Phone SIM card needs to be replaced
You want to install a new SIM Card in your phone, or your current SIM Card is broken.
Install a new SIM Card
Follow our SIM Card installation tutorial here.
Phone keyboard is broken
Keyboard has sustained physical damage and needs to be replaced.
Install a new keyboard
If your keyboard is broken, you may need to install a new keyboard. See our HTC Fortress Keyboard Installation guide here.
Phone camera is broken
Camera is broken and needs to be replaced.
Install a new camera
If your camera has been cracked or no longer works, you might want to install a new camera. See our HTC Fortress Camera Installation guide here.
Phone randomly awakes from sleep mode
Your phone is in its case and without you pressing any buttons or sliding it open, the screen activates.
A magnetic case is awakening your phone
This is a common problem among Fortress users. One possible cause is that if your carrying case has a magnet fastener, it could be triggering a signal inside the phone, telling it to wake up. You can either get a new case for your phone, remove the magnet from the case or get a case with magnets only on the sides, as cases with magnets in the center tend to cause this problem more than others. Also, if your case is made by your provider, you may consider purchasing one here.
Unlock slider slides but doesn't unlock phone
When your phone is locked, the unlock slider will slide left and right, but the phone won't unlock.
Phone requires a Soft Reset
Your phone will need a soft reset to fix this problem. Follow the steps in the Soft Reset guide here.
Black/Blank Display
There is no image on the screen.
Battery is dead
Try to power on your HTC Fortress by holding down the power button for 3 seconds. If nothing happens, try charging the device. If your device doesn't respond when it is attached to the charger and a power source, see the guide for installing a new battery here.
Phone is in Hibernate Mode
Sometimes the HTC Fortress will go into Hibernate Mode and turn off the display. Simply press the power button once to get out of Hibernate Mode. If nothing happens, try using the hardware buttons such as the menu keypad and keyboard to navigate the phone's menus.
If the above methods didn't work, try performing a Soft Reset by following the guide here.
Phone requires a Hard Reset
As a last resort, try a Hard Reset. This will delete all of the data on your phone.
Display has lines
Your phones display has lines on the screen.
Restore Wallpaper settings to Default
With your phone unlocked, tap Start in the upper left corner. Find the Settings icon and tap it, and then tap Today. Select ATT_Tabbed and uncheck "Use this picture as background".
If the above method didn't work, try performing a Soft Reset by following the guide here.
Uninstall 3rd Party Applications
Applications installed after market can cause this problem. If you noticed this problem after installing an application, you can try uninstalling it by following this guide.
Screen alignment is off
When you tap on the screen, the tap is registered in a different place than where you intended.
Touch screen is not aligned properly
Some problems with the display can be caused by a misaligned screen. Try running the Screen Alignment Process.
Screen Protector is interfering with the touch screen
Screen protectors can cause taps to be registered incorrectly. Try removing your screen protector if you have one.
Phantom unread text message
Your HTC Fortress constantly shows 1 unread text message, although you do not have any unread text messages.
Try performing a Soft Reset by following the guide here.
Try a Hard Reset. This will delete all of the data on your phone.
Sources
HTC Tilt 2 Troubleshoot Display issues (goolge search)
forums.at&t.com
forum.xda-developers.com
cummunity.htx.com
Answers.microsoft.com
Author
with
Riess Haslam
161 Reputation
0 Guides authored
Cal Poly, Team 4-13, Maness Spring 2013 Member of Cal Poly, Team 4-13, Maness Spring 2013
CPSU-MANESS-S13S4G13
4 Members
108 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 57
All Time: 1,229
