Up to 20% off select tools
Screen Alignment Process
Views: 9.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
36
Past 30 Days:
136
All Time:
9,248
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Some screen alignment and display issues can be solved by running a simple screen alignment process, accessible through you phone's settings.
This guide will take you through the steps of realigning the screen of the HTC Fortress. You will need to perform several actions involving the phone's user interface and stylus.
    1. Screen Alignment Process, Screen Alignment Process: step 1, image 1 of 1
      • With the phone powered on and at the home screen, tap "Start".
      Ask FixBot
    2. Screen Alignment Process: step 2, image 1 of 1
      • Tap "Settings".
      Ask FixBot
    3. Screen Alignment Process: step 3, image 1 of 1
      • Tap "System".
      Ask FixBot
    4. Screen Alignment Process: step 4, image 1 of 1
      • Tap "Screen".
      Ask FixBot
    5. Screen Alignment Process: step 5, image 1 of 1
      • Now tap "Align Screen". This will initiate the Screen Alignment Process on your phone. Follow the instructions on the screen.
      • The Screen Alignment Process must be completed with the phone stylus only. This will ensure proper alignment of the phone's screen.
      Ask FixBot
Your HTC Fortress' screen is now properly aligned.
2 other people completed this guide.
Author
with
Lucas David
540 Reputation
9 Guides authored
Cal Poly, Team 4-13, Maness Spring 2013 Member of Cal Poly, Team 4-13, Maness Spring 2013
CPSU-MANESS-S13S4G13
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 136
All Time: 9,248
