HP Chromebook CB2L Audio Port Replacement
  1. HP Chromebook CB2L Audio Port Replacement, Audio Port: step 1, image 1 of 2 HP Chromebook CB2L Audio Port Replacement, Audio Port: step 1, image 2 of 2
    • Flip Chromebook over so that the bottom panel is facing upward.
    • Use the plastic opening tool to remove the blue panel.
    Ask FixBot
  2. HP Chromebook CB2L Audio Port Replacement: step 2, image 1 of 3 HP Chromebook CB2L Audio Port Replacement: step 2, image 2 of 3 HP Chromebook CB2L Audio Port Replacement: step 2, image 3 of 3
    • Unscrew the six 1.2mm screws on the metal plate using Phillips #1 screwdriver.
    • Lift the white panel by gently prying around the edges using the plastic opening tool.
    Ask FixBot
  3. HP Chromebook CB2L Audio Port Replacement: step 3, image 1 of 3 HP Chromebook CB2L Audio Port Replacement: step 3, image 2 of 3 HP Chromebook CB2L Audio Port Replacement: step 3, image 3 of 3
    • Disconnect the black wire which connects the audio port to motherboard.
    • Disconnect the gold strip connecting the audio port to motherboard
    Ask FixBot
  4. HP Chromebook CB2L Audio Port Replacement: step 4, image 1 of 2 HP Chromebook CB2L Audio Port Replacement: step 4, image 2 of 2
    • Unscrew four 1.2mm Phillips screws using Phillips #1 screwdriver.
    Ask FixBot
  5. HP Chromebook CB2L Audio Port Replacement: step 5, image 1 of 1
    • Using the plastic opening tool remove the audio port from the back panel.
    Ask FixBot
Fahad Al Raee
131 Reputation
1 Guide authored
USF Tampa, Team S2-G6, Lacy Spring 2017 Member of USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 35
All Time: 895
