Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
64
All Time:
1,056
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
This guide allows the user to access and replace the MicroSD card of a Fujitsu Lifebook Stylistic Q584.
Tools
    1. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Back Case: step 1, image 1 of 1
      • Remove the white sticker covering the screws (if applicable).
      • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
      Ask FixBot
    2. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 2, image 1 of 1
      • Insert the plastic opening tool along the seam of the back case.
      • Gently slide the plastic opening tool along the entire seam popping the clips free.
      Ask FixBot
    3. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 3, image 1 of 1
      • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
      Ask FixBot
    1. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Inner Back Shield: step 4, image 1 of 1
      • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
      Ask FixBot
    2. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 5, image 1 of 1
      • Remove the grey docking station port cover.
      Ask FixBot
    3. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 6, image 1 of 1
      Ask FixBot
    4. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 7, image 1 of 1
      • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
      Ask FixBot
    1. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Battery: step 8, image 1 of 1
      • Pull up the cord that connects the battery to the motherboard
      Ask FixBot
    2. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 9, image 1 of 1
      • Remove seven 1mm screws using a PH00 screwdriver.
      Ask FixBot
    3. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 10, image 1 of 1
      • Disconnect upper peripheral ribbons from motherboard.
      • Disconnect left peripheral ribbon from motherboard.
      Ask FixBot
    4. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 11, image 1 of 1
      • Gently lift the battery from the casing.
      Ask FixBot
    1. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Motherboard: step 12, image 1 of 1
      • Remove three 3mm screws using a PH00 screwdriver.
      Ask FixBot
    2. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 13, image 1 of 1
      • Remove all of the ribbon connector cables from the motherboard using an ESD-safe spudger.
      Ask FixBot
    3. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 14, image 1 of 1
      • Gently pry up the motherboard.
      Ask FixBot
    4. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 15, image 1 of 1
      • Gently lift the foil tape under the motherboard to reveal the connector.
      Ask FixBot
    5. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 16, image 1 of 3 Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 16, image 2 of 3 Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 16, image 3 of 3
      • Remove the clip holding in the connector with an ESD-safe spudger.
      Ask FixBot
    6. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: step 17, image 1 of 1
      • Remove the connector with an ESD-safe spudger.
      Ask FixBot
    1. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, MicroSD Card: step 18, image 1 of 1
      • After removing the motherboard, use an ESD-safe spudger to pry up the MicroSD card from the slot.
      • Gently separate the MicroSD card from the device.
      Ask FixBot
Casey
283 Reputation
2 Guides authored
IUPUI, Team S1-G1, Henning Spring 2019 Member of IUPUI, Team S1-G1, Henning Spring 2019
IUPUI-HENNING-S19S1G1
3 Members
36 Guides authored
1 Guide Comment
I have some OS problem can the SSD be replaced..?
Faiz Rahmathulla - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 64
All Time: 1,056
