Up to 20% off select tools
Hard Reset
Views: 3.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
89
All Time:
3,238
Comments: 1
1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Hard Reset
Introduction
Go to step 1 ↓
When you can't solve a software problem using other troubleshooting techniques, you might consider a hard reset. A hard reset is generally used as a last resort, since it will remove all of your data and settings, and return the device to its original condition.
In this guide, you'll learn how to perform a hard reset on you HTC Fortress. No tools are required, just a series of specific user inputs.
    1. Hard Reset, Hard Reset: step 1, image 1 of 1
      • With the phone powered off, press and hold the Talk/Send, End, and Power buttons (the 3 circled here) for about 3 seconds.
      Ask FixBot
    2. Hard Reset: step 2, image 1 of 2 Hard Reset: step 2, image 2 of 2
      • When the screen powers on, you will see an instructional message.
      • Press the volume up button to perform the hard reset.
      • The hard reset will erase all personal data on your device. If you would like to cancel the hard reset, press any other button.
      Ask FixBot
    3. Hard Reset: step 3, image 1 of 1
      • Your device will display this screen after a few seconds. Press the Volume Up button to boot your phone.
      Ask FixBot
    4. Hard Reset: step 4, image 1 of 2 Hard Reset: step 4, image 2 of 2
      • Your phone will display this screen. If you would like to import your SIM contacts now, tap "Import SIM contacts" and tap "Next". Otherwise, tap "Cancel".
      Ask FixBot
You have just performed a hard reset on your HTC Fortress. All personal data on your phone has been deleted, and your phone is now back to its default settings.
7 other people completed this guide.
Author
with
Lucas David
540 Reputation
9 Guides authored
Cal Poly, Team 4-13, Maness Spring 2013 Member of Cal Poly, Team 4-13, Maness Spring 2013
CPSU-MANESS-S13S4G13
4 Members
108 Guides authored
1 Guide Comment
great information thanks.
regards
Jrubio - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 89
All Time: 3,238
