Fujitsu Lifebook Stylistic Q584 Back Case Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
100
All Time:
1,515
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The back case is the exterior shell of the device. It needs to be removed in order to access internal components.
Tools
    1. Fujitsu Lifebook Stylistic Q584 Back Case Replacement, Back Case: step 1, image 1 of 1
      • Remove the white sticker covering the screws (if applicable).
      • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
      Ask FixBot
    2. Fujitsu Lifebook Stylistic Q584 Back Case Replacement: step 2, image 1 of 1
      • Insert the plastic opening tool along the seam of the back case.
      • Gently slide the plastic opening tool along the entire seam popping the clips free.
      Ask FixBot
    3. Fujitsu Lifebook Stylistic Q584 Back Case Replacement: step 3, image 1 of 1
      • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
      Ask FixBot
Spencer Bacon
419 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 100
All Time: 1,515
