MacBook Pro 17" Unibody Bluetooth Board Replacement
    1. MacBook Pro 17" Unibody Bluetooth Board Replacement, Lower Case: step 1, image 1 of 1
      • Seven 3 mm Phillips screws.
      Ask FixBot
    2. MacBook Pro 17" Unibody Bluetooth Board Replacement: step 2, image 1 of 2 MacBook Pro 17" Unibody Bluetooth Board Replacement: step 2, image 2 of 2
      • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
      • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
      • Remove the lower case.
      Ask FixBot
    1. MacBook Pro 17" Unibody Bluetooth Board Replacement, Battery: step 3, image 1 of 3 MacBook Pro 17" Unibody Bluetooth Board Replacement, Battery: step 3, image 2 of 3 MacBook Pro 17" Unibody Bluetooth Board Replacement, Battery: step 3, image 3 of 3
      • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
      • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
      • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
      • Pull the tab parallel to the face of the logic board.
      Ask FixBot
    1. MacBook Pro 17" Unibody Bluetooth Board Replacement, Bluetooth Board: step 4, image 1 of 1
      • Carefully pull the Bluetooth cable toward the fans to disconnect it from the Bluetooth board.
      • Pull the cable parallel to the face of the optical drive.
      Ask FixBot
    2. MacBook Pro 17" Unibody Bluetooth Board Replacement: step 5, image 1 of 1
      • Use the flat end of a spudger to peel the thin plastic cover off the top and sides of the Bluetooth board housing.
      Ask FixBot
    3. MacBook Pro 17" Unibody Bluetooth Board Replacement: step 6, image 1 of 1
      • Use the flat end of a spudger to pry the Bluetooth antenna connector up and off its socket on the Bluetooth board.
      Ask FixBot
    4. MacBook Pro 17" Unibody Bluetooth Board Replacement: step 7, image 1 of 1
      • Remove the two 2.2 mm Phillips screws securing the Bluetooth housing to the side of the optical drive.
      Ask FixBot
    5. MacBook Pro 17" Unibody Bluetooth Board Replacement: step 8, image 1 of 1
      • De-route the camera cable from its slot in the Bluetooth housing and remove the Bluetooth board from the upper case.
      Ask FixBot
6 other people completed this guide.
1 Guide Comment
I have a late 20 17” MacBook Pro A1297 abd from step 4 on, the photos do not look like the interior of my Mac.
jkorchok - Reply Share
Past 24 Hours: 4
Past 7 Days: 39
Past 30 Days: 130
All Time: 24,977
