HP Chromebook CB2L Speaker Replacement
    1. HP Chromebook CB2L Speaker Replacement, Battery: step 1, image 1 of 2 HP Chromebook CB2L Speaker Replacement, Battery: step 1, image 2 of 2
      • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
      • Next, using the plastic opening tool remove the blue panel.
      Ask FixBot
    2. HP Chromebook CB2L Speaker Replacement: step 2, image 1 of 3 HP Chromebook CB2L Speaker Replacement: step 2, image 2 of 3 HP Chromebook CB2L Speaker Replacement: step 2, image 3 of 3
      • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
      • Gently pry off the white back panel using the plastic opening tool.
      Ask FixBot
    3. HP Chromebook CB2L Speaker Replacement: step 3, image 1 of 1
      • Disconnect the battery input to the motherboard using the plastic opening tool
      Ask FixBot
    4. HP Chromebook CB2L Speaker Replacement: step 4, image 1 of 1
      • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
      Ask FixBot
    5. HP Chromebook CB2L Speaker Replacement: step 5, image 1 of 1
      • Using the plastic opening tool remove the battery from the Chromebook.
      Ask FixBot
    1. HP Chromebook CB2L Speaker Replacement, Speaker: step 6, image 1 of 1
      • Using the plastic opening tool lift the black tab.
      • Disconnect the blue and black strip from the motherboard.
      Ask FixBot
    2. HP Chromebook CB2L Speaker Replacement: step 7, image 1 of 1
      • Use the Phillips #1 screwdriver to remove the four 1.2mm screws circled red.
      Ask FixBot
    3. HP Chromebook CB2L Speaker Replacement: step 8, image 1 of 3 HP Chromebook CB2L Speaker Replacement: step 8, image 2 of 3 HP Chromebook CB2L Speaker Replacement: step 8, image 3 of 3
      • Gently pull the black wire to disconnect the audio port from the motherboard.
      • Disconnect the black wire connecting the speaker to the motherboard with caution.
      Ask FixBot
    4. HP Chromebook CB2L Speaker Replacement: step 9, image 1 of 1
      • Use the plastic opening tool to remove the speaker from back panel.
      Ask FixBot
Gregory Hinkson
352 Reputation
3 Guides authored
USF Tampa, Team S2-G6, Lacy Spring 2017 Member of USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 378
