HP Chromebook CB2L Trackpad Replacement
    1. HP Chromebook CB2L Trackpad Replacement, Trackpad: step 1, image 1 of 3 HP Chromebook CB2L Trackpad Replacement, Trackpad: step 1, image 2 of 3 HP Chromebook CB2L Trackpad Replacement, Trackpad: step 1, image 3 of 3
      • Flip the Chromebook over, and starting at the top right or left hand corner of the large blue piece, use the plastic opening tool to remove it.
      • Remove six 4.77mm screws using the Phillips #1 screwdriver.
      • This part has fragile plastic connectors on it. Do not damage them.
      Ask FixBot
    2. HP Chromebook CB2L Trackpad Replacement: step 2, image 1 of 3 HP Chromebook CB2L Trackpad Replacement: step 2, image 2 of 3 HP Chromebook CB2L Trackpad Replacement: step 2, image 3 of 3
      • Starting at either the top left or right hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel.
      Ask FixBot
    3. HP Chromebook CB2L Trackpad Replacement: step 3, image 1 of 2 HP Chromebook CB2L Trackpad Replacement: step 3, image 2 of 2
      • Remove four 3.42mm screws using the Phillips #1 screwdriver.
      • Disconnect the battery from the motherboard.
      • Remove the battery.
      Ask FixBot
    4. HP Chromebook CB2L Trackpad Replacement: step 4, image 1 of 1
      • Remove four 2.57mm screws using the Phillips #1 screwdriver.
      • Remove single 2.43mm screw using the Phillips #1 screwdriver.
      Ask FixBot
    5. HP Chromebook CB2L Trackpad Replacement: step 5, image 1 of 3 HP Chromebook CB2L Trackpad Replacement: step 5, image 2 of 3 HP Chromebook CB2L Trackpad Replacement: step 5, image 3 of 3
      • Remove the metal piece along the bottom of the trackpad.
      • Use the plastic opening tool to carefully flip the black piece on the ribbon cable holder then remove the ribbon cable.
      • Push the trackpad out from the keyboard side.
      Ask FixBot
Nathan Petrie
277 Reputation
2 Guides authored
IUPUI, Team S1-G4, Harley Fall 2018 Member of IUPUI, Team S1-G4, Harley Fall 2018
IUPUI-HARLEY-F18S1G4
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 27
All Time: 406
