Up to 20% off select tools
HTC Fortress SIM Card Replacement
Views: 1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
15
Past 30 Days:
94
All Time:
1,031
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
The SIM card in your HTC Fortress stores important information including your contacts and personal settings. It is designed to be removed relatively easily.
In this guide, you will learn how to replace the SIM Card in the HTC Fortress. No tools are required for this guide.
    1. HTC Fortress SIM Card Replacement, Battery: step 1, image 1 of 2 HTC Fortress SIM Card Replacement, Battery: step 1, image 2 of 2
      • Remove the back cover of the device by sliding it upward.
      • You may need to remove the phone stylus first.
      Ask FixBot
    2. HTC Fortress SIM Card Replacement: step 2, image 1 of 2 HTC Fortress SIM Card Replacement: step 2, image 2 of 2
      • Remove the battery by pulling it away from the back of the phone.
      Ask FixBot
    1. HTC Fortress SIM Card Replacement, SIM Card: step 3, image 1 of 3 HTC Fortress SIM Card Replacement, SIM Card: step 3, image 2 of 3 HTC Fortress SIM Card Replacement, SIM Card: step 3, image 3 of 3
      • Insert the stylus into the small slot.
      • Use the stylus as a lever to push the sim card out of its fitting.
      • Use your finger to slide the card out the rest of the way.
      Ask FixBot
Author
with
Lucas David
540 Reputation
9 Guides authored
Cal Poly, Team 4-13, Maness Spring 2013 Member of Cal Poly, Team 4-13, Maness Spring 2013
CPSU-MANESS-S13S4G13
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 94
All Time: 1,031
