Lenovo Thinkpad T440s Display Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
98
All Time:
4,109
Comments: 4
4 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 30 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
Is your screen filled with black spots or not displaying images properly? Consider using this guide to replace the display of your device.
Tools
    1. Lenovo Thinkpad T440s Display Replacement, Back Panel: step 1, image 1 of 2 Lenovo Thinkpad T440s Display Replacement, Back Panel: step 1, image 2 of 2
      • Make sure to power down and turn off your device before proceeding with the repair.
      • Flip your laptop over so that the backside is facing you.
      Ask FixBot
    2. Lenovo Thinkpad T440s Display Replacement: step 2, image 1 of 1
      • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
      • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
      Ask FixBot
    3. Lenovo Thinkpad T440s Display Replacement: step 3, image 1 of 2 Lenovo Thinkpad T440s Display Replacement: step 3, image 2 of 2
      • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
      Ask FixBot
    4. Lenovo Thinkpad T440s Display Replacement: step 4, image 1 of 1
      • Remove the back panel from the device.
      Ask FixBot
    1. Lenovo Thinkpad T440s Display Replacement, Display: step 5, image 1 of 3 Lenovo Thinkpad T440s Display Replacement, Display: step 5, image 2 of 3 Lenovo Thinkpad T440s Display Replacement, Display: step 5, image 3 of 3
      • Use the Phillips #1 screwdriver to remove the five screws securing the display mounts.
      Ask FixBot
    2. Lenovo Thinkpad T440s Display Replacement: step 6, image 1 of 3 Lenovo Thinkpad T440s Display Replacement: step 6, image 2 of 3 Lenovo Thinkpad T440s Display Replacement: step 6, image 3 of 3
      • Use the metal spudger to pry up the lever securing the ribbon cable in it's connection housing.
      Ask FixBot
    3. Lenovo Thinkpad T440s Display Replacement: step 7, image 1 of 3 Lenovo Thinkpad T440s Display Replacement: step 7, image 2 of 3 Lenovo Thinkpad T440s Display Replacement: step 7, image 3 of 3
      • Grab hold of the ribbon cable and pull it out of it's connection housing.
      Ask FixBot
    4. Lenovo Thinkpad T440s Display Replacement: step 8, image 1 of 2 Lenovo Thinkpad T440s Display Replacement: step 8, image 2 of 2
      • Disconnect the white and blue wires connected to the mounted circuit by grabbing them close to the connection and pulling upward.
      Ask FixBot
    5. Lenovo Thinkpad T440s Display Replacement: step 9, image 1 of 2 Lenovo Thinkpad T440s Display Replacement: step 9, image 2 of 2
      • Use the Phillips #1 screwdriver to remove the two screws securing the metal plate to expose the wire connection.
      Ask FixBot
    6. Lenovo Thinkpad T440s Display Replacement: step 10, image 1 of 2 Lenovo Thinkpad T440s Display Replacement: step 10, image 2 of 2
      • Disconnect the wire by pulling it upward from the motherboard.
      Ask FixBot
    7. Lenovo Thinkpad T440s Display Replacement: step 11, image 1 of 3 Lenovo Thinkpad T440s Display Replacement: step 11, image 2 of 3 Lenovo Thinkpad T440s Display Replacement: step 11, image 3 of 3
      • Unclip the 5 wires connected to the display assembly from the motherboard and move them out of the way.
      Ask FixBot
    8. Lenovo Thinkpad T440s Display Replacement: step 12, image 1 of 3 Lenovo Thinkpad T440s Display Replacement: step 12, image 2 of 3 Lenovo Thinkpad T440s Display Replacement: step 12, image 3 of 3
      • Now that the display assembly is disconnected from the main body, lift both of the mounting brackets and remove the display assembly from the main body.
      Ask FixBot
3 other people completed this guide.
Terelle Montalvo
1,495 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 98
All Time: 4,109
