Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Flydigi Vader 4 Pro was released June 28, 2024 by Flydigi, an electronics company based in Shanghai, China. Founded in 2008, Flydigi produces game controllers, accessories, and software.
The Vader 4 Pro's controller features a wide adjustment force range, 0.3mm fast trigger, and 12 bit rocker accuracy to support flawless gaming. The Vader 4 Pro weighs 270g, and provides around 15 hours of playtime.
A review of the Flydigi Vader 4 Pro appreciated how it caused no physical nor software problems.
Identification
The Flydigi logo is centered on top of the controller. Model name should be located on right grip of the controller. This device is only sold in black, with the exception of the special edition Assassin's Creed controller, which is white.
Technical Specifications
Battery
  • 800 mAh
  • 15 hours of playtime
  • 2 hours charging time
  • Red-to-green charging indicator
  • USB-C for connection
Controls
  • Wide adjustment force range
  • Stereo seismic trigger grip
  • 0.3mm fast trigger
  • 12 bit rocker accuracy
  • 100Hz rocker rate of return
Vibration
  • Vibration motors in triggers and grips
  • Switchable vibration triggers
  • Four-motor stereo vibration
Dimensions
  • 3.4 inches high
  • 7.4 inches long
  • 7.4 inches wide
Additional Information
Flydigi Vader 4 Pro Gaming Controller
Vader 4 Pro User Manual
Vader 4 Pro User Software
Author
with
Maklee Rhoades
171 Reputation
1 Guide authored
Past 24 Hours: 9
Past 7 Days: 40
Past 30 Days: 232
All Time: 1,228
