Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device won't turn on
You have tried turning on the device but nothing happens
Drained Battery
If your tablet does not turn on, it may be low on charge. Try plugging the device into the charger, wait 10-15 minutes, and try turning it on again. If the tablet still does not turn on, wait for it to fully charge, then try again.
Dead Battery
If the device refuses to charge, the battery may be dead. In this case, you will need to purchase and install a new battery. Follow the Battery Replacement Guide to find out how to do this.
Screen is cracked
The screen has been damaged and will not respond. In that case, the damaged or cracked screen will have to be replaced by following the Screen Replacement Guide
Case is broken
If your tablet's outer case is cracked, scratched, or indented, the device may have been dropped. To remove the case and replace it with a new case, follow the Case Replacement Guide.
Buttons are stuck or not responding
The power button, home screen button and/or the volume button are not responding
Buttons cannot be pressed
When the button cannot be pressed or when a button is pressed and it takes longer than usual to pop back up, there may be something below the actual key that is holding it up. To fix these, remove the button and make sure nothing is stuck below it. You may have to wipe the surface underneath. Once the area is clean, place the button back. To find out how to do this, follow the Button Cleaning/Replacement Guide
Buttons are missing
If the power button, home screen button and/or volume button are missing, then you will have to replace them.
Audio Not Working
The device is on, but the audio is not working properly
Very low sound
The volume on the tablet may be turned down. Try using the buttons on the side to increase the speaker volume until sound can be heard.
There is no sound
The volume may be turned up, but the device may be on a muted setting. Try going into the device settings and removing it from the muted state.
Damaged Speakers
The speaker on the tablet may be damaged and/or not working properly. Try restarting the device. If this does not fix the problem, Try re-installing the OS. It should fix the problem. If not, the speaker may need to be replaced. To replace the speaker, follow the Speaker Replacement Guide.
Weak Network & Wi-Fi Signal
If you aren't receiving Network or Wi-Fi signal, first make sure that you are in airplane mode or not. After that check the network connection. Then ensure that Wi-Fi connection is working properly. If the issue still occurs the antenna may need to be replaced. To replace the antenna, follow the antenna replacement guide.
Author
with
Chris Nelson
219 Reputation
2 Guides authored
USF Tampa, Team 5-1, Brown Winter 2015 Member of USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Members
72 Guides authored
3 Comments
My tablet states "Unfortunately, com.qihoo.security has stopped." It also states in Blue REPORT or OK. It will not leave this screen no matter what I click on.
Elma Van Buren - Reply Share
I'm sorry that when I contacted you before with a comment I forgot to leave you with my email address to contact me back. It is elmavanburen@gmail.com.
I have a skynet also known as skypad and i only dropped it once but it still kept working but a month later i couldn't tap certain things on my tablet like half of the screen i could tap it but the other i couldn't sometimes the audio didn't work but all i needed to do was reboot it but one night i was using my skypad and i thought it died because the screen just automatically went black so i tried turning it on...nothing i waited the next morning so it would charge and when it loaded it brought we to the start up screen but then it would turn black and then when i turn it back on it would just keep on doing it until finally it stopped and just didn't do any start up screen these tips are helpful but not enough (for me at least)
Super Gemcollecter - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 2,187
