Fujitsu Lifebook Stylistic Q584 Battery Replacement
    1. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Back Case: step 1, image 1 of 1
      • Remove the white sticker covering the screws (if applicable).
      • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
      Ask FixBot
    2. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 2, image 1 of 1
      • Insert the plastic opening tool along the seam of the back case.
      • Gently slide the plastic opening tool along the entire seam popping the clips free.
      Ask FixBot
    3. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 3, image 1 of 1
      • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
      Ask FixBot
    1. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Inner Back Shield: step 4, image 1 of 1
      • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
      Ask FixBot
    2. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 5, image 1 of 1
      • Remove the grey docking station port cover.
      Ask FixBot
    3. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 6, image 1 of 1
      Ask FixBot
    4. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 7, image 1 of 1
      • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
      Ask FixBot
    1. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Battery: step 8, image 1 of 1
      • Pull up the cord that connects the battery to the motherboard
      Ask FixBot
    2. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 9, image 1 of 1
      • Remove seven 1mm screws using a PH00 screwdriver.
      Ask FixBot
    3. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 10, image 1 of 1
      • Disconnect upper peripheral ribbons from motherboard.
      • Disconnect left peripheral ribbon from motherboard.
      Ask FixBot
    4. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 11, image 1 of 1
      • Gently lift the battery from the casing.
      Ask FixBot
2 other people completed this guide.
Connor Stanton
613 Reputation
6 Guides authored
1 Guide Comment
I have flickering video problems after a drop, its probably video cable loose. Where is the video cable, To try reseating.
Vince - Reply Share
Past 24 Hours: 7
Past 7 Days: 32
Past 30 Days: 120
All Time: 4,161
