Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Chromebook CB2L Screen is not working
Bad Motherboard
Occasionally a frozen or unresponsive screen can simply be solved by restarting your Chromebook CB2L. Press and hold down the power button and Refresh button simultaneously for three seconds. Wait for the laptop to turn off and then back on. If the issue continues you may need to replace your motherboard. Follow this link to find a replacement guide for HP Chromebook CB2L Motherboard: HP Chromebook CB2L Motherboard Replacement
HP Chromebook will not charge
LED light above the charging port does not work
If the LED light is green that does not necessarily mean the Chromebook is 100% charged, it means that the charger is initializing. (You have to wait 15 seconds after plugging in the AC adapter). If above steps do not work then try to charge your Chromebook by plugging the end of AC adapter to your charging port and the other end to a wall outlet. (Make sure that your outlet is working properly by using any other household device in there). Charge your laptop for 10 minutes and then repeatedly press the power button. If your chrome does not turn on you need to charge your laptop for 24 hours to determine if the battery needs to be replaced or not. If your laptop is still not working, then you may need to replace your battery. Follow this link to find a complete guide to replace your HP Chromebook CB2L battery:
HP Chromebook CB2L Battery Replacement
No sound being heard from audio port or headphones
Faulty/Broken Headphone port
If you are hearing no sound or distorted sound when playing audio through your Chromebook headphone port it may be that the headphones are bad and not the Chromebook. If no audio can be heard make sure that you have turned the volume up on both, the media you are trying to listen to, as well as the volume on your Chromebook. If the issue persists, try using your headphones in a different device. If there is no distortion in the audio reception, then the issue lies with your Chromebook. Your headphone port may need replacing. Follow this link to find a complete guide on how to replace your headphone port:
HP Chromebook CB2L Audio Port Replacement
Faulty/Broken Speakers
If no audio is being output you should first ensure that the volume on both the Chromebook and the media you are trying to play are turned up. If the audio being output is distorted your speaker needs to be replaced. Follow this link to find a complete guide on how to replace your headphone port:
HP Chromebook CB2L Speaker Replacement
HP Chromebook is slow/ takes a lot of time to load
Bad Motherboard
The first thing which you need to do if that happens is to perform a EC (Embedded Controller) reset. Press and hold the power button and refresh button for three seconds. If that doesn’t fix the problem, you need to perform a hard reset. Press and hold the power, refresh, and esc buttons for five seconds. The laptop should turn off, and then back on again. If a message is displayed stating that the operating system is corrupt or missing, press the power button to turn the laptop turn off once more. If any of the previous steps did not fix the problem, you need to replace your motherboard. Follow this link to find a complete guide on how to replace your motherboard:
Author
with
Gregory Hinkson
352 Reputation
3 Guides authored
USF Tampa, Team S2-G6, Lacy Spring 2017 Member of USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 Members
48 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,053
