Up to 20% off select tools
Flydigi Vader 4 Pro Front Case Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
115
All Time:
562
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your Flydigi Vader 4 Pro needs a new faceplate, or if users need access to the inside of the console, this guide can be used to disassemble. The faceplate protects the inner parts of the console and allows firm grip. It is important to note that in Step 2 the faceplate seal may be difficult to open. Careful use of leverage while opening is important.
    1. Flydigi Vader 4 Pro Front Case Replacement, Front Case: step 1, image 1 of 3 Flydigi Vader 4 Pro Front Case Replacement, Front Case: step 1, image 2 of 3 Flydigi Vader 4 Pro Front Case Replacement, Front Case: step 1, image 3 of 3
      • Remove the four 10 mm screws on the rear case using a Phillips #0 screwdriver.
      Ask FixBot
    2. Flydigi Vader 4 Pro Front Case Replacement: step 2, image 1 of 2 Flydigi Vader 4 Pro Front Case Replacement: step 2, image 2 of 2
      • Insert an opening pick into the seam between the rear and front case.
      • Pry around the perimeter of the controller.
      • Remove the rear case and set it to the side of the front case, with care not to strain the connected cable.
      Ask FixBot
    3. Flydigi Vader 4 Pro Front Case Replacement: step 3, image 1 of 1
      • Disconnect the JST-PH connector from its motherboard socket.
      Ask FixBot
Author
with
Taehwan Kim
636 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 115
All Time: 562
