display data cable out of its socket.
      • The display data cable socket is very fragile. Do not lift the connector upward as you disconnect it, as the socket may break off the logic board. Pull the cable parallel to the face of the logic board.
      Ask FixBot
    16. MacBook Pro 17" Unibody Upper Case Replacement: step 22, image 1 of 1
      • Remove the following eight screws securing the logic board and DC-In board to the upper case:
      • Six 3.2 mm Phillips screws
      • These may be T6 Torx screws on the Early 2011 model.
      • Two 7.6 mm Phillips screws
      Ask FixBot
    17. MacBook Pro 17" Unibody Upper Case Replacement: step 23, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 23, image 2 of 2
      • Handle the logic board assembly by its edges only.
      • Lift the logic board assembly from the side nearest the optical drive and lift it away from the upper case.
      • Note that you'll be removing the logic board and DC-in board together.
      • Carefully pull the ports and DC-In board away from the side of the upper case and remove the logic board assembly, minding any cables that may get caught.
      Ask FixBot
    1. MacBook Pro 17" Unibody Upper Case Replacement, Express Card Cage: step 24, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement, Express Card Cage: step 24, image 2 of 2
      • Remove the two Phillips screws securing the hard drive bracket to the upper case.
      • Both screws are captive to the hard drive bracket.
      • Remove the hard drive bracket from the upper case.
      Ask FixBot
    2. MacBook Pro 17" Unibody Upper Case Replacement: step 25, image 1 of 1
      • Peel the hard drive and battery indicator cables off the adhesive securing them to the express card cage.
      Ask FixBot
    3. MacBook Pro 17" Unibody Upper Case Replacement: step 26, image 1 of 1
      • Remove the following five screws securing the express card cage to the upper case:
      • Three 2 mm Phillips screws
      • Two 4 mm Phillips screws
      Ask FixBot
    4. MacBook Pro 17" Unibody Upper Case Replacement: step 27, image 1 of 1
      • Remove the express card cage from the upper case.
      Ask FixBot
    1. MacBook Pro 17" Unibody Upper Case Replacement, Upper Case: step 28, image 1 of 1
      • Using its attached pull tab, lift the hard drive out of the upper case.
      • Do not try to completely remove the hard drive just yet! The hard drive cable is still attached to the upper case.
      Ask FixBot
    2. MacBook Pro 17" Unibody Upper Case Replacement: step 29, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 29, image 2 of 2
      • Pull the hard drive cable connector away from the body of the hard drive.
      • Remove the hard drive from the upper case and set it aside.
      Ask FixBot
    3. MacBook Pro 17" Unibody Upper Case Replacement: step 30, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 30, image 2 of 2
      • Remove the two 2.2 mm Phillips screws securing the hard drive cable to the upper case.
      • Remove the hard drive cable from the upper case.
      Ask FixBot
    4. MacBook Pro 17" Unibody Upper Case Replacement: step 31, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 31, image 2 of 2
      • Remove the two 10 mm Phillips screws securing the front hard drive bracket to the upper case.
      • Remove the front hard drive bracket.
      Ask FixBot
    5. MacBook Pro 17" Unibody Upper Case Replacement: step 32, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 32, image 2 of 2
      • Use an iPod opening tool or another soft thin-edged tool to carefully lift up a corner of the "Warning: Do not remove the battery" sticker off the right speaker/subwoofer enclosure.
      • Peel the sticker off the right speaker/subwoofer enclosure.
      • It is not necessary to peel the sticker off the battery.
      Ask FixBot
    6. MacBook Pro 17" Unibody Upper Case Replacement: step 33, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 33, image 2 of 2
      • Remove the three 6.5 mm Tri-point screws securing the battery to the upper case.
      • Using its attached pull tab, lift the battery out of the upper case.
      Ask FixBot
    7. MacBook Pro 17" Unibody Upper Case Replacement: step 34, image 1 of 1
      • Carefully disconnect the Bluetooth cable from the Bluetooth board.
      • Pull the cable parallel to the face of the optical drive toward the port openings.
      Ask FixBot
    8. MacBook Pro 17" Unibody Upper Case Replacement: step 35, image 1 of 1
      • Use the flat end of a spudger to peel the thin plastic cover off the top and sides of the Bluetooth board housing.
