Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Fujitsu Will Not Connect to Wi-Fi
The Wi-Fi symbol is not showing and internet applications will not load.
The Wireless Component is Switched Off
The radio components are not switched on in the device settings. To turn this setting on go to Settings - Change PC settings – Wireless devices – On.
Wireless Connection to a Network Does Not Work
Check whether the wireless connection is enabled by the software. If the wireless is still not connecting try turning off your Fujitsu, and your modem/router. Wait 30 seconds and turn both devices back on, If the wireless is still not connected it may be a problem with your internet provider.
The Tablet PC Does Not Start After Switching On
The tablet will not start when attempting to power on.
Battery Not Charged
Plug in the charger and allow the battery to charge before powering on.
The AC Adapter is Not Properly Connected
Check whether the AC adapter is properly connected to the Fujitsu, and switch the device on.
Battery is Faulty
If a good charger is unable to supply power to the device, it is possible that the battery is bad and will need to be replaced.
Stylus Input is Not Working
The screen does not respond to touch with the stylus.
Stylus Needs Calibration
To calibrate, run the Hardware and Sound / Tablet PC Settings function in the Control Panel. You need to calibrate both portrait and landscape formats.
Stylus Tip is Faulty
Replace stylus tip using this guide.
The Battery Discharges too Quickly
The battery of the device does not hold a charge.
The Battery is Either Too Hot or Too Cold. Battery Indicator is Flashing.
Bring the Fujitsu up/down to a normal operating temperature. If the battery life is extremely short, the battery might need to be replaced.
There is an Application Running that Consumes a Large Amount of Power
Use the AC adapter when it is possible.
Screen Brightness is Set to Maximum
Reduce the brightness of the screen. You will find the setting under Control Panel - Hardware and Sounds - Windows Mobility Center.
System Error Messages
Error messages generated by the BIOS when a problem has occurred.
Keyboard Controller Error
Switch your Fujitsu off with the ON/OFF button. Wait 3-5 seconds and switch the Fujitsu on again.
Keyboard Error
If you are using an external keyboard: Check the connection and reboot the Fujitsu.
Operating System Not Found
Check in the BIOS Setup whether your hard disk has been set correctly, and make sure that the operating system is installed in the corresponding drive.
Spencer Bacon
419 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 28
All Time: 3,396
