Fujitsu Lifebook Stylistic Q584 Camera Replacement
    1. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Back Case: step 1, image 1 of 1
      • Remove the white sticker covering the screws (if applicable).
      • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
      Ask FixBot
    2. Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 2, image 1 of 1
      • Insert the plastic opening tool along the seam of the back case.
      • Gently slide the plastic opening tool along the entire seam popping the clips free.
      Ask FixBot
    3. Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 3, image 1 of 1
      • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
      Ask FixBot
    1. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Inner Back Shield: step 4, image 1 of 1
      • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
      Ask FixBot
    2. Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 5, image 1 of 1
      • Remove the grey docking station port cover.
      Ask FixBot
    3. Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 6, image 1 of 1
      Ask FixBot
    4. Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 7, image 1 of 1
      • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
      Ask FixBot
    1. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Camera: step 8, image 1 of 2 Fujitsu Lifebook Stylistic Q584 Camera Replacement, Camera: step 8, image 2 of 2
      • Pull up the cord that connects the battery to the motherboard
      Ask FixBot
    2. Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 9, image 1 of 2 Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 9, image 2 of 2
      • Pull the ribbon straight up from the back of the camera board
      Ask FixBot
    3. Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 10, image 1 of 1
      • Remove the single 2mm screw using a PH000 screwdriver from the camera board.
      Ask FixBot
Connor Stanton
613 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 36
Past 30 Days: 99
All Time: 856
