Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop overheats often
''Your Lenovo T440S CPU processor overheats often."
Replace thermal paste on CPU
A common problem with older computers is the thermal conducting paste on the CPU could need replacing. A detailed guide on how to access the CPU can be found here: Thermal Paste Replacement.
Fan vents blocked
Make sure the vents on the side of your Lenovo T440S Thinkpad are non-obstructed and clear of any dust. Use a cotton swab or compressed air to clear the vents of dust if there is any. If you find that your fan has dust embedded into it or is not turning on, you may want to replace your fan. A detailed guide on how to replace the laptops fan can be found here: Fan Replacement.
Keypad is unresponsive
“Your Lenovo T440S Thinkpad does not display any words when typing”
Dirty keys
If your Lenovo T440S Thinkpad does not display any words when you attempt to type, one reason for this could be that the keys you are using are dirty. I suggest trying other keys on the keypad. If other keys work, try taking off the keys that were not working and clean them as well as the keypad. Sometimes dirt may get under the keys and cause them to be unresponsive.
Broken keypad
Another issue that could cause the keypad to be unresponsive on your Lenovo T440S Thinkpad could be that the keypad is broken and may need to be replaced. Before making any decisions, put it into BIOS mode. BIOS mode basically manages the connection between the keypad and the operating system of the Lenovo. To put the Lenovo in BIOS mode, hold the power button until it is completely shut down. Then, power your Lenovo back on and once the start up logo appears, press F2. Once your Lenovo is powered on, attempt typing again. If the keypad is still unresponsive, the keypad more than likely needs to be replaced. For a detailed guide on replacing your Lenovo T440S Thinkpad's keyboard, click here: Keyboard Replacement
Computer Freezes often
“Your Lenovo T440S Thinkpad becomes unresponsive frequently.”
Too many programs are opening
Each program requires some of your computers active memory to run properly, if too many programs are running, including the ones in the background, your computer will freeze. To combat this problem right-click the start menu bar and then left-click Task Manager. In Task Manager you can see which programs are currently unresponsive and/or taking up a majority of your computer's memory and CPU. Identify these programs, click on them and then click End Task.
Insufficient RAM
If simply closing the running programs is not a liable option than your computer may not have sufficient RAM to performs it’s tasks. Click this link to view our guide on how to replace the RAM: RAM Replacement
Drivers are out of date
Drivers are the programs that allow your computer to send and receive signals from its components. If your drivers are not up to date it could cause your computer to freeze as those signals are not being processed correctly. To update your drivers click the Start Menu and search Device Manager and then select it. From here you can choose which drivers to be updated by right clicking the device and selecting Update Driver and then selecting Search automatically for updated driver software.
Can’t connect to Wi-Fi
“Your Lenovo T440S Thinkpad is unable to connect to a network.”
Microsoft Support
Depending on which version of windows your Lenovo T440S Thinkpad is operating on different problems and solutions could arise, refer to the Microsoft Windows support page that offers troubleshooting for each version of Windows: Microsoft Support
Dies Quickly
“Your Lenovo T440S Thinkpad is dying quicker than usual.”
Charging Cable
Allow your Lenovo T440S Thinkpad to complete a full charge which is an average of 3 hours. Check that your charging cable has no cuts or exposed wires. If the charger seems to be alright, check the jack and make sure the charger is properly plugged into your Lenovo. If everything seems to be plugged in correctly but is still having issues, consider replacing the charger.
Battery does not hold a charge
Throughout the devices lifespan the battery’s quality degrades from the numerous charging cycles it experiences. Eventually the battery reaches a point where it can no longer hold a sufficient charge, making the laptop unusable without being plugged into an outlet. This is a normal occurrence for all devices and is most of the time an easy fix. For a detailed guide on replacing your Lenovo T440S Thinkpad's internal batter, click here: Internal Battery Replacement
Faulty Display
“Your Lenovo T440S Thinkpad is displaying a black or pixelated screen”
Verify Display Works When Powering On
If your Lenovo Thinkpad is already powered on, turn the device off, wait a few moments and then turn it back on. Most of the Lenovo models display dims when battery is lower so, be sure that it is fully charged. Also, check that the display and brightness settings are not lowered and color depth has not been affected in any way.
Display Issues
The display is one of the most sensitive components of a laptop, being made usually out of glass or clear plastic. Any stress or impact the laptop experiences will usually result in the display being damaged. Extensive disassembly may be needed to remove the display but usually it is only connected by one or two ribbon cables which makes the repair less intimidating. For a detailed guide on replacing your Lenovo T440S Thinkpad's display, click here: Display Replacement.
Terelle Montalvo
1,495 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 38
All Time: 2,997
