HP Chromebook CB2L Battery Replacement
    1. HP Chromebook CB2L Battery Replacement, Battery: step 1, image 1 of 2 HP Chromebook CB2L Battery Replacement, Battery: step 1, image 2 of 2
      • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
      • Next, using the plastic opening tool remove the blue panel.
      Ask FixBot
    2. HP Chromebook CB2L Battery Replacement: step 2, image 1 of 3 HP Chromebook CB2L Battery Replacement: step 2, image 2 of 3 HP Chromebook CB2L Battery Replacement: step 2, image 3 of 3
      • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
      • Gently pry off the white back panel using the plastic opening tool.
      Ask FixBot
    3. HP Chromebook CB2L Battery Replacement: step 3, image 1 of 1
      • Disconnect the battery input to the motherboard using the plastic opening tool
      Ask FixBot
    4. HP Chromebook CB2L Battery Replacement: step 4, image 1 of 1
      • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
      Ask FixBot
    5. HP Chromebook CB2L Battery Replacement: step 5, image 1 of 1
      • Using the plastic opening tool remove the battery from the Chromebook.
      Ask FixBot
3 other people completed this guide.
Gregory Hinkson
352 Reputation
3 Guides authored
USF Tampa, Team S2-G6, Lacy Spring 2017 Member of USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 Members
48 Guides authored
2 Guide Comments
the step about gently prying the underside of the laptop off made me snap off two screws under the thin blue rubber strip ! i see the holes they went in in the pictures in this guide. i understand that strip was glued on and it doesn't seem necessary to put those back (since i can't unglue the strip to put those screws back in) but.. yeah. it was unexpected and i thought i'd done something wrong.
katie - Reply Share
Dont forget there are two screws underneath the small blue strip.
Roderick Wells - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 26
All Time: 1,836
