MacBook Pro 17" Unibody Feet Replacement
    1. MacBook Pro 17" Unibody Feet Replacement, Lower Case: step 1, image 1 of 1
      • Seven 3 mm Phillips screws.
      Ask FixBot
    2. MacBook Pro 17" Unibody Feet Replacement: step 2, image 1 of 2 MacBook Pro 17" Unibody Feet Replacement: step 2, image 2 of 2
      • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
      • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
      • Remove the lower case.
      Ask FixBot
    1. MacBook Pro 17" Unibody Feet Replacement, Feet: step 3, image 1 of 3 MacBook Pro 17" Unibody Feet Replacement, Feet: step 3, image 2 of 3 MacBook Pro 17" Unibody Feet Replacement, Feet: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Remove any broken or damaged feet.
      • Remove any pieces from the old foot that may have broken off in the foot hole.
      • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
      Ask FixBot
    2. MacBook Pro 17" Unibody Feet Replacement: step 4, image 1 of 1
      • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
      Ask FixBot
    3. MacBook Pro 17" Unibody Feet Replacement: step 5, image 1 of 1
      • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
      Ask FixBot
    4. MacBook Pro 17" Unibody Feet Replacement: step 6, image 1 of 1
      • Peel a replacement foot from the plastic backing.
      Ask FixBot
    5. MacBook Pro 17" Unibody Feet Replacement: step 7, image 1 of 3 MacBook Pro 17" Unibody Feet Replacement: step 7, image 2 of 3 MacBook Pro 17" Unibody Feet Replacement: step 7, image 3 of 3
      • Align the new foot inside the foot pad.
      • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
      • Lay the foot down while keeping it properly aligned.
      • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
      Ask FixBot
    6. MacBook Pro 17" Unibody Feet Replacement: step 8, image 1 of 1
      • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
      • Repeat the last six steps for any broken or damaged feet.
      Ask FixBot
To reassemble the device, replace the lower case and all of the screws.
10 other people completed this guide.
Arthur Shi
351,066 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
2 Guide Comments
I’m not sure if you really need to remove the lower case. It doesn’t really hurt it to do it though, give you a chance to blow out the accumulated dust.
snoakes1 - Reply Share
Great tip. Looks like I was doing it wrong. I’ll try that next time.
lovemymac - Reply Share
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 90
All Time: 3,976
