Lenovo Thinkpad T440s Fan Replacement
    1. Lenovo Thinkpad T440s Fan Replacement, Back Panel: step 1, image 1 of 2 Lenovo Thinkpad T440s Fan Replacement, Back Panel: step 1, image 2 of 2
      • Make sure to power down and turn off your device before proceeding with the repair.
      • Flip your laptop over so that the backside is facing you.
      Ask FixBot
    2. Lenovo Thinkpad T440s Fan Replacement: step 2, image 1 of 1
      • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
      • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
      Ask FixBot
    3. Lenovo Thinkpad T440s Fan Replacement: step 3, image 1 of 2 Lenovo Thinkpad T440s Fan Replacement: step 3, image 2 of 2
      • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
      Ask FixBot
    4. Lenovo Thinkpad T440s Fan Replacement: step 4, image 1 of 1
      • Remove the back panel from the device.
      Ask FixBot
    1. Lenovo Thinkpad T440s Fan Replacement, Fan: step 5, image 1 of 2 Lenovo Thinkpad T440s Fan Replacement, Fan: step 5, image 2 of 2
      • Use the Phillips #1 screwdriver to remove the four screws holding in the fan assembly.
      Ask FixBot
    2. Lenovo Thinkpad T440s Fan Replacement: step 6, image 1 of 3 Lenovo Thinkpad T440s Fan Replacement: step 6, image 2 of 3 Lenovo Thinkpad T440s Fan Replacement: step 6, image 3 of 3
      • Lift the fan out of it's compartment to gain access to the cable connection, firmly grab the cable and pull it out of it's housing.
      Ask FixBot
6 other people completed this guide.
Terelle Montalvo
1,495 Reputation
8 Guides authored
5 Guide Comments
It would be helpful to have something about the fan too!
Where to get it, or at least the model number!
Iraj V - Reply Share
What about thermal grease?
Oscar Desmonteix - Reply Share
Useless info. This is the heatsink (with fan) replacement, NOT fan replacement. The poster is a moron.
Victor Song - Reply Share
Victor - The fan and heatsink are attached to one another. How would you propose one replace the fan only? If you have a method, please create your own guide if this one was authored by such a “moron”. Jeez.
tomwedell - Reply Share
Is there a way to tell if your fan is bad before ordering a replacement and opening my t440s?
Beckco - Reply Share
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 52
All Time: 7,524
