Up to 20% off select tools
HTC Fortress Camera Replacement
Views: 1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
89
All Time:
1,022
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
  • T4 Torx Screwdriver
    4.8
  • Tweezers
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If your Fortress' camera is malfunctioning and you've ruled out any software problems, you may want to install a new Camera.
In this guide, you'll learn how to install the HTC Fortress camera. This guide requires a moderate amount of dismantling of your phone with tools from the iFixit tool kit.
    1. HTC Fortress Camera Replacement, Battery: step 1, image 1 of 2 HTC Fortress Camera Replacement, Battery: step 1, image 2 of 2
      • Remove the back cover of the device by sliding it upward.
      • You may need to remove the phone stylus first.
      Ask FixBot
    2. HTC Fortress Camera Replacement: step 2, image 1 of 2 HTC Fortress Camera Replacement: step 2, image 2 of 2
      • Remove the battery by pulling it away from the back of the phone.
      Ask FixBot
    1. HTC Fortress Camera Replacement, Camera: step 3, image 1 of 2 HTC Fortress Camera Replacement, Camera: step 3, image 2 of 2
      • Remove the top 2 screws on the back of the phone with the T4 Screwdriver.
      Ask FixBot
    2. HTC Fortress Camera Replacement: step 4, image 1 of 3 HTC Fortress Camera Replacement: step 4, image 2 of 3 HTC Fortress Camera Replacement: step 4, image 3 of 3
      • Remove the camera panel by hand (black cover above the battery slot).
      • Be careful; there is a cable attached underneath the case. It does detach, just pull on it carefully.
      • During reassembly, put the cable back in by holding the black piece slightly above its slot and using the spudger to gently press the end of the cable back into its fitting. Then, insert the black piece so it is flush with the black panel again.
      Ask FixBot
    3. HTC Fortress Camera Replacement: step 5, image 1 of 3 HTC Fortress Camera Replacement: step 5, image 2 of 3 HTC Fortress Camera Replacement: step 5, image 3 of 3
      • Work the metal camera casing off by slowly prying up the sides using the spudger.
      Ask FixBot
    4. HTC Fortress Camera Replacement: step 6, image 1 of 2 HTC Fortress Camera Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Use the tweezers to pull the camera straight out of the phone.
      Ask FixBot
Author
with
Lucas David
540 Reputation
9 Guides authored
Cal Poly, Team 4-13, Maness Spring 2013 Member of Cal Poly, Team 4-13, Maness Spring 2013
CPSU-MANESS-S13S4G13
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 89
All Time: 1,022
