Introduction
If your Flydigi Vader 4 Pro does not vibrate as expected during gameplay, this guide can be used to replace the console's vibration motors. Vibration motors are located in the grips of the console and should vibrate according to gameplay impact-unless vibration settings are specifically changed with the Flydigi Space Station software. It is important to note that in Step 4 the vibration motor's JST-PH connector may be difficult to disconnect. Use a gentle hand when disconnecting.
Remove the four 10 mm screws on the rear case using a Phillips #0 screwdriver.
Disconnect each of the two vibration motor connectors.
Remove the vibration motors.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
