Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The HP Chromebook 11 CB2L was the first offering from HP’s Chromebook series. Due to the fact that it is running Chrome OS, which is built for those who want to browse the web and use Google’s suite of apps, it is a low powered laptop with 2GB of RAM and 16GB of storage. The device has two USB ports, a headphone jack, and a micro USB port for charging. Over 145,000 units were affected by a charger recall. The charger would overheat and melt. The remedy was to replace the charger.
Identification
To distinguish this device from other Chromebooks, look for its seamless plastic design with no visible screws, similar to the older MacBooks. The model number "CB2L" is on the bottom of the device, centered on the larger rubber piece.
Technical Specifications
Dimensions: 7.68 x 11.69 x 0.69 inches
Screen
  • Size: 11.6 inches
  • Resolution: 1366x768
Operating System: Chrome OS
Processor: 1.7 GHz Exynos 5250
RAM: 2 GB DDR3L SDRAM
Wireless: 802.11bgn
USB 2.0 Ports: 2
Camera: VGA
Battery: 3270mAh Lithium-ion (Up to 6 hrs)
Additional Information
Author
with
Gregory Hinkson
352 Reputation
3 Guides authored
USF Tampa, Team S2-G6, Lacy Spring 2017 Member of USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 Members
48 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 4,175
