Introduction
If your Flydigi Vader 4 Pro is not responding despite functional external components, or continues to exhibit multiple system-wide issues after individual parts have been tested or replaced, this guide can be used to replace the mainboard. The mainboard is the central component of the controller, connecting and controlling all internal systems including buttons, thumbsticks, vibration motors, and wireless communication. Because it manages all core functions, failure of the mainboard can prevent the device from operating correctly. It is important to note that improper unscrewing or excessive force during disassembly may cause flexing or damage to the mainboard. Handle all components carefully to prevent unnecessary stress on it.
Remove the four 10 mm screws on the rear case using a Phillips #0 screwdriver.
Disconnect each of the two vibration motor connectors.
Remove the vibration motors.
Remove the seven 10 mm screws securing the mainboard using a Phillips #0 screwdriver.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
