Skytex SP728 Antenna Replacement
    1. Skytex SP728 Antenna Replacement, Case: step 1, image 1 of 1
      • Make sure the device is powered off
      • Rotate the device so the ports and screws face you
      Ask FixBot
    2. Skytex SP728 Antenna Replacement: step 2, image 1 of 1
      • Using a small phillips screwdriver, unscrew both end screws
      Ask FixBot
    3. Skytex SP728 Antenna Replacement: step 3, image 1 of 1
      • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
      Ask FixBot
    4. Skytex SP728 Antenna Replacement: step 4, image 1 of 1
      • Once the case has been loosened, pry the backing off gently with your hands.
      • Make sure to remove the case gently as extra force can break the clasps or the case itself.
      Ask FixBot
    1. Skytex SP728 Antenna Replacement, Antenna: step 5, image 1 of 1
      • Remove the case and open the device
      Ask FixBot
    2. Skytex SP728 Antenna Replacement: step 6, image 1 of 1
      • Remove the black tapes
      Ask FixBot
    3. Skytex SP728 Antenna Replacement: step 7, image 1 of 1
      • Use the soldering station and remove soldered connections to the antenna wires.
      • Now replace the antenna.
      • Follow the link below for additional soldering information "https://www.ifixit.com/Guide/How+To+Sold...
      Ask FixBot
Galika Adhikari
248 Reputation
2 Guides authored
USF Tampa, Team 5-1, Brown Winter 2015 Member of USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Members
71 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 381
