Lenovo Thinkpad T440s RAM Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
35
Past 30 Days:
106
All Time:
5,328
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Is your device experiencing problems with loading and saving while the computer is in use? Consider using this guide to replace the RAM in your device.
Parts
Tools
    1. Lenovo Thinkpad T440s RAM Replacement, Back Panel: step 1, image 1 of 2 Lenovo Thinkpad T440s RAM Replacement, Back Panel: step 1, image 2 of 2
      • Make sure to power down and turn off your device before proceeding with the repair.
      • Flip your laptop over so that the backside is facing you.
      Ask FixBot
    2. Lenovo Thinkpad T440s RAM Replacement: step 2, image 1 of 1
      • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
      • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
      Ask FixBot
    3. Lenovo Thinkpad T440s RAM Replacement: step 3, image 1 of 2 Lenovo Thinkpad T440s RAM Replacement: step 3, image 2 of 2
      • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
      Ask FixBot
    4. Lenovo Thinkpad T440s RAM Replacement: step 4, image 1 of 1
      • Remove the back panel from the device.
      Ask FixBot
    1. Lenovo Thinkpad T440s RAM Replacement, RAM: step 5, image 1 of 2 Lenovo Thinkpad T440s RAM Replacement, RAM: step 5, image 2 of 2
      • Right below the battery slot on the right half of the device is where you can access the RAM card Slot.
      • Remove the RAM by pulling it straight out of the device.
      Ask FixBot
7 other people completed this guide.
Terelle Montalvo
1,495 Reputation
8 Guides authored
1 Guide Comment
I have a T460, very similar. A few points missing here… It’s imperative to take out the battery first. Most other tutorials mention disabling the internal battery in the BIOS before starting the process. Then screws don’t come out, they stay attached, which is very nice but better if you expect it. And one of them is right under the battery. The 460 has 2 memory slots, and they’re both functional. I had to swap my 4G card to the second slot, and put the 8G one in to replace it, I don’t know whether that’s mandatory or it was just bad seating initially.
George Mahe - Reply Share
Past 24 Hours: 6
Past 7 Days: 35
Past 30 Days: 106
All Time: 5,328
