Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Fujitsu Lifebook Stylistic Q584 is a 10.1-inch LED back-lit tablet that was first released in December of 2014. The Lifebook can stand alone as a tablet or enhanced with a detachable keyboard. This was an innovative hybrid device when released bridging the technological gaps between the two competitive devices. A stylus compatible touchscreen display and size provided the mobility of a tablet with the option of an attachable keyboard for efficiency. As well as innovatively designed, It’s also appealing to the eyes with an elegant glossy white exterior finish.
There are 3 different models of Fujitsu Lifebooks. The series can be broken down into the categories of all-rounded, advanced, and superior. For proper device validation purposes refer to the back of the device. All of the devices identification numbers such as the model number can be located there. The series Q584 is a superior model in the collection. It's designed for power users based on the specifications of the device, including the most current operating system, the screen dimensions, and a high display resolution.
This guide is only relevant to the Q584. Finally, the quality of the device is well established due to the fact that it hasn’t had any manufacturer recall since 2014.
Specs:
  • Intel® Atom™ Processor Z3770
  • 4GB fixed onboard LPDDR3 memory 1066 MHz
  • 10.1" HD WQXGA Display (2560 x 1600 / 16:10)
  • Front-facing HD Webcam 1600 x 1200 (2 MP)
  • Rear-facing FHD Webcam 3264 x 2448 (8 MP)
  • 64 GB or 128 GB eMMC SSD
  • Lithium-ion battery 3 cell, 38 Wh; Battery life up to 11 hours
Identification
Identified by model number Q584.
Troubleshooting
If you're having issues with your Fujitsu tablet, check out this troubleshooting page
Additional Information
Buy on Amazon
User Guide
Data Sheet
Device Review at Notebook Check
Data Sheet FUJITSU STYLISTIC Q584 Tablet PC
Fujitsu STYLISTIC Q584 Tablet Operating Manual
FUJITSU Tablet STYLISTIC Q584 Betriebsanleitung
Fujitsu STYLISTIC Q584 Tablet Data Sheet
Fujitsu STYLISTIC Q584 Semi-Rugged Tablet PC Data Sheet
Fujitsu STYLISTIC Q584 Tablet PC Data Sheet
Author
with
Isaiah
46 Reputation
0 Guides authored
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 110
All Time: 8,302
