Introduction
Use this guide to replace the battery in a Flydigi Vader 4 Pro.
Remove the four 10 mm screws on the rear case using a Phillips #0 screwdriver.
Pull the white battery connector directly up and out of its motherboard socket.
Slide an opening pick under the battery to sever the adhesive securing it to the mainboard.
Lift the battery up and out.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
