Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
The HTC Fortress Troubleshooting Page will help you fix many problems you may have with the HTC Fortress. You should try to find your problem here before attempting to repair anything on your device.
Background
The HTC Fortress smartphone, also know as the HTC Tilt 2, features a slide-out, tilting keyboard and a 3.6-inch touch-sensitive screen.
This phone can be differentiated from the original HTC Tilt by the larger, touch-sensitive screen and the lack of a standard headphone jack.
Highlights of the device include:
  • a slide-out QWERTY keyboard
  • 3.6-inch WVGA resistive touch screen
  • a 3.2-megapixel camera
  • a built-in accelerometer and proximity sensor
  • a microSD expansion slot behind the battery door
  • a push-to-talk key on the left side
  • a touch-sensitive zoom bar to precisely zoom in and out
Identification
The HTC Fortress model number (ST7377) can be found underneath the removable battery.
Additional Information
HTC Fortress/Tilt 2 Parts
Specific details on GSMArena
Accessories from TheWirelessBoys
Other Hard Reset Option
HTC Support Forums:
Author
with
Lucas David
540 Reputation
9 Guides authored
Cal Poly, Team 4-13, Maness Spring 2013 Member of Cal Poly, Team 4-13, Maness Spring 2013
CPSU-MANESS-S13S4G13
4 Members
108 Guides authored
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 40
All Time: 4,525
