MacBook Battery Replacement Triage
Fix the MacBook you already have – and save money and the planet in the process.
Find your MacBook model below and follow a step-by-step battery replacement guide. (Each guide will also link the corresponding fix kit with all the parts and tools needed to complete the guide.)
MacBook Pro Battery Replacement Guides
MacBook Air Battery Replacement Guides
Frequently Asked Questions
Can I replace my MacBook battery myself?
Yes, you can replace your MacBook battery yourself. iFixit provides free step-by-step repair guides for every MacBook and sells DIY Battery Fix Kits for MacBooks ranging from the 2010 MacBook Air 13", to the 2022 MacBook Pro 13" (M2). These kits include all the necessary tools and parts to replace your battery.
How easy is it to replace my MacBook Pro battery myself?
Battery replacements for most MacBook Pros released after 2011 are not simple. In 2012, Apple introduced its MacBook Pro Retina, a non-upgradable machine with a glued down battery. Battery replacements for these Pros through the 2020 models require a lot of caution and patience—but they're definitely doable with the right tools, instructions, and adhesive removal techniques.
Luckily, starting in 2021, MacBook Pro batteries are now held to the case with stretch-release adhesive pull tabs, something a regular person can remove without special tools or chemicals. The rest of the repair and disassembly process involves handling screws, connectors, clips, components, and cables, and is generally straightforward.
How easy is it to replace my MacBook Air battery myself?
MacBook Air battery replacements are a lot easier compared to their Pro counterparts. Models released before 2018 featured batteries that could be replaced by removing the case, disconnecting the battery, and removing some screws.
Starting with the 2018 MacBook Air, the battery is now held by adhesive pull tabs. Still, repairs for MacBook Airs are straightforward and generally require the fixer to handle screws, connectors, cables, clips, and other internal components.
How much does it cost to replace my MacBook Pro's battery myself?
Using an iFixit kit to replace your MacBook Pro's battery can result in significant savings compared to Apple's out-of-warranty repair costs. iFixit's MacBook Pro Battery Fix Kits cost between $110 and $130, which is more than $100 cheaper than having Apple fix it.
^ Apple's shared estimates as of February 2025.
How much does it cost to replace my MacBook Air's battery myself?
Replacing your MacBook Air's battery with an iFixit Fix Kit can save you $30 to $90 compared to Apple's out-of-warranty repair costs, depending on your model. iFixit's MacBook Air battery replacement kits average around $100, while kits for newer models like the 2020 M1 cost around $130.
Model
Apple's Cost (Out of Warranty)^
iFixit Cost
Savings
MacBook Air (M1, 2020)
$159
$129.99
$29
MacBook Air 13" (Retina, 2020)
$159
$109.99
$49
MacBook Air 13" (Retina, 2019)
$159
$109.99
$49
MacBook Air 13" (Retina, 2018)
$159
$109.99
$49
MacBook Air 13" (2017)
$159
$79.99
$79
MacBook Air 13" (Early 2015)
$159
$79.99
$79
MacBook Air 11" (Early 2015)
$159
$69.99
$89
How long does it take to fix a MacBook battery?
While the time investment can vary based on the MacBook model and your DIY experience, repairing your MacBook battery yourself is feasible. MacBook Pro repairs generally require more time and patience compared to MacBook Air repairs. Battery replacements should take you anywhere from 30 minutes to a few hours. If you get stuck, iFixit's community of fixers can help.
Further Reading: The World of DIY MacBook Repair
Evan Gattuso
25,935 Reputation
7 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
10 Comments
I bought a battery for my macbook pro approx. 2 years ago and now the battery is going bad. Your batteries DO NO LAST! That is why they're so cheap.
Mike V. - Reply Share
@mikev85117 100+ USD or EUR batteries are not cheap.
Oleksandr Ivanov - Reply Share
A bateria do meu MacBook já não segura mais. Só consigo usá-lo na tomada.
Pergunta?
Usar direto na tomada estraga a bateria?
Ana - Reply Share
Li que não devo usar o crome no Mac book, qual navegador é mais recomendável, preciso rodar o streaming yard
Ana - Reply Share
MacBook Pro later 2013 15英寸电池可以找到吗?
Oyghaq - Reply Share
Past 24 Hours: 420
Past 7 Days: 2,670
Past 30 Days: 11,907
All Time: 329,455