      Ask FixBot
    9. MacBook Pro 17" Unibody Upper Case Replacement: step 36, image 1 of 1
      • Use the flat end of a spudger to pry the Bluetooth antenna connector up and off its socket on the Bluetooth board.
      Ask FixBot
    10. MacBook Pro 17" Unibody Upper Case Replacement: step 37, image 1 of 1
      • Remove the small piece of EMI foam attached near the Bluetooth board.
      Ask FixBot
    11. MacBook Pro 17" Unibody Upper Case Replacement: step 38, image 1 of 1
      • Remove the three 3.5 mm Phillips screws securing the optical drive to the upper case.
      • To remove the screw closest to the battery, it may be helpful to use a T6 Torx screwdriver to first remove the upper case bracket directly above it.
      Ask FixBot
    12. MacBook Pro 17" Unibody Upper Case Replacement: step 39, image 1 of 1
      • Remove the optical drive assembly from the upper case.
      Ask FixBot
    13. MacBook Pro 17" Unibody Upper Case Replacement: step 40, image 1 of 1
      • Remove the following three screws securing the subwoofer & right speaker to the upper case:
      • One 2.6 mm Phillips screw
      • Two 12.3 mm Phillips screws
      Ask FixBot
    14. MacBook Pro 17" Unibody Upper Case Replacement: step 41, image 1 of 1
      • Remove the subwoofer and right speaker assembly from the upper case.
      Ask FixBot
    15. MacBook Pro 17" Unibody Upper Case Replacement: step 42, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 42, image 2 of 2
      • Remove the two 7.1 mm Phillips screws securing the camera cable retainer to the upper case.
      • Remove the camera cable retainer from the upper case.
      Ask FixBot
    16. MacBook Pro 17" Unibody Upper Case Replacement: step 43, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 43, image 2 of 2
      • Remove the two 7.1 mm Phillips screws securing the display data cable retainer to the upper case.
      • Remove the display data cable retainer.
      Ask FixBot
    17. MacBook Pro 17" Unibody Upper Case Replacement: step 44, image 1 of 2 MacBook Pro 17" Unibody Upper Case Replacement: step 44, image 2 of 2
      • Remove the two outer 6.8 mm T6 Torx screws from each of the two display brackets (four screws total).
      • We purposely have you leave one screw attaching each display bracket to the upper case to aid in future steps.
      Ask FixBot
    18. MacBook Pro 17" Unibody Upper Case Replacement: step 45, image 1 of 1
      • Open your MacBook Pro so the display is perpendicular to the upper case.
      • Place your opened MacBook Pro on a table as pictured.
      • While holding the display and upper case together with your left hand, remove the remaining T6 Torx screw from the lower display bracket.
      Ask FixBot
    19. MacBook Pro 17" Unibody Upper Case Replacement: step 46, image 1 of 1
      • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
      • Remove the last remaining T6 Torx screw securing the display to the upper case.
      Ask FixBot
    20. MacBook Pro 17" Unibody Upper Case Replacement: step 47, image 1 of 3 MacBook Pro 17" Unibody Upper Case Replacement: step 47, image 2 of 3 MacBook Pro 17" Unibody Upper Case Replacement: step 47, image 3 of 3
      • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
      • Rotate the display slightly away from the upper case.
      • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Make sure that any ribbon cables which need to be attached to the logic board are above it and free from getting caught before you screw it into place.
45 other people completed this guide.
4 Guide Comments
Great guide but I would also appreciate a step that shows me how to remove the trackpad safely after everything else, since most of the replacement parts I saw for this don't include trackpads.
Smart PC - Reply Share
Is it possible to replace the keyboard?
brucemadden71 - Reply Share
You could add a note that once the battery is removed, if all you're replacing is the Trackpad, that is when it would be done. No need to take everything out of the case. Other than that, it's a GREAT guide.
csiemen - Reply Share
Great guide! Although I don’t really look forward to replacing the upper case, BUT I will do so confidently thanks to Andrew’s instructions. This was needed because ½ of the backlight is not illuminating AND most importantly because my <right arrow> key stopped working. I saw how involved replacement of the keyboard assembly was and opted instead to replace the upper case with a used grade “A” upper case from a reputable seller.
Glenn Tiedemann - Reply Share
Past 24 Hours: 5
Past 7 Days: 43
Past 30 Days: 173
All Time: 80,201
