Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓If your Flydigi Vader 4 Pro needs new action buttons, also known as face buttons, this guide can be used to replace them. The action buttons are located on the upper right side of the console, labeled XYAB. The action buttons are the most frequently used during gameplay, so damage and need for replacement is common.
Remove the four 10 mm screws on the rear case using a Phillips #0 screwdriver.
Disconnect each of the two vibration motor connectors.
Remove the vibration motors.
Remove the seven 10 mm screws securing the mainboard using a Phillips #0 screwdriver.
Remove the four 6 mm screws securing the action buttons bracket with a Phillips #00 screwdriver.
1 Guide Comment
Hi do you know where i can source a silicone membrane for the action buttons
